There's a new sheriff in town! Inuke DSP 12000 - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #391 of 409 Old 06-07-2015, 04:52 AM
Stereodude's Avatar
Quoted: 3453 Post(s)
Liked: 2523
Oops, didn't realize there was a 4 channel 6000 and a 2 channel 6000.
Stereodude is offline
post #392 of 409 Old 06-07-2015, 06:19 AM
More is Better's Avatar
Quoted: 620 Post(s)
Liked: 344
I don't think hardly anyone uses it, it doesn't come with dsp. But that's the one that Not tested.
This seemed to be a good test.
http://forum.speakerplans.com/behrin...opic69202.html
More is Better is offline
post #393 of 409 Old 06-07-2015, 09:10 AM
Stereodude's Avatar
Liked: 2523
Originally Posted by More is Better View Post
A well done test, but largely useless to anyone living in a 120V country.
post #394 of 409 Old 06-07-2015, 09:19 AM
Stereodude's Avatar
Liked: 2523
He tested what someone sent him. If you want to see the 2 channel DSP model tested, send him one.
post #395 of 409 Old 06-07-2015, 01:38 PM
notnyt's Avatar
Quoted: 2790 Post(s)
Liked: 2569
Keep in mind I was testing with all channels driven. when I tested with only one, the power was higher. I need to setup a graphing system for my results. I also have results from testing only one channel. Basically the nu4-6000 has barely any burst capability, and it's around 60-63 percent efficient in the bass regions. The max draw that amp is capable of from my testing is 36a. Any more and it shuts down, so you can do the math there for max sustained output. Burst was slightly higher but only like 1db or so.
My test load is configurable for 2.2, 4.4, or 8.8 ohms.
notnyt is offline
post #396 of 409 Old 06-07-2015, 01:48 PM
Quoted: 620 Post(s)
Liked: 344
I already helped with sending him the EP4000. That's the one I was interested in seeing results for. I'd like to see the cv-5000 tested too.
The inukes are interesting to read about but I couldn't imagine ever owning one. I'm happy with my heavy amps.
I really just wanted to point out that 2 things that weren't the same were being talked about as if they would definitely perform identically.
In my last post I was simply pointing out why you wouldn't have heard of the 4 channel inuke and why Not's testing may not apply to the majority of the 6000 users. It seems like 1 in 50 people bought that one.
post #397 of 409 Old 07-31-2015, 08:54 AM - Thread Starter
Archaea's Avatar
Quoted: 3086 Post(s)
Liked: 2711
Has this had any additional testing that anyone has run across? I read the initial results of the test with Speakerpower's owner weren't terribly exciting. Behringer blamed it on a firmware bug as I recall, and then retest was similar.
Archaea is offline
post #398 of 409 Old 07-31-2015, 09:29 AM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
@Archaea
fwiw, i haven't seen anything.
Listen. It's All Good.
LTD02 is offline
post #399 of 409 Old 08-20-2015, 09:10 AM
ericnhitterdal's Avatar
Quoted: 31 Post(s)
Liked: 27
Any other updates on this?
I'd like to see the Behringer 12kdsp tested and also the CV-5000
saginawjuggalo likes this.
ericnhitterdal is offline
post #400 of 409 Old 08-20-2015, 08:24 PM
johnson636's Avatar
Quoted: 406 Post(s)
Liked: 155
I'm in that club as well. I believe it's still $100 cheaper to buy 2 inuke6kdsp than it is to buy one 12kdsp
johnson636 is offline
post #401 of 409 Old 08-20-2015, 09:00 PM
LTD02's Avatar
Liked: 2888
@johnson636
some folks want/need more power than the 6000 has per channel. the 6000 can't be bridged and is only rated for 4 ohms per side, so that kind of limits it for some applications.
LTD02 is offline
post #402 of 409 Old 08-21-2015, 05:57 AM
johnson636's Avatar
Quoted: 406 Post(s)
Liked: 155
Got it. I was just pointing that fact out on a pure price basis.
post #403 of 409 Old 12-11-2015, 08:17 AM
DrDyna's Avatar
Quoted: 120 Post(s)
Liked: 81
Has anyone tested one of these yet?
DrDyna is offline
post #404 of 409 Old 12-11-2015, 11:43 AM
stitch1's Avatar
Quoted: 323 Post(s)
Liked: 265
Can't say that I've tested it but I run one pretty much daily. It makes my subs go boom boom boom.
DrDyna likes this.
stitch1 is offline
post #405 of 409 Old 12-14-2015, 02:07 PM
kcnitro07's Avatar
Quoted: 12 Post(s)
loan me your nu12000...I wanna see if its drives my LMS 5400s harder than my EPX 4000s....the behringer ratings say it shouldn't.....
3400 max @ 4 Ohms x 2 for the NU12000
My EPX is bridged mono rated at 4000 max....
I dont know the RMS numbers of the NU12000, but the "rated" RMS for my EPX is 3000....curious.....
kcnitro07 is offline
post #406 of 409 Old 12-14-2015, 04:02 PM
stitch1's Avatar
Quoted: 323 Post(s)
Liked: 265
I would assume there wouldn't be much difference. other than having a second channel and the DSP. Output wise they should be close. Your EXP might even have the edge. I would think the 12k would be somewhere between 2200 to 2700 rms x2 at 4ohm judging by the other nukes.
stitch1 is offline
post #407 of 409 Old 12-14-2015, 10:16 PM
Quoted: 109 Post(s)
Liked: 37
I'm thinking of trying a bridged pro-lite 3.0. Bet it delivers more at 4 ohms than a single channel of inuke 12000 at 4 and maybe 2 ohm. Bet that 2 pro-lites 3.0 would not shut down before a 12000 does.
I just can't find real measured reviews i can trust of a pro-lite 3.0 yet, bridged or otherwise.
I like my inuke 3000dsp though! Huge bang for buck.
cellarnoise is offline
post #408 of 409 Old 12-14-2015, 10:59 PM
Ketnis's Avatar
Quoted: 173 Post(s)
Liked: 88
That's a lot of assumptions about an amp with very similar architecture and lower rated output. Is there a reason you think it's that much better, or is it more of that tired "Behringer iNuke? More like Budgeter iPuke lolololol" smugness?
Ketnis is offline
post #409 of 409 Old 12-15-2015, 06:28 AM
stitch1's Avatar
Quoted: 323 Post(s)
Liked: 265
Bridged at 4ohm the crest might have a bit more power than each channel of the 12k at 4ohm. The 12k at 2ohm should be good for over 4000 watts RMS per channel. I don't think the crest can match that and the inuke would still have a second channel.
For my current application I would be hard pressed to shut the iNuke down. If you like the 3000dsp than you would like the 12k. It's basically the same amp just with a lot more power.
stitch1 is offline
