ep2500 wont work... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-25-2013, 12:40 PM - Thread Starter
scpete26's Avatar
My wife moved my amp now it isnt working... It powers up and the fans blow but the signal lights dont light up, i do hear a hum on one of my subs but it wont play bass... Could a fuse be blown? I have the edQ hooked up to the subs too. I cant understand why it would stop working just bcuz of it being moved
uncompressed audio is my new best friend
scpete26 is offline
post #2 of 11 Old 01-25-2013, 01:42 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 440
Sounds like it's not getting signal. Did it get unplugged from the sub out on the receiver? The sub can still hum even with no signal.
Achievement Unlocked
Psychotic Episode Averted
bass addict is online now
post #3 of 11 Old 01-25-2013, 01:52 PM - Thread Starter
scpete26's Avatar
No Ive checked all inputs and outputs, i may have been wrong about the sub humming, checked again and no hum... Could it be my xlr to rca cablecoming from the eq2?
scpete26 is offline
post #4 of 11 Old 01-26-2013, 06:52 PM
BassThatHz's Avatar
Quoted: 2042 Post(s)
Liked: 1570
Check all the dip switches and take it apart and make sure all the connections are seated firmly, and check the fuses.
The power light should work of course, and with it disconnected from the speaker and having it cranked, the signal lights should work too; otherwise it is broken and needs repair. confused.gif
It is a heavy amp and maybe she dropped it and doesn't want to tell you. wink.gif
BassThatHz is online now
post #5 of 11 Old 01-26-2013, 08:50 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
Luckily it's a ep2500 and not a lab gruppen or equivalent. Still sucks though.
stormwind13 is online now
post #6 of 11 Old 01-26-2013, 09:53 PM - Thread Starter
scpete26's Avatar
I took it apart and everything looks good but i havnt had a chance to check the fuses, ill get a hold of a volt meter tomorrow. My wife feels bad but insists she did nothing other than move it from the floor to a shelf on the tv stand.. She knows she has to replace it if we cant fix it though:), one thought i had, i think she put stress on the xlr cable that i have coming from the e2q or whaterver it is, i took the cable apart and none of the solders are broken...
scpete26 is offline
post #7 of 11 Old 01-27-2013, 01:35 AM
robertcharles's Avatar
How is this amp hooked up? Bridged or stereo? I would not take it apart before I checked each channel with a new cable and a known good speaker wire.
Keep cranking,
Robert
robertcharles is offline
post #8 of 11 Old 01-27-2013, 07:45 AM - Thread Starter
scpete26's Avatar
Stereo, i ordered another cable from monoprice to double check
scpete26 is offline
post #9 of 11 Old 01-29-2013, 07:53 PM - Thread Starter
scpete26's Avatar
I tested new cable, checked the fuses both are good, still nothing! Could it be the eq.2?
scpete26 is offline
post #10 of 11 Old 01-29-2013, 08:18 PM
Mrkazador's Avatar
Quoted: 254 Post(s)
Liked: 380
Have you tried removing the eq2 and test the amp only?
Mrkazador is offline
post #11 of 11 Old 01-29-2013, 08:19 PM - Thread Starter
scpete26's Avatar
Shoot, i messed around with the receiver settings checked the sub level and all the sudden my sub was rumbling? Weird? So now its working again. So what should my switches look like? I have the input going into input 2, the two subs are hooked to it so parallel should be on, what about the clip limiters and low cut filters?
scpete26 is offline
