TD12X SEOS Tower Speaker Build - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 325 Old 06-01-2013, 09:25 PM
brian6751's Avatar
Quoted: 885 Post(s)
Liked: 678
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #302 of 325 Old 06-01-2013, 09:27 PM
antisuck's Avatar
Quoted: 98 Post(s)
Liked: 141
Oh I didn't mean I thought you should leave them as is, although my twisted evil mind did think for a moment of cheap (cheesy) wood-grain vinyl wrap and a pair of thrift shop grill badges that say "Fisher" or something similar. Then watch your guest's faces as you crank it up. wink.gif
Piano black is going to be killer.
antisuck is offline
post #303 of 325 Old 06-01-2013, 09:40 PM - Thread Starter
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
I actually do have old Fisher speakers in the attic. I really should see if I can remove the baffle and install a SEOS kit into it. Would be hilarious and retro.
bhazard is offline
post #304 of 325 Old 06-02-2013, 04:56 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
LoL @ you guys. That piano black finish is going to look sooo good on there! How are you liking them so far?
Martycool007 is offline
post #305 of 325 Old 06-02-2013, 09:35 AM
antisuck's Avatar
Quoted: 98 Post(s)
Liked: 141
bhazard, any plans to add a center down the road? I realize after seeing your pics that would entail ripping apart your stand/equipment rack and doing something completely different there, but comments made so far make it sound like a good center would really push your movie watching experience to the next level in terms of dialog clarity and such.
antisuck is offline
post #306 of 325 Old 06-02-2013, 09:59 AM - Thread Starter
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
Originally Posted by brian6751 View Post
Yes... blank............. or home videos.....
They're amazing. I haven't even broke 100db yet, and that is plenty for the room. They can do 122 if I wanted.
Not with that current stand. The top shelf is the only one that can hold the XPA-5. Down the road if I change the stand or move, I'll build the SEOS center that is coming out.
As far as cloaked voices, I don't really hear them anymore. I've come to realize its because I'm missing Dynamic EQ having Trinnov, running at -15, and I never use dynamic compensation/compression. There really isn't a need for a center at all. Running at reference gets really stupid loud and pisses everyone off around me.
bhazard is offline
post #307 of 325 Old 06-02-2013, 10:08 PM
NWCgrad's Avatar
Quoted: 1233 Post(s)
Liked: 1227
That would be cool...a new Econowave build (sort of).
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is online now
post #308 of 325 Old 07-18-2013, 01:29 PM - Thread Starter
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
"Mini" versions! Some crazy powerful surrounds right there.
bhazard is offline
post #309 of 325 Old 07-19-2013, 10:54 PM - Thread Starter
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
bhazard is offline
post #310 of 325 Old 07-20-2013, 10:51 AM
filtor1's Avatar
Quoted: 77 Post(s)
Liked: 78
Those grills look awesome!
filtor1 is online now
post #311 of 325 Old 07-20-2013, 10:57 AM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Fantastic.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #312 of 325 Old 08-01-2013, 11:53 AM
joeybutts's Avatar
Everything good mang?
joeybutts is offline
post #313 of 325 Old 08-02-2013, 06:19 PM - Thread Starter
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
All is well. Haven't had time to hook them up yet, but I will this weekend.
I see some full range, double bass tower and surround action in the near future. Why buy more 18s when I now have 4 12s also in the room. lol
bhazard is offline
post #314 of 325 Old 09-09-2013, 02:57 AM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
Hi guys, I'm very interested to DIY build 3 units of this TD12X SEOS Tower (similar to this build) as my LCR, the only difference is build it in two 12" or 15" woofers instead of one woofer? anyone can kindly please advise & guide me are there any changes needed on the crossover, bracing & the design of the speaker cabinet?
WereWolf84 is offline
post #315 of 325 Old 09-09-2013, 05:53 AM
Quoted: 280 Post(s)
Liked: 176
Although I recommend starting your own thread, I will try to answer your questions.
Yes, if you go with duel 12's or duel 15's in the Seos based designed, you will certainly have to modify the crossover, but how much I can not say as I am not sure if it would make all that much difference in the crossover.
The cabinet will certainly have to be modified. Most people order the baffles pre-cut from DIYSG, but if you are planning on adding another woodfer, you will have to make a baffle that will hold two woofers. You might try asking Erich if he could make you a custom baffle on the CNC machine that he uses.
Hope that helps!
post #316 of 325 Old 09-09-2013, 06:15 AM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
Thanks & appreciate it, but the OP didn't show how's the internal bracing looks like for this speaker design
post #317 of 325 Old 09-09-2013, 08:34 AM - Thread Starter
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
There are a few pics of the bracing in the shots. I didn't cut the bracing so Joey would have to go more into detail.
Another update, I had to flip wires on the CD, as the crossover design has reverse polarity. The speakers were tested and run for over a month with the CD in reverse!! The "veil" that JB mentioned was immediately lifted once I did this. Would have loved to retest these and the Khans now that they are wired correctly.
I also added an Inuke NU4-6000 to replace my XPA-5 and EP4000. It is now running these speakers AND my 2 subs. Works great.
bhazard is offline
post #318 of 325 Old 09-09-2013, 12:37 PM
joeybutts's Avatar
A retest would be great! Should have figured it was that now that we know. Makes absolute sense having a suckout like that.
There is no real magic to bracing, I just try my best to allow air to move while really hitting the mid lines of the panels. Also don't want to obstruct the port opening. Using the birch helps quite a bit as well.
Vin, what did you do with both units now that they are replaced with the iNuke? biggrin.gifbiggrin.gif
post #319 of 325 Old 09-09-2013, 12:45 PM - Thread Starter
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
The XPA-5 is sold, and the EP4000 will be up for sale soon.
bhazard is offline
post #320 of 325 Old 09-14-2013, 09:21 PM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
Bhazard,
any updates of your impressions & reviews after some break in time for both HT & 2 channel music duties?
post #321 of 325 Old 09-15-2013, 11:49 AM - Thread Starter
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
Bhazard,
Unless you buy a Seaton Catalyst or JTR Noesis for quite a bit more $$, nothing can touch a SEOS kit in value/performance right now. This kit has the ability to play full range with 0 issues, and handles more power than the average SEOS kit.
It is the best speaker I've heard by far in the price range.
bhazard is offline
post #322 of 325 Old 09-15-2013, 12:39 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
i agree with bhazard, the performance per $ spent is pretty unmatched across all the SEOS designs
bhazard i may have asked this before but why are these towers tuned to?
Sibuna is offline
post #323 of 325 Old 09-15-2013, 01:50 PM - Thread Starter
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
32-34hz. They can play as deep as a BIC F12 sub if you want them to, which makes them great space savers/apartment speakers as long as you keep the volume down. Crank them up, and no apartment/condo association will keep you around. lol
bhazard is offline
post #324 of 325 Old 11-13-2013, 02:06 PM
Ashiyatl's Avatar
Ordered the TD12Xs.
I feel like DIY is the way to go. There may be huge advances or price drops in quality compression drivers for these designs within the next few years. I always see JTR crossovers being upgraded, so I could see a Noesis quality SEOS happen within the next few years.
Did you use the 4ohm or 8ohm version of the TD12X?
Ashiyatl is offline
post #325 of 325 Old 11-13-2013, 02:35 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2828
beastaudio is online now
