DIY Home Automation - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #91 of 98 Old 07-17-2016, 06:52 PM - Thread Starter
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1547
There the face plates fit and there is enough space for the 10awg wires.
Now I need 16 1/4" screws for the heat sinks.
dashpuppy likes this.
BassThatHz is offline
post #92 of 98 Old 07-21-2016, 12:11 AM - Thread Starter
BassThatHz's Avatar
Liked: 1547
I tried creating my very first andriod app, I followed the instructions, but it gave me 60 java runtime errors.
and this is why I prefer Microsoft C# (because it NEVER gives you API runtime errors!)
It is backwards compatible since version 1.0 of the API!!! and most certainly the last few versions. Unlike java!
I don't have time to bleed!!!
I don't know andriod studio and I don't know java, so I'm off to a great start!
post #93 of 98 Old 07-21-2016, 09:33 AM
dashpuppy's Avatar
Quoted: 375 Post(s)
Liked: 197
There is a reason why im a hardware guru @ work I HATE software !
dashpuppy is online now
post #94 of 98 Old 07-21-2016, 03:26 PM - Thread Starter
BassThatHz's Avatar
Liked: 1547
Well, I'm gonna forge ahead without a working compiler.
Got the GUI done. Now I need to make the buttons do something:
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    android:paddingBottom="@dimen/activity_vertical_margin"
    android:paddingLeft="@dimen/activity_horizontal_margin"
    android:paddingRight="@dimen/activity_horizontal_margin"
    android:paddingTop="@dimen/activity_vertical_margin"
    tools:context="bassthathz.bassthathzrelayapp.MainActivity">
    <Button
        android:layout_marginTop="0dp"
        android:layout_width="fill_parent"
        android:layout_height="wrap_content"
        android:text="Music Mode"
        android:onClick="MusicModeClick"
    <Button
        android:layout_marginTop="50dp"
        android:text="Movie Mode"
        android:onClick="MovieModeClick"
    <Button
        android:layout_marginTop="100dp"
        android:text="All Off"
        android:onClick="AllOffClick"
</RelativeLayout>
post #95 of 98 Old 07-21-2016, 04:41 PM - Thread Starter
BassThatHz's Avatar
Liked: 1547
Alright, this should do it, I think....?
That said, the C# code can't yet handle this, it will have to be updated to accept these URL parameters from the Android and process them... (it is nothing difficult.)
Code:
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="bassthathz.bassthathzrelayapp">
    <uses-permission android:name="android.permission.INTERNET" />
    <uses-permission android:name="android.permission.ACCESS_NETWORK_STATE" />
    <application
        android:allowBackup="true"
        android:icon="@mipmap/ic_launcher"
        android:label="@string/app_name"
        android:supportsRtl="true"
        android:theme="@style/AppTheme">
        <activity android:name=".MainActivity">
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
    </application>
</manifest>
Code:
package bassthathz.bassthathzrelayapp;
import android.content.Context;
import android.net.ConnectivityManager;
import android.net.NetworkInfo;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.util.Log;
import android.view.View;
import java.io.BufferedOutputStream;
import java.io.IOException;
import java.io.OutputStream;
import java.net.HttpURLConnection;
import java.net.MalformedURLException;
import java.net.SocketTimeoutException;
import java.net.URL;
public class MainActivity extends AppCompatActivity {
@Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
    public void MusicModeClick(View view)
       int response = SendNetworkComm("MusicModeClick");
        ResponseHandler(response);
    public void MovieModeClick(View view)
        int response = SendNetworkComm("MovieModeClick");
    public void AllOffClick(View view)
        int response = SendNetworkComm("AllOffClick");
    public void ResponseHandler(int response)
        //todo
    public void ErrorHandler(String UserMessage)
        //todo
    public int SendNetworkComm(String paramValue)
        int response = -1;
        try
            ConnectivityManager connMgr = (ConnectivityManager) getSystemService(Context.CONNECTIVITY_SERVICE);
            NetworkInfo networkInfo = connMgr.getActiveNetworkInfo();
            if (networkInfo != null && networkInfo.isConnected()) {
                // do network comm
                URL url = new URL("http://192.0.0.1/?action=" + paramValue);
                HttpURLConnection conn = null;
                try
                    conn = (HttpURLConnection) url.openConnection();
                    conn.setReadTimeout(10000);
                    conn.setConnectTimeout(10000);
                    conn.setRequestMethod("GET");
                    //conn.setRequestProperty("Content-Type", "text/plain");
                    //conn.setRequestProperty("charset", "utf-8");
                    conn.setDoInput(true);
                    conn.connect();
                    response = conn.getResponseCode();
                catch(MalformedURLException error)
                    ErrorHandler("URL is invalid.");
                catch(SocketTimeoutException error)
                    ErrorHandler("Server could not be reached.");
                catch (IOException error)
                    ErrorHandler("Network error.");
                finally
                    if(conn != null)
                        conn.disconnect();
            else
                ErrorHandler("Network Unavailable.");
        catch (IOException e)
        return response;
post #96 of 98 Old 07-21-2016, 06:29 PM
dashpuppy's Avatar
Quoted: 375 Post(s)
Liked: 197
Code:
    <application
            <intent-filter>
            </intent-filter>
        </activity>
    </application>
</manifest>
Code:
@Override
        //todo
        //todo
        int response = -1;
        try
                // do network comm
                try
                    conn.connect();
                finally
                    if(conn != null)
                        conn.disconnect();
            else
        return response;
Is the ip your using just a temp one . I don't think 192.0.0.1 is rout able.
post #97 of 98 Old 07-21-2016, 07:21 PM - Thread Starter
BassThatHz's Avatar
Liked: 1547
It's just a placeholder. Ideally it would be configurable, haven't got that far yet.
post #98 of 98 Old 07-21-2016, 07:30 PM - Thread Starter
BassThatHz's Avatar
Liked: 1547
Ok here is the newest version of the C# Relay up on my Google Drive:
C# Source Code
Windows Binary
This now has support for the Android app (or any app that can apply this request parameters syntax):
Code:
public static string HttpRequestHandler(HttpListenerRequest request)
            String ReturnValue = String.Empty;
            var x = new RelayConfig.RelayConfig();
            if (request.QueryString != null)
                String action = request.QueryString["action"];
                if (!String.IsNullOrEmpty(action))
                    switch (action)
                        case "MusicModeClick":
                            x.MusicMode();
                            break;
                        case "MovieModeClick":
                            x.MovieMode();
                            break;
                        case "AllOffClick":
                            x.AllOff();
                            break;
            else
                using (var reader = new StreamReader(request.InputStream, request.ContentEncoding))
                    string text = reader.ReadToEnd();
                    if (text.Contains("btnMusic"))
                        x.MusicMode();
                    else if (text.Contains("btnMovies"))
                        x.MovieMode();
                    else if (text.Contains("btnOff"))
                        x.AllOff();
                ReturnValue = GetFileAsString();
            return ReturnValue;
Code:
private void HttpRequestHandler(IAsyncResult result)
            HttpListenerContext Context = listener.EndGetContext(result);
            HttpListenerRequest Request = Context.Request;
            HttpListenerResponse Response = Context.Response;
            if (Request.RawUrl != "/" && Request.RawUrl != "/Default.html" && !Request.RawUrl.Contains("/?action="))
                return;
            string ResponseString  = String.Empty;
            Response.StatusCode = 200;
            Response.StatusDescription = "OK";
            Response.ContentType = "text/html";
            if (_HttpResponseHandler != null)
                ResponseString = _HttpResponseHandler.Invoke(Request);
            if (String.IsNullOrEmpty(ResponseString))
                ResponseString = "<HTML><BODY>Default Content</BODY></HTML>";
            byte[] Buffer = System.Text.Encoding.UTF8.GetBytes(ResponseString);
            Response.ContentLength64 = Buffer.Length;
            System.IO.Stream OutputStream = Response.OutputStream;
            OutputStream.Write(Buffer, 0, Buffer.Length);
            OutputStream.Close();
            Response.Close();
but I haven't tested this new code just yet.
"Should" work, it was a pretty small/simple change.
(But never say never... )
