Newbie wanting some help on a center channel and diapole surrounds - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 01-29-2013, 08:00 PM - Thread Starter
bcharlsen's Avatar
looking for a good clear sounding center channel DIY idea. i don't want a huge center channel. i wouldn't mind around a 3" or 4" driver. also something i can put my TV on too.
i really would like to build a good pair of DIY diapole surrounds. something i can load the corners of my main room with. I have no idea how to build a good crossover and or components to buy for a crossover. i am just after a low dollar budget build with a good result. all help would be amazing. ideas, pictures, other speaker builds. that would be amazing!!
bcharlsen is offline
post #2 of 21 Old 01-29-2013, 08:20 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
Give us some dimensions on how big you want the speaker cabinet.
Mrkazador is offline
post #3 of 21 Old 01-29-2013, 08:36 PM - Thread Starter
bcharlsen's Avatar
ohh something that will fit in the corner of family room. either a 6.5 inch or 5 inch driver. that is for the surrounds. and maybe around 24inches wide by 12inches deep. some help would be awesome
post #4 of 21 Old 01-30-2013, 02:44 AM
domanskipaul's Avatar
I think the term "low cost" is relative. It might be $150 for me, but $500 for you...
I personally don't have any experience building anything like what you're looking for, but some good resources are:
http://speakerdesignworks.com/index_page_2.html
http://www.parts-express.com/project-gallery/speaker-projects/
If you don't have much experience with speaker or crossover design you'll probably want to use an existing set of plans instead of designing your own.
Also, if you decide not to build, there are some pretty decent centers out there at the size you're looking for, for about as much if not less than what it would cost to build one.
If you decide to build, keep us updated! I'm sure someone who is more knowledgeable on the topic will chime in.
domanskipaul is offline
post #5 of 21 Old 01-30-2013, 02:53 AM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
post #6 of 21 Old 01-30-2013, 09:46 AM - Thread Starter
bcharlsen's Avatar
well I am looking for like a surround build to be around 150 bucks or less. also the center channel to be less then 100. I already have wood and the know how to build cabnits. again any help would be great!
post #7 of 21 Old 02-01-2013, 01:32 PM - Thread Starter
bcharlsen's Avatar
I am thinking about using the zaph audio za5.3c center channel and za5.3 tower speaker designs. now would I have to use the same drivers that he used it.can I snag some on sale at parts express?
post #8 of 21 Old 02-01-2013, 01:35 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
You have to use exactly what is shown in the plans.
Madisound has some Zaph kits
http://www.madisoundspeakerstore.com/zaph-audio/
post #9 of 21 Old 02-01-2013, 01:46 PM - Thread Starter
bcharlsen's Avatar
so it wouldn't help if i bought an other speaker with almost the same specs?
post #10 of 21 Old 02-01-2013, 01:59 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
No, the speaker was designed and measured with those specific drivers.
post #11 of 21 Old 02-01-2013, 04:53 PM - Thread Starter
bcharlsen's Avatar
well damn that sucks!! is there a design that is around the same sepcs as those two that i can use a different driver in??
post #12 of 21 Old 02-04-2013, 11:10 AM - Thread Starter
bcharlsen's Avatar
is there a way i could buy a in-wall speaker and then build a cabnit around it to fit it?? or would it sound like crap?
post #13 of 21 Old 02-04-2013, 12:03 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
Depends on the design, I think some allow you to use an enclosure but they are designed to be in wall only.
post #14 of 21 Old 02-04-2013, 10:03 PM - Thread Starter
bcharlsen's Avatar
well dang!! no fun! i wish it was a little easier
post #15 of 21 Old 02-04-2013, 10:47 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
You can't customize these designs on how you want. Unless you have calibrated measuring gear and an understanding of speakers/crossovers...
post #16 of 21 Old 02-05-2013, 11:46 AM - Thread Starter
bcharlsen's Avatar
well since everyone here knows a whole lot more then i do. if i gave you all a speaker style and then what drivers i wanted to use. could someone on here help me with a cross over???
post #17 of 21 Old 02-05-2013, 02:10 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
I don't know anything about crossovers and designing speakers but I do know its not that simple so you may not get any replies.
post #18 of 21 Old 02-05-2013, 03:35 PM
mobeer4don's Avatar
Quoted: 123 Post(s)
Liked: 117
The same guys that can design a really good crossover are also good at picking drivers that are good at what they want them to do for a particular design. You will save much time (and $, probably) if you follow a proven design.
Hint - many of the bargain drivers at Parts Express are cheap for a reason....and it ain't because they are real easy to use or the best performers.
Not trying to be a downer.
Good luck!
mobeer4don is offline
post #19 of 21 Old 02-07-2013, 03:56 AM
maxcooper's Avatar
Quoted: 13 Post(s)
Think about it as needing to find a speaker design that uses inexpensive drivers, rather than starting with inexpensive drivers and trying to find a design to use them in.
However, in direct contrast to the advice i just gave :-), Parts Express has those nice Aura ns6 woofers for $9. And there are various designs that use them -- the Stentorians are one design, and there are a few others floating around on diysoundgroup.com.
Building speakers is still quite fun, even when you are limited to building other peoples designs. biggrin.gif
-Max
maxcooper is offline
post #20 of 21 Old 02-07-2013, 02:52 PM - Thread Starter
bcharlsen's Avatar
So would my pick if driver and tweet be ok in other designs?? or am I just SOL? I am more worried about sq not spl. some extra help would be great
post #21 of 21 Old 02-09-2013, 06:36 AM
maxcooper's Avatar
Quoted: 13 Post(s)
The drivers are a key part of any design. You can't swap in other drivers.
Designing crossovers involves building, listening, measuring, and tweaking. It is unlikely that you'll be able to get someone to do that for you just so you can use some cheap drivers. A person with those skills is going to work on projects that they find interesting. Saving you a few bucks isn't interesting.
Also, be aware that crossovers can be a significant part of the cost of building a speaker. And lousy drivers often need expensive crossovers. A driver that looks like a bargain may not be once you build a crossover for it. That might be one reason that you don't see a lot of DIY speaker designs for every cheap driver out there.
You aren't SOL; you just need to change the way that you approach speaker building. If that feels too constraining, get over it. Focus on the possibilities rather than the limitations. There are tons of excellent designs out there.
Here are some more ideas (and I know that I am sort of ignoring your size requirements, but I think it's good to look outside your initial constraints a little bit):
* There's a speaker design on this $15.50 "tweeter" product page that uses the $9 Aura NS6 woofer that I mentioned:
"tweeter" http://www.diysoundgroup.com/drivers/tweeters/dna-10.html
woofer http://www.parts-express.com/pe/showdetl.cfm?partnumber=299-030
* Madisound kits:
http://www.madisoundspeakerstore.com/2-way-speaker-kits/
* "Stentorians" with lots of those NS6 woofers:
http://speakerdesignworks.com/NS6project_1.html
* Several small, budget-friendly designs in the threads here:
http://www.diysoundgroup.com/forum/index.php?board=20.0
* This design requires some fancy woodworking, but it uses inexpensive drivers, and has some cool audio properties:
http://www.diysoundgroup.com/forum/index.php?topic=19.0
Now, with all due respect, quit whining and get back to planning your speaker build. biggrin.gif It's going to be fun.
-Max
