Is it damaging to clip an amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 72 Old 02-01-2013, 11:48 AM - Thread Starter
apnea's Avatar
I have a Crown xls 1000, wired 2 ohm stereo, to a pair of subs. I have the soft clip on, and run my receiver hot, and clip the amp fairly often when I'm 'playing'.. is that a bad thing to do to the amp? The subs don't mind the abuse, and the soft clip makes me think that it's not an issue for the drivers, but I'd hate to fry my amp.
I know I could run it cooler, but it's fun to push the limits of the subs, especially given they cost so little...
apnea is offline
post #2 of 72 Old 02-01-2013, 12:37 PM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1771
So long as you keep them cool, they should be OK.
A quibble, though: if the subs cost so little that you don't mind destroying them, then I have to question the quality of the sound they produce.
Selden
Selden Ball is offline
post #3 of 72 Old 02-01-2013, 12:52 PM
Bond 007's Avatar
Quoted: 2662 Post(s)
Liked: 2113
Licence to Kill
Bond 007 is online now
post #4 of 72 Old 02-01-2013, 01:02 PM - Thread Starter
apnea's Avatar
Ha, a fair point. They are a pair of infinity drivers that cost me $67 each. I'd be upset at destroying them, but much less so than if they cost $400 each. The cheapness makes me less cautious, or at least more experimental, I think it'd be fair to say.
apnea is offline
post #5 of 72 Old 02-02-2013, 06:46 PM
BassThatHz's Avatar
Quoted: 2391 Post(s)
Liked: 2167
Hard clipping would be a very bad thing, soft-clipping not so much...
As long as the both stay cool it should be OK.
It's not really a good thing for either of them, and will shorten the lifespan of them both. By how much exactly? Only god knows that.
BassThatHz is offline
post #6 of 72 Old 02-02-2013, 06:49 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
It is best to avoid it as much as possible, that's why we build in headroom.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #7 of 72 Old 02-02-2013, 07:08 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Not at all. Guitar amps are always clipped, and never damaged by it. And there's nothing special about them to allow that. But with subs it won't sound good, especially with SS.
It can be catastrophic to drivers too
Tweeters yes, midranges sometimes. Woofers and subs, never.
Bill Fitzmaurice is offline
post #8 of 72 Old 02-03-2013, 04:51 AM - Thread Starter
apnea's Avatar
Thanks for the replies. It's rare that I clip the amp just during regular music or movie viewing. I try and make sure my gain structure limits it, but sometimes you've got to find out what a clip sounds like at war volume. To Bill's point, it doesn't sound great either. The amp doesn't get hot - it's rare that the fan even comes on.
apnea is offline
post #9 of 72 Old 02-03-2013, 05:08 AM
Theresa's Avatar
Liked: 51
True. I have, when I was a youth, burned out a tweeter by clipping. Woofers/subs will not be damaged by clipping but can be damaged by over excursion (not clipping) and overheating (thermal overload). I'm certain you know all this.
Theresa is offline
post #10 of 72 Old 02-03-2013, 07:04 AM
Liked: 5687
We should, but the myth of under powering just won't die. It's not referenced often here, on musical instrument and pro-sound forums it pops up with surprising regularity from people who should know better.
post #11 of 72 Old 02-03-2013, 10:17 AM
JDEaston's Avatar
I agree with you, but since thermal overloading and over excursion can be a direct result of hard clipping shouldn't it be said that clipping could damage a woofer if one doesn't hear it and know when to back off?
JDEaston is offline
post #12 of 72 Old 02-03-2013, 10:40 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
It isn't damaging until it is. It is real simple, avoid it and you won't worry about it.
Joe = LFE Addict
jpmst3 is offline
post #13 of 72 Old 02-03-2013, 10:48 AM
N8DOGG's Avatar
Quoted: 1117 Post(s)
Liked: 1221
As long as the driver can thermally take the power, you can clip your amp all day long and it's not going to hurt anything. The DC current is the tweeter killer. I just recently blew 2 x sI 18's with less than 1000 watts power. I was using the dayton 1000 plate amp on both and both went up in smoke. was it clipping? probably, theres no reason the SI should have crapped out in 3CF boxes with 1000 watts. Both coils were smoked. I can't think of any other reason they would crap[ out as both amps still work perfect on my UXL's. Turn them up the same deal and they clip all day long and the UXL's just laugh at them.
N8DOGG is offline
post #14 of 72 Old 02-03-2013, 11:23 AM
Theresa's Avatar
Liked: 51
Originally Posted by N8DOGG View Post
As long as the driver can thermally take the power, you can clip your amp all day long and it's not going to hurt anything. The DC current is the tweeter killer..
I believe it is the high frequencies produced from the clipping, ie the square wave, that burns out tweeters.
Theresa is offline
post #15 of 72 Old 02-03-2013, 11:49 AM
N8DOGG's Avatar
Liked: 1221
It's the DC current the amp produces when it clips that is the killer.
N8DOGG is offline
post #16 of 72 Old 02-03-2013, 01:31 PM
Liked: 5687
That's one of the myths in question. There is no DC.
http://forum.qscaudio.com/forum/viewtopic.php?f=29&t=2736
High frequency harmonics, to be exact. With a normal signal power density drops by 3dB for each 1 octave rise in frequency, so normally a tweeter might see 5% of the total system power. The added harmonics of a clipped signal can result in 10dB or more power density in the highs than normal, so the tweeter might be called on to handle 50% of the total system power, burning it out. Since the woofer is already expected to handle at least 75% of system power and its voice coil inductance acts as a low pass filter it's unaffected unless the clipping is accompanied by the low frequency output being more than the driver is rated for. Keep in mind that amps are rated typically at 1% or less THD, and when driven into clipping they can deliver much more than their rated power.
post #17 of 72 Old 02-03-2013, 01:57 PM
Theresa's Avatar
Liked: 51
Well, I'm happy I wasn't wrong.
Theresa is offline
post #18 of 72 Old 02-03-2013, 02:22 PM
N8DOGG's Avatar
Liked: 1221
I can quote several websites that say the exact opposite. I'm not saying they are 100% correct but I'm only doing wjhat you are Bill, quoting a link just for reference.
http://www.formaudio.com.au/technical-articles/83-technical-clipping-and-under-powering-speakers
http://www.focal.com/en/content/420-why-do-voice-coils-burn-out
Although the voltage can't actually hold the woofer in place, it does attempt to until the input falls within the voltage limits. There is quite a bit of evidence both ways. An amp can certainly produce more wattage that it's rated for for short bursts, which is the result of most failures but thermally, the coil can't cool itself and bingo, we have a cooked coil.
N8DOGG is offline
post #19 of 72 Old 02-03-2013, 02:47 PM
Liked: 5687
If that's what they say they're wrong.
Nope. A woofer never sees a true square wave. It only sees that portion of the square wave that remains after it has passed through the crossover, or if there is no crossover that which remains after being filtered by the inductance of the voice coil. If your links show an oscilloscope trace of a square wave then totally clueless they be, for no speaker ever sees a waveform that even vaguely resembles that.
As far as speakers are concerned there's nothing special at all about a clipped waveform, it's just another complex waveform, and they treat it just like every other complex waveform that they deal with with every pulse they receive.
If clipping bothered woofers in the least then every guitar player would be replacing drivers as often as they replace strings.
post #20 of 72 Old 02-03-2013, 03:15 PM
bass addict's Avatar
Quoted: 451 Post(s)
Liked: 510
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #21 of 72 Old 02-03-2013, 03:17 PM
N8DOGG's Avatar
Liked: 1221
I only put the links up as an example. Simply the same thing you did, just to show different points of view. I'm only trying to show others. There is lots of papers saying it does. It is what it is. This will be my last post on the subject as I'm sure it will just turn into a typical debate we've all seen time and time again lol
http://sound.westhost.com/clipping.htm
N8DOGG is offline
post #22 of 72 Old 02-03-2013, 04:32 PM - Thread Starter
apnea's Avatar
I'm an empirical kind of guy. I'll just keep on clipping the amp and see how the drivers fare. I have a pair of subs, and you can always draw a straight line through two data points, so it'll be statistically robust.
Joking aside, has anyone measured the shape of the signal at low frequencies for amps which claim to offer soft clip protection?
apnea is offline
post #23 of 72 Old 02-03-2013, 04:32 PM
MarkHotchkiss's Avatar
Liked: 85
I think part of the problem is misused terminology. In this reference: The author says:
" 1. When an amp is clipping, it will output a DC signal. "
This is not only wrong, but is clearly contradicted by the image on his oscilloscope. I think he is describing the flat-top as DC, which it is not. The energy delivered is less than it would have been had the sine-wave been allowed to continue its normal curve rather than flat-topping.
It is the abrupt edges when the signal goes flat that causes the higher-frequency harmonics. As Bill said, those would then be routed to the midrange and tweeter by the crossover, and possibly cause damage there.
That second reference has too many problems to refute.
MarkHotchkiss is offline
post #24 of 72 Old 02-03-2013, 05:11 PM
N8DOGG's Avatar
Liked: 1221
I'm only pointing out examples of different papers. I'm not saying that they are right or wrong. Just pointing out that there are lots of differing views on the subject. I personally have never blown a tweeter, I've blown up a few subs lately that shouldn't have been nowhere near cooking with the power they were getting but they did. If I'm wrong, I'm fine with that but I've not seen any evidence to prove otherwise. Like what was just said, just linking a paper or some numbers isn't evidence because as we all know, it can be wrong.
N8DOGG is offline
post #25 of 72 Old 02-03-2013, 06:08 PM
Liked: 5687
Agreed, and note that I stated that this is a persistent myth that won't go away, partly because parties that should know better continue to spread it.
Were you monitoring the power? If not you can't know for sure that overpowering didn't occur, and if you cooked drivers then the only logical conclusion is that it did. I've blown exactly one driver in the last 40 years, an EVM15B that I was testing. I was using a 50 watt amp and an errant transient pulse took out the 400w rated voice coil in the blink of an eye.
post #26 of 72 Old 02-03-2013, 06:33 PM
Liked: 85
Yes, I see your point.
A poster needs to do more than just link to what may be a dubious source. This is one of the reasons I read AVS, as there are many people like Bill who are speaking from in depth experience. If someone here misstates the facts, it will always be corrected. I've learned a lot in this forum, in particular.
post #27 of 72 Old 02-03-2013, 08:16 PM
N8DOGG's Avatar
Liked: 1221
They should not have blown, they should have been able to handle way more power. I don't know why they fried but both subs cooked at the same time on "scary christmas" dub step song I play to make sure they have no problems before I ship them away. They were SI 18's in 3 CF boxes. They might have been getting 650 watts, if that. It just surprised me I guess. I've been putting quadruple power to subs for 10 years now and never had one smoke a coil. I've had damage from over excursion but never thermally. 2 seperate dayton 1000 plates amps. Crazy stuff. I can get a VC made no problem and I've got a few re-cone kits laying around that should be ok.
N8DOGG is offline
post #28 of 72 Old 02-03-2013, 08:57 PM
DonH50's Avatar
Quoted: 2222 Post(s)
Liked: 1828
People who write, or perhaps proof, such papers should be required to take at least one basic circuits class.
I love debating "marketing" papers on the Internet, proves just how useless three degrees and decades of experience can be. Helps keep me humble. Or maybe not, just annoyed and befuddled at how readily physics can be redefined...
Life would be easier if pi = 3 instead of 3.141592653..., but...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #29 of 72 Old 02-04-2013, 12:49 AM
Roger Dressler's Avatar
Quoted: 1872 Post(s)
Liked: 1004
There are debates on opinions that cannot be resolved. This is math and physics, not opinion.
The author of the info at the westhost link offers the relevantly titled article "Why Do Tweeters Blow When Amplifiers Distort?" The introduction of which laments this is:
a vexing question, regularly asked and rarely answered properly. The answers are actually quite simple, but the common misconception is that the distortion creates harmonics, and the additional harmonic content destroys the tweeter.
The rest of the article then provides measurements that show the added harmonics from clipping do in fact increase the signals in the tweeter. Just that the ponderous explanation misses the point. So the author is correct: the question is rarely answered properly. rolleyes.gif
The article also makes this statement about what happens when a sine wave just below clipping is pushed 3 dB into clipping:
Peak power remains the same, since it is limited by the amplifier's power supply voltage.
Except it doesn't. The power increases even though the peak voltage of both waveforms is limited by the power supply. As a sine wave becomes a square wave, the power ultimately doubles. Where does all that added power exist spectrally? At every harmonic above the fundamental -- many of which heat the tweeter. wink.gif
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #30 of 72 Old 02-04-2013, 03:42 AM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
"As a sine wave becomes a square wave, the power ultimately doubles. Where does all that power exist spectrally? At every harmonic above the fundamental -- many of which heat the tweeter."
i thought the average of a sine wave was 0.707 of peak, therefor at full square wave where the average increases to ~1.000, the increase in power would be 1.000/0.707 which is around 1.414 or a 41% increase in power.
Listen. It's All Good.
LTD02 is offline
