Problems finding 1" MDF - do I really need it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-17-2013, 09:27 AM - Thread Starter
Aaron_G's Avatar
I am building a this sub cabinet (60 L) that calls for 1" thick MDF, but I cannot find that anywhere and I have called a dozen building supply and lumber stores in Houston.
Can I get away with 3/4" MDF and address the baffle separately, perhaps doubling it up or doing MDF over a plywood layer for added strength? Or should I do two layers of 1/2" thick MDF?
I have built plenty of subs boxes in my day but never with 1" MDF, but I don't want to short change myself.
Aaron_G is offline
post #2 of 15 Old 01-17-2013, 09:41 AM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 438
I can't think of any scenario where 1" MDF would be required. Proper bracing is effectively the same as doubling the wall thickness. I would run a double baffle, but other than that 3/4" is plenty sufficient. I can't imagine the weight of a complete 1" MDF cab.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 15 Old 01-17-2013, 10:01 AM
Bill Fitzmaurice's Avatar
Liked: 4704
A lot more than that. Imagine that the colored squares below are panel to panel braces, viewed end on:
The red brace alone gives the panel the same stiffness as does doubling the panel thickness. Adding the blue braces gives the panel the same stiffness as does quadrupling the panel thickness.
Bill Fitzmaurice is online now
post #4 of 15 Old 01-17-2013, 01:02 PM - Thread Starter
Aaron_G's Avatar
Awesome info, thanks guys. I did find a place that sells a 4'x8' 1" thick MDF sheet for $57/sheet, but based on your input I am going to use 3/4" MDF and incorporate the proper bracing, which the plans call for one middle brace, but I might add two and make the box slightly larger to compensate.
Aaron_G is offline
post #5 of 15 Old 01-17-2013, 01:33 PM
Liked: 4704
I wouldn't brace it according to the plans. For one thing braces near the corners are wasted material, as that's the strongest part of the box and doesn't need bracing. But more important is that bracing the front to the back is just as necessary as bracing the top to bottom and sides to each other.
post #6 of 15 Old 01-17-2013, 01:49 PM
Colm's Avatar
Liked: 94
...I have called a dozen building supply and lumber stores...
You are looking in the wrong place. You need to go to a place that supplies the cabinet trade. Look for "hardwood". There are places in Huston that can supply what you are looking for.
Colm is offline
post #7 of 15 Old 01-17-2013, 02:29 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
This is great info. Thanks for sharing this.
ack_bk is offline
post #8 of 15 Old 01-21-2013, 01:14 PM - Thread Starter
Aaron_G's Avatar
I don't follow. The plans call for bracing down the center of the cabinet, parallel to the face of the sub, not near the corners. I could add some threaded rod bracing from the front panel to the back panel, but given the location of the sub and the port I don't see how I could add the same type of bracing from front to back.
Aaron_G is offline
post #9 of 15 Old 01-21-2013, 01:16 PM - Thread Starter
Aaron_G's Avatar
Thanks, I will keep that in mind.
Aaron_G is offline
post #10 of 15 Old 01-21-2013, 02:46 PM
Liked: 4704
I don't follow. The plans call for bracing down the center of the cabinet, parallel to the face of the sub, not near the corners. .
I see a 'window' brace, which resembles the picture below left, albeit a much fancier iteration. It's got plenty of material in the cab corners. A more effective version that uses less material is shown below right.
post #11 of 15 Old 01-22-2013, 08:12 AM - Thread Starter
Aaron_G's Avatar
AHHH, understood now. A picture is indeed worth 1000 words! Thanks for clarifying.
Aaron_G is offline
post #12 of 15 Old 01-22-2013, 08:14 AM - Thread Starter
Aaron_G's Avatar
BTW, would 3/4" MDF material be sufficient to make that type of brace? Should I double up two pieces of 3/4" MDF or is that overkill?
Aaron_G is offline
post #13 of 15 Old 01-22-2013, 08:59 AM
Liked: 4704
I don't care for MDF as a brace material, being rather brittle it easily will snap, though once installed that's no concern. In terms of the required strength 1/2" plywood is adequate.
post #14 of 15 Old 01-22-2013, 09:04 AM - Thread Starter
Aaron_G's Avatar
That seems reasonable. I can manage to build the brace with some 1/2" plywood.
I appreciate your input, it helps greatly.
Aaron_G is offline
post #15 of 15 Old 01-22-2013, 09:18 AM
Jinjuku's Avatar
Quoted: 65 Post(s)
Liked: 148
Try a google search for architectural lumber and your zip code or zip code of nearest, largest city.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
