Dumb newb sub build q... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-21-2013, 03:17 PM - Thread Starter
goonstopher's Avatar
Quoted: 286 Post(s)
Liked: 55
If you dont have cnc or tightly cut slot aligned braces, how do you get the bracing to stay in place while gluing?
It doesn't seem like nailing into thin strips would work out well
goonstopher is offline
post #2 of 7 Old 01-21-2013, 03:27 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
I use a nailer, works great.
N8DOGG is online now
post #3 of 7 Old 01-21-2013, 11:25 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Clamp or brad nailer. Hell, if the braces slide into the cabinet snugly, PL holds them plenty firm until it sets up.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #4 of 7 Old 01-21-2013, 11:32 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Jay1 is offline
post #5 of 7 Old 01-22-2013, 05:07 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 674
Nailer, screws, or clamps
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #6 of 7 Old 01-22-2013, 07:23 AM
nograveconcern's Avatar
Quoted: 91 Post(s)
Liked: 128
Drill a small pilot hole before nailing. Also, if you drill the hole through the cab first you can pencil in an X on the inside of the cab to help align the brace to the hole. Then you can re-pilot hole with the brace once in place before nailing or driving in a screw.
nograveconcern is offline
post #7 of 7 Old 01-22-2013, 07:49 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 674
Nailer as in air tools. Not regular hammer and nails. If you don't have a brad nailer and cannot use clamps, use the pilot hole/ screw method.
Rivers Edge Theater
