Possible to DIY the B&W 800 Diamond? - Page 4 - AVS Forum
post #91 of 123 Old 01-25-2013, 12:48 PM
Face2's Avatar
Quoted: 18 Post(s)
Liked: 41
Originally Posted by Jay1 View Post
The mid and tweeter are among the lowest distortion available regardless of price, and the woofers have very impressive capability. DIY FTW.
That tweeter doesn't do so well once it has a few watts running through it.
Mike
Face2 is online now
post #92 of 123 Old 01-25-2013, 12:58 PM
Jay1's Avatar
Liked: 102
What are you basing that assessment on?
Jay1 is offline
post #93 of 123 Old 01-25-2013, 12:58 PM
Jay1's Avatar
Liked: 102
Jay1 is offline
post #94 of 123 Old 01-25-2013, 01:12 PM
Face2's Avatar
Quoted: 18 Post(s)
Liked: 41
Measurements.
Mike
Face2 is online now
post #95 of 123 Old 01-25-2013, 01:20 PM
Bill Fitzmaurice's Avatar
Liked: 1284
Originally Posted by ChopShop1 View Post
Its interesting how how some folks hear differences and some don't.
IME, and that of most acoustical engineers, what you hear has got a lot to do with what you see. I know that if I saw a receipt that said $12k on it I had better hear a difference, and that if I didn't know what I do about how speakers work I'd have no trouble convincing myself that I did. I'm positive that Wilson makes his cabs as ugly as he does intentionally, as the average more money than brains buyer of same would think anything that expensive that's also that ugly must sound good, placing function over form.
Bill Fitzmaurice is online now
post #96 of 123 Old 01-25-2013, 01:28 PM
Jay1's Avatar
Liked: 102
Originally Posted by Face2 View Post
Measurements.
Not sure that's enough support to show it would fall on its face crossed at 2.5kHz
Jay1 is offline
post #97 of 123 Old 01-25-2013, 01:34 PM
tuxedocivic's Avatar
Quoted: 235 Post(s)
Liked: 497
Face, I'm pretty sure that's my measurement. But it's not of the tweeter that Jay proposes. That's the CSS LD25x.
I do agree however that I've done a lot of testing like that, and little 25mm domes can't take more than about 8 watts before the lines start to diverge.
For those wondering what that graph means, the blue line is an on axis measurement of the tweeter on a 12" x 12" baffle with a typical cap and coil high pass. Something like 6uF and 0.5mH, can't remember exactly. The measurement software output is reduced to -24db and my preamp is adjusted until I have 2.83V at the amp terminals. That's the blue line. I then increase the software ouput 3db at a time and measure each time. The consecutive sweeps are then overlaid by -3db, -6db, -9db, etc. What happens to most domes is what you see in the red graph. They compress above a certain point. And below a certain point the spew so much distortion they have added ouput. Very non-linear. That particular graph is -24 vs -3db. So a 21db difference. If you wanted to listen that loud (very loud), it would be a totally unacceptable tweeter imo. And it's a good little dome. Very few domes have stood up to my torture test. The SB29RDCN managed ok. Every compression driver I've done it to has performed flawlessly.
PS that little spike at 20kHz is a sound card calibration issue I've fixed.
tuxedocivic is online now
post #98 of 123 Old 01-25-2013, 01:44 PM
Jay1's Avatar
Liked: 102
We're also talking about copying a system using a dome tweeter, so it's a moot point. Thank you for the clarification though.
Jay1 is offline
post #99 of 123 Old 01-25-2013, 01:48 PM
Quoted: 235 Post(s)
Liked: 497
Well, the system uses a dome, but it's also not a run of the mill dome. It's hard to say how that dome would compare to the SS D2608, LD25x, SB29, or any other. I'd give B&W the benefit of the doubt and say it would do ok in those compression tests. I think the DIY'er would be best of loading a $500 dome into a 6" waveguide and crossing around 1750hz if they wanted to beat the B&W in performance. The tweeter really is the highlight of the 800D. IMHO.
post #100 of 123 Old 01-25-2013, 01:48 PM
ChopShop1's Avatar
Liked: 168
I think I have to agree. I like my inexpensive, powerfull amps just fine. In my listening experience, i am alwasy underwhelmed with high ticket items. As an "el-cheapo" , something must perform worlds beyond to justify some of the prices, and when they don't it dissapoints. If you set the bar low and jump over it, you look good...when you set the bar high and don't reach it, it looks very bad. That is just the way I justify my experience in my head.
ChopShop1 is online now
post #101 of 123 Old 01-25-2013, 02:02 PM
Jay1's Avatar
Liked: 102
I stopped giving hifi companies the benefit of the doubt a long time ago.
Jay1 is offline
post #102 of 123 Old 01-25-2013, 02:08 PM
Quoted: 235 Post(s)
Liked: 497
post #103 of 123 Old 01-25-2013, 02:34 PM
Liked: 1284
If you want to start at the top and work your way down I'd probably go with this for a tweeter:
http://www.parts-express.com/pedocs/specs/276-412-aurum-cantus-g3-specifications.pdf
Maybe a pair of these for midbasses:
http://www.parts-express.com/pedocs/specs/296-440-aurum-cantus-ac12050ck-specifications.pdf
And horn load one of these for the lows:
http://www.parts-express.com/pedocs/specs/296-438-aurum-cantus-ac-250sw-specifications.pdf
The 96dB sensitivity would enable you to use a nice tube amp, paid for with the money you saved versus the B&W.
post #104 of 123 Old 01-25-2013, 05:32 PM
cookieattk's Avatar
Liked: 58
im building a
1 bayma tpl-150h b/c they cost a lot
1 ae 12m possibly a very good woofer
2 Dayton Audio UM12-22 b/c they look pretty smile.gif
2 ae 18'' pr for 15-18hz tune somewhere around there depending on roomgain.
box is 16.5x25x50.5. 1.5'' mdf on all sides + bracing a seprate box for mid / highs as small as i can make it making it in a few days so i don't know for sure.
xo @ 100hz / 1200hz
hopefully 15-19khz flat 96db/1watt
also going to make the baffle for the ae12m / beyma removable and back mount every thing and make a baffle for using ae12m + a seos 24 with some ridiculously expensive cd smile.gif
all active with a $300 class d amp :0 simi diy amp and a ep4k for the subs
cookieattk is offline
post #105 of 123 Old 01-25-2013, 09:59 PM
maxserg's Avatar
Originally Posted by imagic View Post
If the material is affecting the sound in an noticeable manner, it should not be used in a driver designed to reproduce music. For a musician working with a guitar amp, distortion is their friend through and through... the point is to use different materials to add pleasing harmonics - aka distortion - to the sound. On purpose. There is no logical reason a speaker designer would choose to do the same (add a specific timbre) to a tone, if the goal is faithful music reproduction i.e. HiFi
Well said!
I understand the coice of tone with amp/speaker guitar as I'm in line with the leslie for organ sound but how can you reproduce all theese sounds! you need a transducer that will reprodure all different sounds corretly without adding it's own color!
For ezample: play a recorded voice trough a Marshall amp;) or trough a Leslie! Sound different? Why? The receipe is in the pudding!wink.gif
maxserg is offline
post #106 of 123 Old 01-25-2013, 10:03 PM
maxserg's Avatar
Originally Posted by cookieattk View Post
im building a
xo @ 100hz / 1200hz
Sounds like a recieipe for success
maxserg is offline
post #107 of 123 Old 01-26-2013, 04:38 PM
chrapladm's Avatar
Quoted: 94 Post(s)
Liked: 66
I do love my TPL-150.
Penngray a while back tried duplicating one of the 800 series B&W's. Looked really good but stopped building because other things or something. I dont recall but he had a lot of trial and error and it would be a good read if trying to build one. I like my setup better than any B&W but would prefer their construction as to mine. Much prettier. biggrin.gif
And Bill's suggestion would be an awesome setup also. I might have to try that combo.
chrapladm is offline
post #108 of 123 Old 01-26-2013, 05:25 PM
Senior Writer @ AVS
imagic's Avatar
Quoted: 969 Post(s)
Liked: 2086
Not to be too silly, but seeing how people build so many other things out of Legos, it would be funny if someone built a Lego 800D. I'm sure it's possible
Find out more about Mark Henninger at www.imagicdigital.com
imagic is online now
post #109 of 123 Old 01-27-2013, 04:53 AM
Martycool007's Avatar
Quoted: 148 Post(s)
Liked: 146
Has anyone posted a link to the measurements done on the 800D by Stereophile? If I remember correctly, the 800D did not measure that well. With that being said, I just want to point out that I find it very interesting that so many people think it sounds so good but yet measure so bad. Like I stated previously, this just goes to show that measuring flat, and sounding completely neutral without any added coloration, is not always going to sound the best when compared to speakers such as the B&W 800D, which have been voiced and designed to be pleasing to the listeners as their number one priority over just measuring flat.
I have hear many speakers that measured flat, including the Salk Songtowers, and Ascend Sierra-1's, both EQ'd flat for movies and music, and although they measure so much better than the 800D, the later still sounds like one of my favorite speakers at any price range!
Martycool007 is offline
post #110 of 123 Old 01-27-2013, 05:40 AM
Senior Writer @ AVS
imagic's Avatar
Quoted: 969 Post(s)
Liked: 2086
The Stereophile measurements came up earlier in the thread. Here's the link: http://www.stereophile.com/content/bampw-800-diamond-loudspeaker-measurements
For the most part they loved the 800D, the bump in the treble provoked a rare gripe from Stereophile: "If there was any fault to be found in the 800 Diamond, it was the revealing treble of that diamond tweeter."
My take is that the target audience for the 800D is wealthy and older so a typical buyer might have lost a bit of their high-frequency hearing and probably decorates their home with thick rugs and luxurious fabrics in addition to sound absorption panels and such, so the 'bump' was engineered into the 800D to compensate, to bring it closer to playing 'perceptually flat' to the target buyer - BTW this is pure speculation on my behalf.
post #111 of 123 Old 01-27-2013, 07:35 AM
Liked: 1284
For the most part they loved the 800D.
Show me a speaker that they panned for having an average result for an outrageous price and I'll be able to die knowing that I really have seen everything. cool.gif
post #112 of 123 Old 01-27-2013, 07:41 AM
Senior Writer @ AVS
imagic's Avatar
Quoted: 969 Post(s)
Liked: 2086
They have nice things to say about one of the cheapest speakers out there, Dayton's $40/pair bookshelf - actually on sale for $29.95 right now. Stereophile liked the Daytons enough to bless them with the usual kind words (To cherry pick for a moment): "Listening to "The Nightcaller," from Flying Lotus's excellent new Until the Quiet Comes (LP, Warp WARP230), I heard an impressively large soundstage, good image separation, and a very fine sense of momentum and flow, the up-tempo track moving steadily along with no hint of temporal distortions." - If they are willing to say that about the Daytons, I guess they would say just about anything if the speaker costs between 100-10,000X more.
post #113 of 123 Old 01-27-2013, 09:32 AM
LTD02's Avatar
Quoted: 197 Post(s)
Liked: 912
"Show me a speaker that they panned for having an average result for an outrageous price and I'll be able to die knowing that I really have seen everything."
yeah, that and all the high dollar advertisers' speakers as well.
advertising-based revenue model and objective performance assessments just don't go together. they can't.
Listen. It's All Good.
LTD02 is offline
post #114 of 123 Old 01-27-2013, 11:01 AM
Liked: 1284
+1. I once bought a Renault based on it's being named the 'Motor Trend Import Car of the Year'. I dumped it at 20k miles after replacing two clutches and a cam. Worst car I ever owned.
post #115 of 123 Old 01-27-2013, 10:15 PM
BassThatHz's Avatar
Quoted: 158 Post(s)
Liked: 330
Here is my PV horn rig vs my B&W. Listen for yourself.
It's level matched and powered by the same 1000watt amp.
Obviously a horn loaded 1.5" with two 15's is going to be more efficient than two 7" and one 1" in a Nautilus tube. But the PV sounds soo bad eek.gif it sounds like a "speaker" singing rather than a "human" singing; this is what I'm talking about. I'd rather sacrifice a little efficiency and SPL to gain that nirvana Hi-Fi sound.
If I need to entertain a crowd of drunk people needing to have their ears blasted off, that's when I use the horns smile.gif if I want to enjoy the sound, I use my B&W's smile.gif
IMO, the two speakers sound worlds apart and are clearly gear for different purposes.
You are free to draw your own conclusions of course, but this is mine, having A/B compared such systems side-by-side.
When I hear something with higher SQ than B&W 800's, I will make sure I let everyone know about it. Until then, I'm keeping my mains as-is. wink.gif
BassThatHz is online now
post #116 of 123 Old 01-27-2013, 10:49 PM
Bigus's Avatar
Liked: 50
Anyone want to explain what any of that gibberish means? What language is that anyway? And some people not only read that without spewing their tea, but actually defend the practice as well?
Bigus is offline
post #117 of 123 Old 01-27-2013, 11:08 PM
Senior Writer @ AVS
imagic's Avatar
Quoted: 969 Post(s)
Liked: 2086
Those Peavey speakers are just about the 'cheapest' sounding P.A. speakers you can buy (no offense). I am only familiar with 'that sound' from local bands playing at events. That's because they are literally cheap. Like anything else, if you spend more you can get more. A higher-end pair of EAW, EV, QSC, JBL, Mackie... they will sound better than those Peavey towers. Even so, if you were to open up the Peaveys and improve the inside of the enclosure by adding bracing and additional stuffing, you can get better sound out of them. You are listening to a lot of cabinet resonance and reflection. Have you tried putting the Peavey into your actual system with the sound absorption/diffuser treatments? I'm sure that makes a difference, too.
post #118 of 123 Old 01-27-2013, 11:31 PM
Senior Writer @ AVS
imagic's Avatar
Quoted: 969 Post(s)
Liked: 2086
Temporal Distortion: "A temporal distortion is a warp in the spacetime continuum, which can oftentimes be associated with the phenomenon of time travel. Temporal distortions can often be detected via tachyon particles, which are created as a side effect."
http://en.memory-alpha.org/wiki/Temporal_distortion
So rest assured, the Daytons do not emit black holes when playing music. Not even a hint.
post #119 of 123 Old 01-28-2013, 02:40 AM
Thatsnasty's Avatar
Quoted: 14 Post(s)
Those Peavey's aren't really a good example of what a 1.5 cd / 15 can do.
Since when does high efficiency mean that a speaker automatically is worse / not considered Hi-Fi?
Thatsnasty is offline
post #120 of 123 Old 01-28-2013, 05:53 AM
Liked: 1284
Really, you might as well be comparing a Kia to a Ferrari. Make that Peavey a Meyer of even half the price of the BW and the BW will come up very short.
User Tag List
