What The .........? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 04-09-2013, 03:48 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
That's exciting to hear.
I still have about 4 18" PR's lying around, would this be something worth looking into or is it worth the trouble only if you have 21" PR's?
I know there is a 6th order BP selection in WinISD but my brain shut down when it tried to process what I am doing, stupid brain. I have a RCF LF21N451 21" and a XXX 18" laying around right now not doing anything and a pair of SI 18" subs that are waiting for an enclosure.
mjaudio is online now
post #32 of 44 Old 04-10-2013, 06:22 AM - Thread Starter
Fatawan's Avatar
You would have to model it and see. I did a "combo" model where I was using the 6th order BP and the PR facilities in WinISD at the same time to get tuning and chamber sizes. Which PR's do you have?
Fatawan is offline
post #33 of 44 Old 04-10-2013, 12:27 PM
Ricci's Avatar
Quoted: 185 Post(s)
Liked: 473
There is a freeware program called SubSimulator (I think) that will model these and even 8th order cabs. It is about as easy as winisd once you get used to it. I don't remember the actual link to it.
Or there is Akabak if you feel froggy...
Ricci is online now
post #34 of 44 Old 04-10-2013, 01:14 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
I was messing around a little on WinISD using 6th order BP's but really have no idea what I am doing right now. Are the chambers tuned to the same frequency or is one tuned low and the other higher, say 15hz for the back chamber and 40hz for the front?
I have a pair of Exodus 18" PR's with the weight kit and a pair of Mach 5 18" PR's but they are already tuned to 18hz per Mark and I think it's glued in so I might not be able to change the tune. Jogging my memory I forgot I also have a pair of TC Sounds 15" VMPS but I am thinking the 18's are the way to go especially since I need 3?
post #35 of 44 Old 04-10-2013, 01:15 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
Thanks man, I will have to look those up as well.
post #36 of 44 Old 04-10-2013, 01:45 PM - Thread Starter
Fatawan's Avatar
Small chamber in front tuned to higher frequency than big chamber in back. If you really mess up on the model, you can get the response to look like sally the camel(2 humps). I may get that Sally look, I don't know. I am putting REW on my laptop right now.
Fatawan is offline
post #37 of 44 Old 04-13-2013, 07:24 AM - Thread Starter
Fatawan's Avatar
Houston, we may have a problem. It was late when I finally got REW going on my new laptop. I only ran a couple sweeps, but it appears my front chamber is peaking around 36 Hz. That is where the model would indicate the tune to be when the chamber volume is 2.9cf. That would indicate to me that my foam did nothing to take up the excess volume. I thought it would reduce the volume down to 1.6cf or so, but it appears I was wrong. Anyone have any thoughts on that? Back to the drawing board.....
Fatawan is offline
post #38 of 44 Old 04-13-2013, 07:58 AM
brian6751's Avatar
Quoted: 900 Post(s)
Liked: 693
Cut small panels and seal off each of those foam chambers using PL premium ?
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #39 of 44 Old 04-13-2013, 08:26 AM - Thread Starter
Fatawan's Avatar
Yea, that is what I was thinking too.
Here are the graphs--all were done with a 20Hz BUT12 filter in place to protect the innocent until my MiniDSP is in place
The front PR
A sum of both rear PRs
and finally, a sum of all three radiators
Fatawan is offline
post #40 of 44 Old 04-14-2013, 08:47 AM - Thread Starter
Fatawan's Avatar
Well, the powers of the miniDSP have made this look a lot better. Some more fun with REW now:
I added the miniDSP to the equation(was using the DCX2496 before--its now out of the loop). I put in a 12Hz LR24 HPF. I also added one wide PEQ cut of 5db centered at that 36Hz peak. Now watch the magic!
First, the front radiator alone
Here are the individual traces of the two PRs in the rear chamber
Now if I sum both rear chamber outputs and put them on the graph with the front PR trace
To wrap it up, I sum the output of the front PR with the summed outputs of the rear PRs and this gem emerges
So I end up with a "band" that is narrower than I had originally intended, but I may just live with it. It will provide some serious output in that 18 to 60Hz region before my room's own output additions.
Fatawan is offline
post #41 of 44 Old 04-17-2013, 04:26 PM - Thread Starter
Fatawan's Avatar
I added another sub to the front of my room(LMS 5400 15" with two 18" PRs, same tune as this new sub), plus I have 4 sealed Rythmiks in the back of my room. I used the miniDSP to get the front two subs to play well together after I got the best graph I could from moving subs around. I consider that SUB A as far as Audyssey Multi EQ XT32 is concerned. The 4 Rythmiks stacked in back are SUB B. I ran Audyssey, and here is the result at my main listening position:
I can live with that. I am going to listen now and see if I like this combination or not.
Fatawan is offline
post #42 of 44 Old 04-17-2013, 04:52 PM
N8DOGG's Avatar
Quoted: 976 Post(s)
Liked: 1046
good looking graphs!!! I bet it sounds great.
N8DOGG is online now
post #43 of 44 Old 04-18-2013, 02:25 PM
coctostan's Avatar
Liked: 135
That is exceptional Fatawan. Have you taken measurements across a few seats?
coctostan is offline
post #44 of 44 Old 04-19-2013, 12:13 PM - Thread Starter
Fatawan's Avatar
I was having people over that night, so it was a quick three-position Audyssey run, one measurement at the main listening position to make sure it was ok, then rush to put it all away. I'll do some more later.
Fatawan is offline
