Petition to Behringer: Please create a stand alone, home theater focused, DSP similar to INuke's DSP - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #91 of 124 Old 11-19-2013, 08:38 AM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
"Why not use PEQ instead of HS, with gain and Q to make the right half approximate the HS, so that the mirrored left has gives 12 dB more cut on the low end?"
that may be a way to go about it as well. i'm just not quite sure how that would work.
Listen. It's All Good.
LTD02 is offline
post #92 of 124 Old 11-19-2013, 09:21 AM
desertdome's Avatar
Quoted: 1335 Post(s)
Liked: 1525
Originally Posted by clausdk View Post
My HTPC runs Jriver already:)
It's a little bit outside this thread, but how would one go about such system in a good way?
There is some good info in this thread: Oddball inwall
Also, dlbeck's home theater thread will detail a 15 channel setup using JRiver: The Savoy
In a few weeks I will be receiving a demo of Solid State Logic's Alpha-Link MX 4-16 DAC and MadiXtreme PCIe card.
Here is a thread I started at JRiver's forum about Methods of Output to an Audio Device. I eventually hope to list a bunch of options in the thread for multi-channel DACs.
LTD02 and clausdk like this.
High Impact AV
desertdome is offline
post #93 of 124 Old 11-19-2013, 09:30 AM
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
Thx, desertdome!
Added this thread to my signature to call attention to our grass roots movement for product action!
blah450 is offline
post #94 of 124 Old 11-19-2013, 01:58 PM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
What's not to be sure about?
Noah
noah katz is offline
post #95 of 124 Old 11-19-2013, 02:03 PM
LTD02's Avatar
Liked: 2888
i'm not sure what settings would be used, how closely it could be made to the target, and what advantage it would provide...so pretty much everything. my sense is your right, i'm just not sure how to go about it.
LTD02 is offline
post #96 of 124 Old 11-19-2013, 02:45 PM
clausdk's Avatar
Quoted: 214 Post(s)
Liked: 82
I'll look into that. Thanks.
clausdk is offline
post #97 of 124 Old 11-19-2013, 04:11 PM
noah katz's Avatar
Liked: 387
How about this:
filt.jpg 72k .jpg file
LTD02 likes this.
Noah
post #98 of 124 Old 11-21-2013, 10:10 AM
noah katz's Avatar
Liked: 387
Has a bit of ripple, but not much and seems to do the job otherwise.
What do you think, lilmike?
LTD02 likes this.
Noah
post #99 of 124 Old 11-21-2013, 10:30 AM
LTD02's Avatar
Liked: 2888
"How about this"
that looks good. ricci's method was similar.
with a little farting around, you might be able to get a little bit less ripple, but there comes a point where its 'good enough'.
LTD02 is offline
post #100 of 124 Old 11-21-2013, 10:38 AM
LTD02's Avatar
Liked: 2888
also, one neat little trick is to create a driver and put an LR transform on it down to 1hz. that makes a perfectly flat line. from there, you can plop a filter on it such as LR 24 at 16hz, or whatever your target is. that way you can see how close you are on target with the synthetic. with the shelf filter, it is possible to nail it exact.
LTD02 is offline
post #101 of 124 Old 11-21-2013, 11:07 AM
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
Looks like that will work. Won't know till I measure things.
I'll pull the amp, get my load resistors out, and take some measurements to confirm as soon as I'm able.
Will be a few days before I can mess with it though.
lilmike is offline
post #102 of 124 Old 11-21-2013, 01:04 PM
noah katz's Avatar
Liked: 387
I made the driver essentially flat by changing its parameters to Fs = 5, Qe = .6, Vas = 1000 L
Noah
post #103 of 124 Old 11-21-2013, 02:14 PM
LTD02's Avatar
Liked: 2888
"then what the heck weren't you sure about?"
probably just how accurate it could be made to match up. i farted around with it before for quite some time and could never really get things to match that way, and the lower the target/steeper the slope, the further off it would be. but like i mentioned above, in many scenarios, it certainly seems like it would be 'good enough'.
LTD02 is offline
post #104 of 124 Old 11-23-2013, 07:20 AM
onebadmonte's Avatar
Liked: 26
onebadmonte is offline
post #105 of 124 Old 05-19-2014, 11:22 AM - Thread Starter
Archaea's Avatar
Quoted: 3086 Post(s)
Liked: 2716
We now have a Behringer rep on this forum. His name is John DiNicola. I invited him to check out this thread.
Archaea is offline
post #106 of 124 Old 05-19-2014, 11:26 AM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
i woudl also support this, i have an iNuke 1k powering some things and really like it. a stand alone would be very nice
Sibuna is online now
post #107 of 124 Old 05-19-2014, 11:32 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5973 Post(s)
Liked: 5036
Nice. Would be interesting to hear the man's thoughts on the matter.
I am still down for something like this but in the sense of being a updated/new replacement for the DCX with the option to rackmount. Best of both worlds.
Scott Simonian is offline
post #108 of 124 Old 05-19-2014, 01:31 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 408
The strange thing is that they recently modified the DCX2496 slightly, making a new model number DCX2496LE. This version has no digital inputs or outputs and costs less than the regular DCX2496. That's a step in the right direction, but it would be really great if they could have one with a USB control port and software resembling that of the iNuke DSP amps.
andyc56 is offline
post #109 of 124 Old 05-19-2014, 01:36 PM
NWCgrad's Avatar
Quoted: 1272 Post(s)
Liked: 1311
Should be simple for them to put the DSP from the iNuke into a stand alone processor. Seems tailor made to fit a need for both pro and HT applications. The iNuke GUI is very user friendly.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #110 of 124 Old 05-19-2014, 01:42 PM
Bass Enabler
Liked: 5036
I noticed this release recently.
It also omits a third input, which I think is useful.
post #111 of 124 Old 05-19-2014, 02:09 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 408
Ooh, I had missed that. Thanks for pointing that out.
andyc56 is offline
post #112 of 124 Old 05-19-2014, 02:16 PM
Bass Enabler
Liked: 5036
Yeah an important distinction of the LE version which is also $50 less. A third input may never be used by someone so saving $50 might be worth it for them.
post #113 of 124 Old 05-20-2014, 07:45 AM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
I'd be completely satisfied/happy if they'd just update the software in the DCX2496 to be like the iNuke DSP. A facelift of sorts.
JohnDean is offline
post #114 of 124 Old 05-20-2014, 08:09 AM
NWCgrad's Avatar
Liked: 1311
Would be nice...I am on the fence for ordering the DCX2496. I already have plenty of parametric equilization capability but both devices (Behringer DSP1124P and FBQ2496) lack HPF/LPF.
Home Theater:
NWCgrad is offline
post #115 of 124 Old 05-20-2014, 11:04 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
Yes, if they would just allow the extension of the filters to say, 10Hz, it would do wonders for the HT crowd. Great piece of gear, but just a tad short of ideal.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #116 of 124 Old 06-12-2014, 02:33 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I'd be interested
Mfusick is offline
post #117 of 124 Old 06-12-2014, 04:15 PM
DiscoDuck's Avatar
Quoted: 14 Post(s)
I would be interested in a behringer dsp only rack mount
DiscoDuck is offline
post #118 of 124 Old 06-13-2014, 04:01 AM
blazar's Avatar
Quoted: 754 Post(s)
Liked: 539
I want the lab gruppen amps to have 12v trigger too... Then they would be perfect.
Pro amps likely wont add another relay in there tho, they dont want another part that can fail.
blazar is offline
post #119 of 124 Old 07-15-2014, 06:01 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
Pro amps likely wont add anothweter relay in there tho, they dont want another part that can fail.
Wtf. Did I miss something.
Add me to the list of interested parties for a standalone inuke dsp or an updated dcx.
berstuck is offline
post #120 of 124 Old 07-15-2014, 07:40 PM
BassThatHz's Avatar
Quoted: 2390 Post(s)
Liked: 2165
2RU solution for 16 inputs, 16 outputs:
2 of these (one for input, one for output): http://www.sweetwater.com/store/detail/P16/
2 of these: http://www.minidsp.com/products/mini...8-x-in-8-x-out
16 of these: http://www.parts-express.com/talent-...15-ft--240-909
optionally 1 of these: http://www.circuitspecialists.com/ra...ure-37-2u.html
~$1200 Not cheap or easy, but problem solved!
(Expand as needed.)
But yeah... it would be great if it could be bought as a professionally packaged product!!!
BassThatHz is online now
