Subwoofer end tables? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-22-2013, 08:35 PM - Thread Starter
CleatusCat's Avatar
I just recently set up my HT room with the DTs and I still would like to see more bass. I've been thinking about 2 end tables that are really subs. I don't know if it can be done but it would be nice if nothing vibrated off the table subs as well. Any ideas?
Xbox Live- RumRiverKiller
HT Room- Samsung 550 64" Plasma, Tivo XL, Marantz SR-14 EX , BP3000TLs, CLR3000, BP2002 sides, Logitech 700
Music Room- Samsung 650 46" LCD, Tivo, Pioneer VSX-1120K , Canton GLE 409s, small cheap sub, Logitech 650
Garage- Kenwood VR606, Original Large Avents
CleatusCat is offline
post #2 of 11 Old 01-22-2013, 09:23 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2571
sure, you could do that and several folks have.
a dual-opposed design would eliminate resonances.
a bottom firing design might work too if the cabinet was nice and heavy.
it is really up to you to select how you would like the end tables to look and be constructed. if you need help choosing drivers and amplification, you'll get plenty of suggestions.
have you poked around the stickies (index and gallery threads might give you some ideas).
Listen. It's All Good.
LTD02 is online now
post #3 of 11 Old 01-23-2013, 06:43 AM
nograveconcern's Avatar
Quoted: 91 Post(s)
Liked: 128
I'm worried about stuff vibrating off tables and shelves in other rooms of the house. If you want your bowl of M&M's to stay in place on your subwoofer end table you have conflicting design goals.
You can make it D/O or down firing. Either should minimize movement. Go a bit overboard on bracing for the table top and extra weight, like a slab of granite for the top, will help too. Having a concrete subfloor will help. If it's in a room w/ a suspended floor then the floor and everything sitting on the floor will resonate.
nograveconcern is offline
post #4 of 11 Old 01-23-2013, 10:01 AM
BassThatHz's Avatar
Quoted: 2029 Post(s)
Liked: 1546
You typically need 200 to 300lbs to stop a sub from shaking; OR you could do dual-opposed which is basically a two woofer box, one on the front and on the back.
The only downside of dual-opposed is that it costs nearly double, and the box volume is slightly less than double.
Using two 12's you could make the box (probably) 13x13x20 and two 18's the box would probably be 20x20x22.
Two Dayton HO-18's and a nu3000DSP is a common solution.
BassThatHz is offline
post #5 of 11 Old 01-23-2013, 10:41 AM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
Ask archaea, the master of the ottoman sub build!
stormwind13 is offline
post #6 of 11 Old 01-23-2013, 01:55 PM
Bill Fitzmaurice's Avatar
Liked: 4628
Not at all. Leland Crooks built this combination TableTuba/CD/DVD case, and the stored CDs,DVDs and doors don't even rattle. It doesn't weigh even 100 pounds, as there isn't a piece of wood in it thicker than 1/2 inch.
Bill Fitzmaurice is online now
post #7 of 11 Old 01-23-2013, 02:42 PM
Quoted: 60 Post(s)
Liked: 96
post #8 of 11 Old 01-23-2013, 03:03 PM - Thread Starter
CleatusCat's Avatar
I like the idea of a granite slab on top of the subs. So I've been researching the dual opposing sub configuration and that looks like a good direction to go but I have another idea, how about dual subs in a box facing each other at an angle? They would be in the center of the box. The angle would be towards the floor with a vent between them at the bottom.
post #9 of 11 Old 01-23-2013, 03:06 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I went with endtables in my setup. They work great and no one even knows there are subs in them.
http://www.avsforum.com/t/935522/ebony-and-ivory-dual-18-lms-5400-endtables-completed
I orient them so that the grilles face the couch so they are not seen either, but are removable via neo magnets inside the enclosure.
You can't see the wheels in everyday use either, only when using flash photography as they shadows hide everything.
I would recommend it to anyone if you want to be inconspicuous with your setup.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is online now
post #10 of 11 Old 01-23-2013, 03:08 PM - Thread Starter
CleatusCat's Avatar
eek.gif That's beautiful
post #11 of 11 Old 01-23-2013, 03:17 PM
dbldare's Avatar
Here's one of Bill's designs. It's the Table Tuba.
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
