Full DIY HT Replacement - SEOS Tempests + SEOS Fusion 10s + Dayton 18s - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 343 Old 01-17-2013, 07:35 PM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
So its about time I started my own thread as ive been lurking in everyone else’s for some time. My HT is less of a dedicated space than many but it works, It’s a very small space with a very interesting shape. Main listening area is 12x15 with a 7 foot celling. The kicker is its on the 3rd floor of a house and has knee walls and odd sloped ceilings. Open on either side to rooms that can be closed off and open to the back for ~20 feet . Just a TV and speakers, no room for a projector.
I’ve been planning on upgrading in one form or another for what seems like an eternity. Current Speakers are a pair of Wharfedale Sapphires for L&R and a pair of old Advents for rears. Running Phantom center currently as I don’t really have room for 1, there is one in the pic but its not used. I’ve had all these speakers since HS/College, they have served me well but, ive always wanted more.
Being someone always looking for a deal, DIY is right up my alley. More bang for the buck as it were. After I built a pair of overnight sensations for my dad this summer I figured I’d go all out and have been waiting for all the SEOS stuff to get finished. Also after spending about 30 seconds at Gorillas house I decided I’d so subs as well.
Sold my PB12 to help fund this. Current setup with a Bic-F12 as a stand-in for the time being as it was sitting around.
Building 2 of the Tempests for L&R and 2 of the Fusion Max 10s for surrounds. And 2 of the Dayton 18’s in ~4 CUFT boxes. My plan is to place the dayton’s on either side of the TV and stand the Tempest’s on them. Fusions will sit on stands in the back. I am also having a new TV stand built that will be taller than the current one and about 55 inches wide – which is ~5 inches wider than the TV. Everything should work out fine in the space. and everything will fit on the new stand including the PS3/Xbox for a much cleaner look.
Will be powering the Daytons from an EP4000, will run the L&R off an Emotiva XPA-3 and the rears off the AVR (Yamaha RXA-3000). I will probably add a center at some point, when I was doing some measuring I can get the Malcolm to fit by propping the TV up a little on the stand, but if I do that I will be later.
Almost ready to get started. Most of my parts are here but I’m still waiting on the enclosures form Erich. He said the Fusions will most likely ship out next week and the Tempests not far behind them. And the word on the sub boxes is “soon”. I decided to purchase the enclosures because I don’t really have the means to cut everything. My 30 year old table saw isn’t up to it + it scares the crap out of me and I don’t own a router.
Plan on finishing everything with duratex.
Bunch o pics of what I have now
Current setup
Compression drivers
360
350
all this stuff came today (minus the Cat) That is Jake my helper
Tempest Parts
Fusion Parts
12" SEOS Horns
Ports
Baffle for the Fusion 10
Baffle for the tempest
Delta 10A
Delta Pro 12a
Dayton 18"
Sibuna is offline
post #2 of 343 Old 01-17-2013, 07:52 PM
skeeter99's Avatar
Man it sounds like you've done your homework very well and have it planned out very nicely. I'll definitely be watching your build as its almost identical to what I want to do. Keep the thread going with pics as you build along. Congrats! Really excited for you!!
Scott
EDIT: Man those Dayton's are beefy cool looking drivers!
skeeter99 is offline
post #3 of 343 Old 01-17-2013, 07:57 PM
mtg90's Avatar
Quoted: 412 Post(s)
Liked: 778
Wow looks like you are going to be busy, that should be a decent upgrade over what you have now.
On a side note are you still using the 4 DIY bookshelf speakers I sold you?
mtg90 is offline
post #4 of 343 Old 01-17-2013, 08:07 PM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Yep I'm listing to them as i type this. 2 of them are used in my computer room paired with an Epik legend. the other 2 i gave to my dad for xmass. Replaced a pair of 25 year old Magnepan's that i believe have started to delaminate. The two of us are going to attempt to fix them this summer.
Hes really happy with them, as they don't make any odd crackling sounds (ie they aren't broken) was totally shocked on xmass morning because i ninja installed them at like 2 AM biggrin.gif
comp
Dads - crappy cellphone pic
Sibuna is offline
post #5 of 343 Old 01-17-2013, 08:08 PM
MrSmithers's Avatar
Subbed. This should be a really cool build, you're going to absolutely obliterate that space! I know in some ways it's the least impressive of the three, but there's something I really like about the look of the Eminence Delta-10A driver. Get started on those crossovers!
MrSmithers is offline
post #6 of 343 Old 01-17-2013, 08:21 PM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
I would start them this weekend but i need to wait for the flat packs because of the style of bracing i need to be sure how much room i have between the ribs
http://www.diysoundgroup.com/flat-packs-1/seos-flat-packs/2-cuft-tall-seos-flat-pack.html
Sibuna is offline
post #7 of 343 Old 01-17-2013, 08:27 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
Should be awesome! Two words though. FALSE WALL. Think about it.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #8 of 343 Old 01-17-2013, 08:33 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Very cool thread, subscribed... You guys are killing me with the waveguide build.. I really like my current speakers, but....
ack_bk is offline
post #9 of 343 Old 01-17-2013, 08:40 PM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
hehehe
Sibuna is offline
post #10 of 343 Old 01-17-2013, 08:46 PM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Lots of fun about to go down here....
Gorilla83 is online now
post #11 of 343 Old 01-17-2013, 10:47 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
I'm anxious to see this unfold. I'm currently running a 9 speaker Axiom setup which has worked just fine for me, but I'm debating taking it to the next level. Builds like this are a great inspiration.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #12 of 343 Old 01-17-2013, 11:23 PM
rr14's Avatar
Quoted: 38 Post(s)
Subbed! I'm looking to go DIY with very similar setup.
rr14 is offline
post #13 of 343 Old 01-18-2013, 03:21 AM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
You definitely should. I've never heard Axioms but i would bet they aren't far off from the Aperions I had. Going to high efficiency horns is a huge difference.
Rivers Edge Theater
post #14 of 343 Old 01-29-2013, 11:28 AM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
1:19 pm Delivered
Left at front door. Signature Service not requested.
7:10 am On FedEx vehicle for delivery
4:54 am At local FedEx facility
i think i will leave work early today - those are the Fusion 10s. Tempests shoudl be here on Wedns
Sibuna is offline
post #15 of 343 Old 01-29-2013, 01:09 PM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
post #16 of 343 Old 01-29-2013, 04:52 PM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Originally Posted by Gorilla83 View Post
if you say so
Erich shipped me 2 of the Fusion 10 flatpacks in 1 box. He was not sure this would work because of weight/potential damage. However after sending a test box to another AVSer with success he mailed mine out. The flatpacks for the tempests come tomorrow
Box from Erich
Expert packing as always
Hurray for foam
Dry fit
Putting the Daytons to work - just have the braces in now, will go down in a bit do top/bot and maybe sides
Sibuna is offline
post #17 of 343 Old 01-29-2013, 07:37 PM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
should have the inner baffle on tonight, can possibly get the other side on before i go to work in the morning
Sibuna is offline
post #18 of 343 Old 01-29-2013, 07:45 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Nice build thread and cool project!
Keep the pix coming!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #19 of 343 Old 01-29-2013, 07:53 PM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
post #20 of 343 Old 01-29-2013, 08:01 PM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
yea these things are pretty cheap and work great, i have 4x of the 18s 4x 24s and 3x 36s. ill need at least 1 more 36 for the sub boxes. they only had 3 last time i was at home depot
Sibuna is offline
post #21 of 343 Old 01-29-2013, 08:38 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
Rivers Edge Theater
post #22 of 343 Old 01-29-2013, 09:02 PM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
and the lord said
LET THERE BE CLAMPS
ive tried, doesn't work, reed gets too floppy
Sibuna is offline
post #23 of 343 Old 01-29-2013, 11:53 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
That 2nd side panel might need to be tapped into place with that hardcore clamping method you have going on there! But that's still an easier way to assemble than trying to squeeze in that inner baffle after the sides are in place. At least it seemed like it to me.
Looks like the foam took a beating! They must have dropped that package a few times on the sides to get that.
The foam is one thing I worry about replacing for packaging once I run out. I don't actually figure that into the packaging costs because I got a huge amount of that stuff for nearly free when a local door manufacturer closed down. Well, I did spend a day picking up pallets of it. biggrin.gif Same with those corner protectors.
I'm guessing I have enough foam panels to last about a year, so hopefully I'll find some more in that time.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #24 of 343 Old 01-30-2013, 06:11 AM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
WTF im pretty sure i posted in here this morning before i left for work.
anyway. the side panel went in fine with just a few taps from a rubber mallet to get it started. after that just a few taps to square it up. the clamps are not super tight. Ill get started on the 2nd one this evening.
Sibuna is offline
post #25 of 343 Old 01-30-2013, 06:35 AM
bmg963's Avatar
Erich, regarding styrofoam, think outside the box. being that i build houses, i trash foam packaging all the time. To get more for free (a little time and communication involved though), visit construction sites when they have appliances delivered, visit stores who may run through lots of foam when unpackaging for floor demos, things of that nature. Appliance stores, electronic stores, furniture stores etc... It's there for the taking if you just speak with them about saving it for you! Mark
bmg963 is offline
post #26 of 343 Old 01-30-2013, 07:24 AM
tuxedocivic's Avatar
Quoted: 1904 Post(s)
Liked: 1724
Hey Sibuna!
Nice work you're doing here. Appreciate you picking up my kit and documenting it here. I hope you enjoy them. Any questions feel free to pm me. Ill try and keep an eye on this thread. It's so insane how many are starting I'm worried ill miss some builds.
Thanks again!
Ryan
tuxedocivic is online now
post #27 of 343 Old 01-30-2013, 07:28 AM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Originally Posted by tuxedocivic View Post
Hey Sibuna!
Thanks again!
Sibuna is offline
post #28 of 343 Old 01-30-2013, 08:50 AM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Looking at your assembly steps, along with others, always reminds me what a slob I am when I put things together. Everything within ten feet gets pl on it. Nice work!
ChopShop1 is offline
post #29 of 343 Old 01-30-2013, 09:07 AM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
lol TBH thats kinda why i avoid using PL for main assembly. ill do touchup with it to fill gaps and such. The flatpacks go to well so easy all you need is tightbond
ill prob end up doing the sub boxes with PL just because they really need to be a bit stronger
EDIT
Tempests were just deleivered
Sibuna is offline
post #30 of 343 Old 01-30-2013, 06:50 PM - Thread Starter
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Box 1 of the fusions is finished - just need to attach the outer baffle
Tempests arrived today, Boxed up masterfully - Erich these ones didn't show the indents on the Styrofoam like the dbl packed fusions did
Dry fit next to Fusion #2 -
Holy crap they are large - AKA i suck at judging size in 3 dimensions - not a big deal they just look so much larger in person - rillas 15s must be massive
Made some more room - much more assembly line looking now
Tempest #1
Should get the inner baffle on Fusion #2 tonight and prob the other side in the morning - might get the braces in Tempest #2 but it depends on clamps
Every time i type clamps this is all i can think of
Sibuna is offline
