There's a new sheriff in town! Inuke DSP 12000 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #271 of 409 Old 02-23-2014, 10:21 PM
BadmanSound's Avatar
wall voltage is not constant.. if only. voltage will sag due to low gauge wiring, long runs, etc.
your epx is probably going into protect because voltage is sagging below 90v to the power supply (causes digital amps to shutdown)
BadmanSound is offline
post #272 of 409 Old 02-24-2014, 06:34 AM
thebuckaman's Avatar
Quoted: 21 Post(s)
Liked: 80
So, eventually (when the new high power subwoofers arrive) am I stuck just plugging this thing directly into the wall? Instead of buying a super expensive surge suppression system capable of 30 amp at 120v?
Getting things ready for a new theater room build at the new house.
Equipment so far- (8) SI HT18 mini martys, speakerpower SP2-12000, Denon 4311ci (will replace), MINIDSP 10x10HD, Crown CT8150, Oppo BDP-103D, (8)JBL 8320 , (3) EV EKX12 , Crestron CP3N control system, iso clips/Roxul
TBD- Projector, AT Screen, in room acoustics,
thebuckaman is online now
post #273 of 409 Old 02-24-2014, 06:38 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Unless your area is prone to surges and brown outs, I wouldn't bother with it.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #274 of 409 Old 02-24-2014, 07:28 AM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 107
"That may be true for the speaker, but the PS has to replenish the energy taken out of the caps either way, and the wall voltage is constant so more power means more current."
I thought the high local impedance around resonance reduced the current from the amp and in turn from the wall.
12GA wire (20A circuit) is 1.6 mOhm per foot. So if you have a 100 foot round trip (50 feet each way), you have ~0.16 ohms of resistance. So @ 80A, you are dropping 12.8Volts. The worst part about starting to "brown out" is that no matter what for every Watt you put out you need to pull one watt in minimum. When your voltage starts drooping that means the current you pull in doesn't go up in a linear fashion. Here is where it gets scary; non-power factor corrected amps...the peak currents might be double or triple or even more than that! Furthermore, breaker trip curve aren't "linear" either. So the reason why some people might trip during "spirited sessions" isn't because of how much power they are putting out, it is because the AC to DC stage in their PA is ****.
Rule of thumb I have is no more than 3x pulse power for a given breaker size for a class D power factor corrected amp. For traditional (e.g. pasive front end) class A/B or B I would never go higher than 1.5:1 So, if you have a 20A breaker in the US, that means 110*20*3 = 6600W. For the people going with the iNuke 12000 seriously need to look at a 220V/20A source at a minimum. Furthermore, going to 220V manages the droop better since it is a smaller fraction of the baseline voltage.
FYI, a really good test of your wiring is to hook up an incandescent bulb in the same socket as a cheap circle saw and pull the trigger. If the bulb strongly dims, the circuit isn't really good for "pulse loads"
EDIT: Clarification on A/B comment.
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
post #275 of 409 Old 02-24-2014, 09:40 AM
Quoted: 21 Post(s)
Liked: 80
Thanks for that info. Unfortunately I ordered mine in 120VAC (US) (only option I had). I have a 30a 120V outlet being put in my theater room hoping it will do the trick.
post #276 of 409 Old 02-24-2014, 09:48 AM
andy497's Avatar
Quoted: 13 Post(s)
I have a dedicated 10/3 line (roughly 50 ft) on 30 amp breakers straight from my service box to the ht amps. Bass hits cause incandescent bulbs to dim *on other circuits in my house*!
andy497 is online now
post #277 of 409 Old 02-24-2014, 09:58 AM
Quoted: 39 Post(s)
Liked: 107
It should be enough. But if you do a NOTNYT system....it might not be. biggrin.gif Just remember to really get the most out of your outlet, you need a good power factor corrected amp.
Eeep. That is a bit scary. How much do they dim? I mean is it a "big dim" or "noticeable"? What is the breaker rating of your main panel? There could be other aspects at play here. But as for having a 30A breaker means you have 10GA wire which is ~1mOhm per foot. This puts you in a 'much better space". What amp are you using (not sure if you stated it earlier).
post #278 of 409 Old 02-24-2014, 02:11 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
That's true of the woofer/box resonance, but at higher freq I believe the higher impedance means less current/less power.
But that's besides the point of power is power.
Then it must be drop across the lines feeding your service entrance.
You could try asking the power company to replace them.
Noah
noah katz is offline
post #279 of 409 Old 02-24-2014, 02:41 PM
andy497's Avatar
Quoted: 13 Post(s)
Eeep. That is a bit scary. How much do they dim? I mean is it a "big dim" or "noticeable"? What is the breaker rating of your main panel? There could be other aspects at play here. .
It's an old house with old wiring and wimpy service. Not big dimming, but you can see them pulse slightly to music when I have everything cranked. Amps are an inuke nu4-6000 on mains and not working too hard, inuke 6000 and ep4000 on subs and being driven balls out.
Hrm... Wow. I think I'll be content. It's a pretty cool party trick.
post #280 of 409 Old 02-24-2014, 03:07 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
Noah
post #281 of 409 Old 02-24-2014, 05:27 PM
Bob7145's Avatar
Liked: 36
My electric bill dropped considerably after running new copper lines and circuit breakers to my "Heavy Breathers". I remember the Living Room ceiling light pulsing the the beat of whatever music was playing.
Bob7145 is offline
post #282 of 409 Old 02-27-2014, 04:13 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Inuke 12000DSP now showing as in stock and ready to ship at bhphotovideo.com!!!
Swolephile is offline
post #283 of 409 Old 02-27-2014, 05:46 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Joe = LFE Addict
jpmst3 is offline
post #284 of 409 Old 03-06-2014, 11:13 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
"But that's besides the point of power is power."
at resonance in the enclosure power drops dramatically for the same spl. that's all i was getting at.
large ported cab, impedance.
low pass filter, high pass filter, power follows inverse of impedance.
this is with "2200 watts". at resonance, around 30hz, almost no power is consumed.
Listen. It's All Good.
LTD02 is offline
post #285 of 409 Old 03-07-2014, 10:30 AM
zeus33's Avatar
Quoted: 1335 Post(s)
Liked: 996
1k for a 12000? Why not buy 2 6000s for $760 and save $240?
zeus33 is online now
post #286 of 409 Old 03-07-2014, 10:36 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
They won't suffice if you need 2 ohm capability.
Joe = LFE Addict
jpmst3 is offline
post #287 of 409 Old 03-07-2014, 11:35 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Yep.
post #288 of 409 Old 03-07-2014, 01:50 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
If the 2 ohms comes from two paralleled 4 ohm coils, you could biwire.
jpmst3 likes this.
Noah
post #289 of 409 Old 03-07-2014, 02:05 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
Maybe a little OT, but i was discussing this the other day and didn't find the answer. If you have a dual voice coil woofer and a two channel amp. Can you the run the amp in parallel mode with each channel into each coil of the woofer? If yes the how do you figure out the TS spec if only the spec for parallel coupled coils is given and what power do you put into the model. Sorry if these Qs might seem too simple but DVC is really all new to me and id rather ask than get it wrong.
splotten is offline
post #290 of 409 Old 03-07-2014, 02:15 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Good point Noah!
Joe = LFE Addict
jpmst3 is offline
post #291 of 409 Old 03-07-2014, 02:26 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
I'd take the easy way out and and just pretend it's driven by one amp with twice the power.
Noah
post #292 of 409 Old 03-07-2014, 11:32 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
OK thanks. Sounds easy enough.
splotten is offline
post #293 of 409 Old 03-18-2014, 12:10 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Inuke 12000DSP is now available at americanmusical.com. You can also purchase it on a five month payment plan consisting of five $200 payments.
post #294 of 409 Old 03-19-2014, 07:05 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Several other sites have it as well. The problem is that the MAP is $999. So, you need to work directly with a dealer to negotiate any lower. I know for a fact that it can be had for a couple hundred less.
At $999 I am not sure it is worth it.
Joe = LFE Addict
jpmst3 is offline
post #295 of 409 Old 03-19-2014, 10:46 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
I agree. But if it at least puts out 3 kilowatts @ 4 ohms, I would take it over a clone amp.
post #296 of 409 Old 03-19-2014, 12:01 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Ya, but I doubt it would. I would suspect more like 2300-2400 at 4 ohms. I think you can safely take any figures they give and take 70% of that for a closer to real world figure...Roughly 50-60% of what a clone would do.
Still not bad though, better at $800. There are better choices over that price, at least IMO.
Scott Simonian likes this.
Joe = LFE Addict
jpmst3 is offline
post #297 of 409 Old 03-19-2014, 12:05 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
So you believe it only puts out 3-400 watts more@ 4ohms than what the Inuke 6000 does?
post #298 of 409 Old 03-19-2014, 12:15 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yes, because that is all it is rated at.
The 6000 is spec'ed at 3000w x 2 at 4 ohms and puts out around 2000w. So, if the 12000 is rated at 3400w....
Joe = LFE Addict
jpmst3 is offline
post #299 of 409 Old 03-19-2014, 12:17 PM
steve nn's Avatar
Liked: 433
Seems logical..
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #300 of 409 Old 03-19-2014, 12:35 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Originally Posted by steve nn View Post
Seems logical..
Yes, but one never knows for sure. We will see soon enough when tested.
Joe = LFE Addict
jpmst3 is offline
