A noobie with questions. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-25-2013, 01:38 PM - Thread Starter
Darrel Drake's Avatar
So I recently got a Denon AVR 3311 and I was looking at buying something and I kinda stumbled across the DIY forums and my interest peaked a little bit. I'm curious what you guys would suggest for plans for a 2.1 system focused on music, while I use my existing BIC DV62si speakers for surrounds (unless they are not worthwhile compared to what I would be building)
I currently have to fill a room that is about the size of a large closet, but if I were to build I would want something that would last once I get a bigger place. So, I'm leaning toward towers instead of bookshelves
With a budget of 1000 for the materials to build the boxes and electronics (I'm thinking I would end up casing anything I build in clear cherry/mahogany/something fun, so I guess I'll leave that cost out) what would you suggest, and what would be comparable products if I were to buy instead of building.
Darrel Drake is offline
post #2 of 2 Old 01-26-2013, 03:36 AM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Have a look at these kits
http://www.diysoundgroup.com/waveguide-speaker-kits.html
Add a 15" sub and you're good to go!
Mrkazador is offline
