VALUE FOR MONEY AMPLIFIER FOR REAUDIO XXX 18 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-18-2013, 04:28 AM - Thread Starter
Ourania Mylona's Avatar
which is the most value for money amplifier for sealed re audio xxx 18 after lab gruppen fp 14000 clone?
my goal is to reach with high spl <20hz.
i am between crown xls 5000 and nova x 6000.
what do you think?
can you propose me something else?
thank you in advance
Michael
Ourania Mylona is offline
post #2 of 8 Old 01-18-2013, 05:30 AM
keager's Avatar
Are they sealed? What size enclosure? I believe these want more than the clone can give in a relatively small sealed box. Maybe the 5000kw cerwin vega?
keager is offline
post #3 of 8 Old 01-18-2013, 05:35 AM - Thread Starter
it is 9 cu ft sealed.
post #4 of 8 Old 01-18-2013, 06:19 AM
subyguy's Avatar
Liked: 27
(3) JTR Noesis 212HT (LCR) (2) JTR Single 8 (wides) (2) JTR Slanted 8 (sides) (2) DIY Eminence 10" coax (rear Surrounds)
(2) JTR Orbit Shifters (2) Mach5 UXL-18's sealed (2) Soundsplinter 15's sealed Speakers powered by 6 crown xls 1500's
UXL's powered by Peavey IPR-7500 My theater: http://www.avs...
subyguy is online now
post #5 of 8 Old 01-18-2013, 08:24 AM
Looneybomber's Avatar
Originally Posted by subyguy View Post
CV has teamed up with Dr Emmett to come up with a reliable way to power the flux capacitor.
YID DIY
Looneybomber is offline
post #6 of 8 Old 01-18-2013, 09:35 AM
keager's Avatar
Woah. Maybe I over rated that wattage a bit. Lol
keager is offline
post #7 of 8 Old 01-18-2013, 10:31 AM
BassThatHz's Avatar
Quoted: 2383 Post(s)
Liked: 2155
These are all proven top-shelf amps of a "similar" build-quality (that ALSO come with warranties)... as least as similar as one could get from a different company! !
In no particular order:
A MA-5050 or QSC-5050, PL380 or PLX3602, or a Crest 9200 or CC5500, or nu3000DSP, crown XTI6002.
I wouldn't be personally confident it comparing it to anything less than a top-shelf amp, as the clones are no slouch.
There is also many other china-based switcher amps in existance. How they compare? God only knows.
An actual closer comparisons would be either a: PS K10 or Crown iT8000 or a few heavy-horses with 900X or 1000X in their names. None are cheap/cheaper so. wink.gif
Ourania Mylona likes this.
BassThatHz is online now
post #8 of 8 Old 01-18-2013, 11:00 AM
beastaudio's Avatar
Quoted: 4147 Post(s)
Liked: 3504
Having had two sealed RE's on a clone, they take a lot to get moving. if you are wanting them to be purely for sub20hz content you are in good shape, and some of the suggested amps will work fine. I will say though, the LG 14k is killer, and the RE's take every bit of power it throws out, and still could ask for more.
beastaudio is online now
