S.E.O.S.R. MEGA BUILD - Page 53 - AVS Forum
 20Likes
post #1561 of 1579 Unread Today, 05:59 AM
Mfusick's Avatar
Quoted: 212 Post(s)
Liked: 1092
I think dual 15's would be kick ass. Easier to figure out and tweak and implement too. Do a 3 way xover do you can roll one 15" off sooner than the other might be helpful.
Mfusick is online now
post #1562 of 1579 Unread Today, 06:51 AM - Thread Starter
ChopShop1's Avatar
Quoted: 54 Post(s)
Liked: 187
Still liked the idea of the quad 12'd and SEOS 24. But thats just me. Should be doing a dual 10" side by side under a SEOS 18 soon. We'll see how I go from there.
The above and below 12s could be a nice option, even dual below only. I just really like that TD15m
Not really a need to...it is a 3 way, remember, the BMSis a coax and active cross between mid and hf section in this build, then the dual 15s. The woofers really werent' the issue. The units we ran at the gtg were test units and the quads had never been run "live" before, only done on paper. I believe more of the "issues" were the details on the coax honestly. If gone as far as to talk with Ivan Beaver fro Danley and had looooonnngg conversations about it and their implementation of it in some of their units. The general concensous is that you can't get it perfect without going full active. I know some will oppose this view citing the JTR gear that uses it, but I'm not convinced the JTR offerings that run the 4594 wouldn't be even better if they were run this way.
ChopShop1 is online now
post #1563 of 1579 Unread Today, 06:59 AM
Mfusick's Avatar
Quoted: 212 Post(s)
Liked: 1092
I'm with you 100% on that. Active is better than passive, even with the perfect passive crossover there is an advantage with active over that.
post #1564 of 1579 Unread Today, 07:22 AM
Liked: 0
Ultralight mdf is not more substantial after that plyboard as well as the chaos isn't to be able to negative. This reductions more exact then plywood I've found. My cuts tend to be dangerous. Simpler to paint also.
gejoes is offline
post #1565 of 1579 Unread Today, 07:30 AM
btinindy's Avatar
Quoted: 26 Post(s)
Liked: 53
I have been waiting a long time to hear the words that you are back in the game. Heck, I wanted to scoop up some of the gear you were selling, but I couldn't bring myself to taking it away...I knew you'd be back! This was by far my favorite thread to follow, simply because it was pushing the limits of DIY and what could be done. Glad this thread is back on top of my subscribed list.
BT1
ChopShop1 likes this.
btinindy is offline
post #1566 of 1579 Unread Today, 08:23 AM - Thread Starter
ChopShop1's Avatar
Quoted: 54 Post(s)
Liked: 187
BT1
Thanks man, much appreciated! Through all the nonsense, I forgot how much fun even just speculating and planning is!
Your second to last statement is why I went with the quads originally....I'll never see close enough to the limits of the dual 15s to experience any negative effects, but the the dual model isn't really outlandish in te diy arena these days, so I got stuck on the quads as a must
post #1567 of 1579 Unread Today, 08:28 AM
Fatshaft's Avatar
Quoted: 202 Post(s)
Liked: 258
Originally Posted by ChopShop1 View Post
I just had to build the biggest thing in the diy section cause I'm a dumba$$
should read here at DIY...
I just had to build the biggest thing in the diy section cause it just proves that I'm NOT a dumba$$
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is online now
post #1568 of 1579 Unread Today, 11:15 AM
Face2's Avatar
Quoted: 76 Post(s)
Liked: 62
The BMS can get close via passive, but active is needed for perfect response. I use a combo active/passive filter for the BMS/SEOS24 combo.
Mike
Face2 is online now
post #1569 of 1579 Unread Today, 11:17 AM
Face2's Avatar
Quoted: 76 Post(s)
Liked: 62
I agree with the AE TD15M being used under the SEOS24, anything smaller would be weak looking. :-D
How about some 18" AE woofers instead?
Mike
Face2 is online now
post #1570 of 1579 Unread Today, 12:27 PM
gpmbc's Avatar
Quoted: 87 Post(s)
Liked: 84
Where to source the BMS for any reasonable amount?
gpmbc is offline
post #1571 of 1579 Unread Today, 12:33 PM
Face2's Avatar
Quoted: 76 Post(s)
Liked: 62
Used or wait for a group buy.
Mike
Face2 is online now
post #1572 of 1579 Unread Today, 01:04 PM - Thread Starter
ChopShop1's Avatar
Quoted: 54 Post(s)
Liked: 187
I honestly thought about it, but not chasing full range, I wonder if the 18 gives something up to the TD15 in the midrange (John swears the 15M is the best of all his woofers) and really not getting any benefit.
Pretty much as Face said..pay $700 or get a group buy going. Jack as Assistance Audio, though I've had my differences with him, will give a bit better deal than that too.
post #1573 of 1579 Unread Today, 01:23 PM
gpmbc's Avatar
Quoted: 87 Post(s)
Liked: 84
Thx for the responses.
gpmbc is offline
post #1574 of 1579 Unread Today, 05:43 PM
Mfusick's Avatar
Quoted: 212 Post(s)
Liked: 1092
It's just physics. Plus the 18" would beam sooner, pretty early actually. You'd need a LOW crossover to prevent that. 15" better to reach up to 600hz handoff.
post #1575 of 1579 Unread Today, 05:50 PM - Thread Starter
ChopShop1's Avatar
Quoted: 54 Post(s)
Liked: 187
I didn't mean like that mike...I meant within the operating range without those issues, the 15 is a better driver in many ways according to John. ...Btw the 4594 seos24 performed just fine well below 600. ...I have to pull the files but if memory serves, 450 or 500 is what we were at
post #1576 of 1579 Unread Today, 06:09 PM
pnw
pnw's Avatar
Liked: 36
Originally Posted by klipsch View Post
Can that Radian fit the throat on a SEOS 24?
950Be is a 2" exit. 951Be is the 1.4".
I tested a (used) D2430K & it looked very good except that it had an intermittent buzz or rub at LF...probably why it was used. The 2430 is a "push-push" design with both diaphragms working full range of the driver. It is very different from the BMS coaxials, but lots of potential for an excellent system.
pnw is online now
post #1577 of 1579 Unread Today, 06:22 PM
klipsch's Avatar
Quoted: 67 Post(s)
Liked: 29
Thanks. Good info
klipsch is online now
post #1578 of 1579 Unread Today, 06:29 PM
Face2's Avatar
Quoted: 76 Post(s)
Liked: 62
Just keep in mind it won't work as low as the BMS coax unit.
Mike
Face2 is online now
post #1579 of 1579 Unread Today, 08:06 PM
Erich H's Avatar
Quoted: 488 Post(s)
Liked: 752
There's also a SEOS-18 with a 1.4" throat. It doesn't look like the 1" model, but more like a smaller SEOS-24.
Erich H is online now
