5 DIY Bookshelf Speakers for HT setup (approx .5cuft) recommendations ?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 02-02-2013, 09:31 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Looking to build 5 Bookshelf (aprox .5cuft) for HT setup to go along with Subs ,..any recommendations ??
Will be replacing Small Kef Sats
randyc1 is offline
post #2 of 20 Old 02-02-2013, 09:42 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Jay1 is offline
post #3 of 20 Old 02-02-2013, 10:18 PM
tuxedocivic's Avatar
Quoted: 1905 Post(s)
Liked: 1725
What's the budget.
By bookshelf, how big do you mean?
Ryan
tuxedocivic is online now
post #4 of 20 Old 02-04-2013, 11:22 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Originally Posted by tuxedocivic View Post
What's the budget.
.5 cu ft ext size would be around 9x14x11
200.00 per speaker budget
randyc1 is offline
post #5 of 20 Old 02-04-2013, 11:33 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Originally Posted by Jay1 View Post
These look pretty good
http://www.diysoundgroup.com/waveguide-speaker-kits/alpha8-kit.html
Yes these do look like an interesting option !
Im not to familiar with thes kinds of speakers
randyc1 is offline
post #6 of 20 Old 02-04-2013, 11:46 AM
Liked: 1725
I'd second Jay1's suggestion. Those are really good.
Ryan
post #7 of 20 Old 02-04-2013, 01:26 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
N
..What are the general differences of (waveguide) speakers over a high end sealed bookshelf ? And why is one better than another for SQ in HT ??
randyc1 is offline
post #8 of 20 Old 02-04-2013, 01:41 PM
Liked: 1725
Well, the waveguide speaker can also be sealed. In fact, I usually do seal mine and run subs.
The rest of your question is very broad. It comes down to off axis performance and SPL. The linked speaker can go way louder cleanly than most hifi speakers (assuming that's your comparison and what you mean be high end). It'll also have a very uniform off axis performance that matches the woofer. So reflected sound has a timbre match to the direct sound. These are all good things for music listening as well as HT.
I use dome tweeters also, because they measure really flat, easy to work with, cheap, and sound just fine when kept within their SPL limits and incorporated into the speaker properly. But at $200/speaker, that is a hard speaker to beat.
Ryan
post #9 of 20 Old 02-04-2013, 07:59 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
I use dome tweeters also, because they measure really flat, easy to work with, cheap, and sound just fine when kept within their SPL limits and incorporated into the speaker properly. But at $200/speaker, that is a hard speaker to beat.[/quote
Thanks tuxedocivic,... can the model u mentioned be sealed ,? in what size ,and how would it affect performance ??
I've seen some of your designs from a link and really liked their size !
randyc1 is offline
post #10 of 20 Old 02-04-2013, 08:04 PM
Liked: 1725
I'd ask Matt (mtg-90) about sealed and cab size. He would know that better than me.
Thanks for the compliment. I'm not sure any of my designs hit the small and high performance for $200 mark. I have a few in the sub-$150 range, and a few big ones. But nothing that meets your needs.
Ryan
post #11 of 20 Old 02-04-2013, 08:19 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
I saw the youtube video on the model u suggested and cant believe how loud it,.one..was playing with 15w !! .. imagine L,C.R!!
Just cant understand all these waveguide models much bigger and more efficient,that people are building,.. how loud do people listen to music or movies ???
I was thinking of 5 sealed bookshelves ( approx .5 cuft ) with subs for HT , but now im curious about these waveguides??
randyc1 is offline
post #12 of 20 Old 02-04-2013, 08:50 PM
Liked: 1725
Ya, I certainly don't listen nearly as loud as some around here. I do it for the directivity and off axis match. The clean dynamic headroom is a perk for me. There are some tweeter designs that are pretty good at dynamics and off axis control. But those usually take a bit more money and often need to be three way. Diysoundgroup just makes it so affordable.
Ryan
post #13 of 20 Old 02-05-2013, 12:04 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Ok tuxedocivic , so i guess the Alpha 8 are the best Small Bookshelf option for HT
Thanks again !
randyc1 is offline
post #14 of 20 Old 02-05-2013, 01:34 PM
Liked: 1725
At that price point and size constraint, I'm thinking it's about the best. If you're not sold on the waveguide and compression driver thing, well, there's other options. But I think you'd be pretty pleased. Before spening the bucks though, maybe ping MTG-90 and ask him to shed some light on your question. It's good to get a variety of opinions.
Ryan
post #15 of 20 Old 02-05-2013, 05:23 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Well i did follow your advise and ask MTG-90, and he explained how it was designed and said i would be very pleased !
Have'nt made my choice yet , but are certainly on my list !
Thanks !!
randyc1 is offline
post #16 of 20 Old 02-07-2013, 12:12 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
How much better of a speaker at Approx the same size (.5cuft net)can i make if i had a 500.00 per speaker budget ?
randyc1 is offline
post #17 of 20 Old 02-07-2013, 02:39 PM
Liked: 1725
If it were me, I'd use the new SB satori ring radiator tweeter in a custom milled maple burl waveguide from TN Allen over on techtalk. Then I'd cross over around 900hz to an 8" scan revelator or something like that in a sealed 0.5 cu ft box. Cross it to your subs around 60 to 80hz. But that design doesn't exist frown.gif
As a kit or something with a design, I'm not sure what's out there. Most high end designs like that use a 7" woofer and flush mounted dome crossed around 2khz. Not a good idea imo. If flush mounting a dome, it's gotta be a 2khz cross over with a 5" woofer. Maybe there's a high end MTM that does this. Even, so, I think I'd spend less and get the alpha 8 before doing that. Check out the Aurora by Pete Schumacher over on tech talk. Not sure I spelled his name right. He's pretty fond of that design. It's a high end bookshelf and design well I think. He doesn't have much data on it other than a few FR measurements.
Ryan
post #18 of 20 Old 02-08-2013, 09:02 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Hi tuxedocivic !
I stumbled on a thread talking about a 8" COAXIAL Driver , same one used in the Alpha8 ,but Coaxial ! ( same as Mark Seaton"s SPARK Speaker)
To bad no one has designed a DIY speaker around this driver . Enclosure size,..shape could be very versatile !! also could be used horizontally for Center channel !
randyc1 is offline
post #19 of 20 Old 02-08-2013, 09:18 AM
Liked: 1725
I agree, that would make for something really great. I personally would love to find a coax that works well, I believe in close driver spacing and point source sound. A coax is the pinnacle of that. Unfortunately I've never seen one that measures well. The Kef ones are ok. I'll look into Mark's SPARK speaker.
Just thought of a better $500 bookshelf. Creative Sound Solutions Planer 2 for $229. Over a scan revelator or something.
Ryan
post #20 of 20 Old 02-08-2013, 10:41 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Im using small Kef Coaxial speakers right now.
randyc1 is offline
