tall shallow subwoofer design possible? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-26-2013, 09:06 AM - Thread Starter
goonstopher's Avatar
Quoted: 322 Post(s)
Liked: 66
Floor space is limited so I'd like to make a tall shallow subwoofer is it possible to make a 2 subwoofer sealed enclosure 48 inches tall I only 12 inches deep if the sub woofer allows it. Would it be unstable and tip over and how could you stabilize it? I've never seen a design like this
goonstopher is offline
post #2 of 8 Old 01-26-2013, 09:07 AM - Thread Starter
Quoted: 322 Post(s)
Liked: 66
I could go up to 16 inches deep
post #3 of 8 Old 01-26-2013, 09:15 AM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
To keep it stable, you can place the subwoofer as close to the bottom as you can and make the base of the cabinet a little wider than the top. Another option is to have the subwoofer down firing. If its still too top heavy, there are these nylon straps that anchor to the wall and screw into cabinets.
http://www.homedepot.com/h_d1/N-25ecodZ5yc1v/R-100124824/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=earthquake+strap&storeId=10051#.UQQPEmeZFaQ
Mrkazador is offline
post #4 of 8 Old 01-26-2013, 09:17 AM
filtor1's Avatar
Quoted: 189 Post(s)
Liked: 150
As long as you maintain the required clearance for the driver, there will be no issue. Look into a sonotube or a transmission line as an alternative for minimum floor space applications.
filtor1 is offline
post #5 of 8 Old 01-26-2013, 09:21 AM - Thread Starter
Quoted: 322 Post(s)
Liked: 66
The idea is low sight. Was going to make the baffle and depth the same as my tv stand
post #6 of 8 Old 01-26-2013, 09:29 AM
filtor1's Avatar
Quoted: 189 Post(s)
Liked: 150
Have you chosen a driver you are interested in?
filtor1 is offline
post #7 of 8 Old 01-26-2013, 09:30 AM
mtg90's Avatar
Quoted: 469 Post(s)
Liked: 923
And how wide can you go?
mtg90 is offline
post #8 of 8 Old 01-26-2013, 09:34 AM
brian6751's Avatar
Quoted: 1108 Post(s)
Liked: 1100
How about a cylinder sub then?
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
