Clay Pot as Sub Enclosure - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-08-2013, 07:00 AM - Thread Starter
Daphnis's Avatar
Can someone comment about using sand clay pot as sub enclosure? For ported design with a strict budget.
Daphnis is offline
post #2 of 8 Old 02-08-2013, 07:05 AM
DonH50's Avatar
Quoted: 2170 Post(s)
Liked: 1751
Probably crack once you crank the sub, and mounting the driver could be tricky... I suppose you could try an epoxy seal. I'd probably just buy a sheet of 1" MDF and screw and glue together a box.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 8 Old 02-08-2013, 07:07 AM
JD in NJ's Avatar
Liked: 37
What's cheaper, a sheet of MDF or a sonotube build?
JD in NJ is offline
post #4 of 8 Old 02-08-2013, 07:10 AM - Thread Starter
Daphnis's Avatar
Can you comment on the SQ on this? I understand that mounting as well as porting is going to be difficult but just wanted to give it a try. I can always go back to MDF if this cracks as pot is very cheap in my area.
Daphnis is offline
post #5 of 8 Old 02-08-2013, 07:11 AM
JD in NJ's Avatar
Liked: 37
maxcooper likes this.
JD in NJ is offline
post #6 of 8 Old 02-08-2013, 11:13 AM
DonH50's Avatar
Liked: 1751
All that usually matters for SQ is a stiff enclosure with enough volume and proper port size. From that standpoint pot away.
DonH50 is offline
post #7 of 8 Old 02-08-2013, 01:08 PM
BassThatHz's Avatar
Quoted: 2350 Post(s)
Liked: 2114
It won't crack, not from the SPL inside.
Maybe an LMS Ultra might be able to manage to, if feed 4kW, but that's about the only driver that could...
BassThatHz is offline
post #8 of 8 Old 02-08-2013, 01:52 PM
DonH50's Avatar
Liked: 1751
I was thinking more about the vibration, not SPL, but I don't know since I've never built a sub in a clay pot.
DonH50 is offline
