Full DIY HT Replacement - SEOS Tempests + SEOS Fusion 10s + Dayton 18s - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #181 of 343 Old 03-23-2013, 01:53 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
itll be easier for me to lay the one on the right down and rotate the one on the left, which should accomplish the same thing
Sibuna is offline
post #182 of 343 Old 03-23-2013, 06:06 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
I don't know if that would work. How big is the board? Looks pretty compact.
Mrkazador is offline
post #183 of 343 Old 03-23-2013, 07:49 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
its like 5x7
and there is room to do what i said if that is what you were concerned about
Sibuna is offline
post #184 of 343 Old 03-23-2013, 10:43 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
This was my suggestion, excuse the horrible drawing...
If I understood you correctly, this is what you wanted to do? You can see how the two inductors on the left would interfere.
You should probably get a second opinion on this.
post #185 of 343 Old 03-24-2013, 04:25 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 521
Why not just move the right inductor up a little bit and rotate the middle inductor to a 45 degree angle?
Gorilla83 is offline
post #186 of 343 Old 03-24-2013, 07:12 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 771
also if anyone is curious about how far 1 gallon of Duratex will go. Ive done 2 of the 2 CUFT and 2 of the 1 CUFT boxes for fusions and Tempests, 2 of the 4 CUFT sub boxes all with 2 coats, and 1 large lamp with 1 coat and still have about 1/2 of it left
This is very helpful to know, thx for posting.
I've read what they say about coverage but 1st hand accounts are best.
Did you put any primer on beforehand?
Is so, was it dark or light?
What does the can say about shelf life?
Sent from my 32GB iPhone4 using Tapatalk
mtbdudex is offline
post #187 of 343 Old 03-24-2013, 07:53 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
i got it now, i was being dumb yesterday and forgot there were 3 inductors and not 2
derp derp
Sibuna is offline
post #188 of 343 Old 03-24-2013, 07:55 AM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
nope no primer. i just rolled it on the bare MDF
Gorilla used a black primer on his and said it made covering with 1 coat easier. not sure about shelf life ill have to look
Sibuna is offline
post #189 of 343 Old 03-24-2013, 11:33 AM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
derp derp
The inductor on the far right would interfere with the one in the center. I would try moving the inductor on the far right up higher. Another option is to rotate the inductor on the far right 90 degrees. Measure the center of the inductor on the far right to the inductor on the far left. I've seen some people recommend at least 2-4 inches between inductors.
post #190 of 343 Old 03-24-2013, 12:17 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
got it rotate and move up i can do that
in the meanwhile
Sibuna is offline
post #191 of 343 Old 03-24-2013, 01:12 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Sibuna is offline
post #192 of 343 Old 03-24-2013, 01:26 PM
mtg90's Avatar
Quoted: 469 Post(s)
Liked: 925
That looks amazing! Well done on the finish.
mtg90 is offline
post #193 of 343 Old 03-24-2013, 01:38 PM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 521
Looks great, Adam! I've got a new entertainment center on my list but will probably be a few months behind once I get the new AT screen and false wall done. Great job!
post #194 of 343 Old 03-24-2013, 02:21 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Thanks, it came out better then i expected. and larger. but everything fits, however once i get the rears up and start messing with the EQ i have the feeling ill be moving one of the subs to right behind the couch for more impact
of i could just build another one, obviously i have space for more amps biggrin.gif
This is what it looks like with the TV up. Just tossed it up there for a pic really fast as im supposed to wait 36 more hours until i put weight on the top :/
reason perspective looks funny is because of the 11mm lens
Bombelman likes this.
Sibuna is offline
post #195 of 343 Old 03-24-2013, 05:31 PM
tuxedocivic's Avatar
Quoted: 2179 Post(s)
Liked: 2048
Amazing job. The finish looks fantastic.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #196 of 343 Old 03-24-2013, 07:15 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
thanks Tux
rears are up, had to order more speaker wire, i ran out of the good stuff
time to start playing with stuff tomorrow after work i guess
Sibuna is offline
post #197 of 343 Old 03-24-2013, 07:21 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
ive done just that. they measure 2.5-2.75 between the centers, one on the right has been rotated and is up as high as it will go
Sibuna is offline
post #198 of 343 Old 03-25-2013, 06:27 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
So got everything setback up today. moved the giant Ethernet cord mess off the floor, drilled a hole in the wall to pass 1 cord through and got all the others arranged under the rug and behind the TV stand, 8 things wired into a 8 port GigE switch into a wireless router.
wired up the rears and ran YPAO after an extreamly long Firmware update on the RX-A3000
and this is what i end up with, Mains crossed at 80Hz, Rears at 160, all Levels set to 0, distances match what i measure with a tape +/- a few inches
Sibuna is offline
post #199 of 343 Old 03-25-2013, 06:46 PM
antisuck's Avatar
Quoted: 113 Post(s)
Liked: 159
antisuck is offline
post #200 of 343 Old 03-25-2013, 07:29 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
this is a better graph i didnt realize the scale was all messed up on that
Sibuna is offline
post #201 of 343 Old 03-25-2013, 08:04 PM
LTD02's Avatar
Quoted: 2505 Post(s)
Liked: 2835
your response is not bad at all. a little absorption on some of those surfaces may help smooth things out a bit.
Listen. It's All Good.
LTD02 is offline
post #202 of 343 Old 03-26-2013, 04:44 PM
wywern209's Avatar
Do you plan to build a seos type center?
wywern209 is offline
post #203 of 343 Old 03-26-2013, 05:01 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Sibuna is offline
post #204 of 343 Old 03-26-2013, 05:27 PM
wywern209's Avatar
yea at somepoint i will
sweet. I look forward to a seos center!
post #205 of 343 Old 03-26-2013, 07:40 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Yea im not sure which one ill build yet, the Big Mal got taken down because of driver availability. It was running the SEOS 12 + 4 6" drivers under it. However Erich said he was working on a replacment. Also someone mentioned a MTM design based on the fusion 8 was in the works. So ill wait and see
Speaking of the Fusion 8s, i sanded down mine today and filled some areas with wood putty. they will get another sanding this week and ill start finishing them
They are going to be stained like the TV stand was - same color/gloss and the front will be done with duratex
Sibuna is offline
post #206 of 343 Old 03-28-2013, 05:01 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Sibuna is offline
post #207 of 343 Old 03-30-2013, 04:06 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Today it was finally warm enough outside to spray paint so i finished the speaker grills for the subs
Fusions should be up and running tomorrow. Poly Coats should be done today. Just have to duratex the front baffle and then install
Sibuna is offline
post #208 of 343 Old 03-31-2013, 03:28 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Fusion 8's are done - more pics incoming. time to eat
Sibuna is offline
post #209 of 343 Old 03-31-2013, 03:40 PM
carp's Avatar
Quoted: 2789 Post(s)
Liked: 2102
carp is offline
post #210 of 343 Old 03-31-2013, 04:04 PM - Thread Starter
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
Thanks carp, really like how these came out
rest of the pics
Sibuna is offline
