$200 sub DIY - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 01-31-2013, 03:49 PM - Thread Starter
IslandStylin's Avatar
Hey everybody!
SO I know everyone on here has been asked multiple times in the past threads, but I wanted to get new opinions on what sort of driver and amp you would purchase for a 1600 sqft room?
I am a complete noob. The first sub I had built was by a friend. This time I want to give it a go. If I am unable to build a better sub than the JBL 150P or Bic F12 for under $200, I might as well just buy one of those. Sadly that is all my budget will allow me to spend. This includes the stuffing and MDF board.
All thoughts and advice are very appreciated.
IslandStylin is offline
post #2 of 18 Old 01-31-2013, 04:39 PM
SULLY12's Avatar
Do you have a amp?
SULLY12 is offline
post #3 of 18 Old 01-31-2013, 04:40 PM
SULLY12's Avatar
try a infinity 1260w and a dayton 240 amp that might leave you some for materials.
SULLY12 is offline
post #4 of 18 Old 01-31-2013, 04:49 PM - Thread Starter
I have nothing. I even have to borrow the appropriate tools. Yes, this budget might be too ridiculous to do better than the 2 subs I can buy. Agreed? Or is it possible? =)
post #5 of 18 Old 01-31-2013, 04:57 PM
SULLY12's Avatar
In a correctly tuned ported design the sub and amp above will stomp the subs you listed.
SULLY12 is offline
post #6 of 18 Old 01-31-2013, 04:59 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
save your money and buy something worth spending money on imo
cookieattk is offline
post #7 of 18 Old 01-31-2013, 05:22 PM
Point Source
beastaudio's Avatar
Quoted: 3545 Post(s)
Liked: 2851
where are you located? Scouring the used ads, you might find something alright smile.gif starting with $200 for a DIY is a little low unless you had an amp already, in which case we could find something decent for ya. As cookie said, if we could just work with maybe $400 we would have several options!!!
beastaudio is offline
post #8 of 18 Old 01-31-2013, 05:33 PM
SULLY12's Avatar
You could save up but with a little reserch and effort you can build a pretty decent sub out of the stuff above. Its easy for someone to say spend more but some of us have budgets and are trying to squeeze as much as we can out of it.
SULLY12 is offline
post #9 of 18 Old 01-31-2013, 05:37 PM - Thread Starter
Sully is right on with his comment. I would love to save up more, but I honestly don't want to wait any longer. I have gone long enough without a SUB and it's been pretty painful to say the least.
Don't have anything. No driver, no amp, no mdf, no stuffing, no glue...no tools. Though I know I can borrow the tools with no problem.
I live in Los Angeles. Any specific places to scour for audio besides craigslist?
post #10 of 18 Old 01-31-2013, 05:41 PM - Thread Starter
What software program would you recommend to figure out the exact design? Perhaps I am getting in way over my head. Just thought it could be a fun project, plus I would be getting a kick a#s sub out of it
post #11 of 18 Old 01-31-2013, 05:43 PM
SULLY12's Avatar
I did not mean to take anything away from the people who have the crazy sytems with multiple 15 and 18 inch subs. If i could i would do the same and it gives me somthing to look up to and admire. its just that I have been seeking the most bang for my buck after spending too much for my current sub and now realize that if i go diy i can come out with way better performance for my budget.
To the ts you really should google the 1260w and see what is possible.
SULLY12 is offline
post #12 of 18 Old 01-31-2013, 05:44 PM
SULLY12's Avatar
winisd.
SULLY12 is offline
post #13 of 18 Old 01-31-2013, 05:49 PM
Point Source
beastaudio's Avatar
Liked: 2851
Running 8 SI 18's but I didn't take any offense to your comment biggrin.gif I know the point you were getting across, my suggestion was purely due to the fact that with a little more saving and painful waiting, with a $400 budget the possibilities are much better that we could get a MUCH more capable sub out of it. On the other hand, get the 1260, and the 240 watt plate amp, build out a nice ported box, and then when the next $200 come around, you could build another one if you aren't happy smile.gif that is basically how i got where I am right now, just found deal after deal after deal until I had made enough off of previous equipment sales to afford what I have. I don't usually purchase unless I have something going out the door. With that said, I have so much overstock in stuff right now it isn't even funny biggrin.gif
post #14 of 18 Old 01-31-2013, 05:55 PM
SULLY12's Avatar
Cool man. do you have any drivers for sale?
SULLY12 is offline
post #15 of 18 Old 01-31-2013, 06:29 PM
kmannth's Avatar
Funny. DIY can be very cheap. You don't need a 1000 watts or $500 driver to beat a crappy $200 sub.
Low wattage with a big box can be a decent bass for very modest costs.
You will have to do work do under $200 but it is quite doable.
Buy a cheap used plate amp (what do you think is in the BIC?). Some basic HTIB plate amps can be 100 watt. Ebay is your frined. Don't spend more than $50 (you said something about "old sub", maybe that amp).
Learn to model drivers. this is free learn what it all means you probably want to port for output. Start with Dayton Audio DCS305-4 or a pair of SD270A-88.
Find a driver under 90$ that will work. The driver in the $200 sub is worth less than $40.
Use the rest of the money to build the right proper sub you modeled. It won't be pretty unless you are a real carpenter but it is very doable.
kmannth is offline
post #16 of 18 Old 01-31-2013, 06:46 PM
mobeer4don's Avatar
Quoted: 123 Post(s)
Liked: 117
Another option is to do some serious shopping for used subs. With a little luck, you might find a damn decent one for dirt cheap that needs a little work.
mobeer4don is offline
post #17 of 18 Old 01-31-2013, 08:33 PM
Point Source
beastaudio's Avatar
Liked: 2851
yep, PM me if interested, I already have gotten slapped on the hand once for talking about it outside the classifieds, why, I don't understand but forum rules say I can't.
post #18 of 18 Old 02-01-2013, 03:53 PM - Thread Starter
Do you guys know of any DIY videos from start to finish? Seeing as I am new and more of a visual learner. Plus having such a tight budget I don't want to screw up too badly.
Can anyone recommend any more drivers I should keep my eye on besides the Infinity mentioned above.
