Newb enclosure build help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-13-2013, 02:41 PM - Thread Starter
Blackls1z's Avatar
I have an elemental design 13kv.2 kicking around. I'm looking to start the build but need assistance with what size enclosure. Specs are as follows:
Specifications
Qts: .31
Qes: .35
Qms: 3.33
Fs: 21.50Hz
Re: 3.7
Vas: 162L
Mms: 142.0g
Bl: 15.00T*m
SPL: 88.47dB
Sd: 545cm²
Xmax: 15.1mm
Voice Coil: 50.0mm
Magnet Width: 5.700"
Cutout Diameter: 11.000"
Mounting Depth: 5.750"
Weight: 14lb
Total Height: 6.250"
Displacement: .06 ft³
Outside Diameter: 12.375"
Watch movies about 75% of the time and listen to music the rest. Looking for some nice low end for movies yet still have decent punch for music. Any suggestions would be much appreciated. Thanks!
Blackls1z is offline
post #2 of 2 Old 01-13-2013, 04:23 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Not sure how accurate those specs are, as ED was known for being pretty far off... A 4 ft3 box, with a 4" x 17" port (21 hz tune) should work well with a 300 watt amp. A 20" x 20" x 24" box would get you the needed volume, and allow for some bracing.
Amp
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-750
Port
http://www.parts-express.com/pe/showdetl.cfm?partnumber=268-352
Jay1 is offline
