Time to shift gears towards the front stage - Sponge mode on :) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 02-12-2013, 04:56 PM - Thread Starter
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 441
Originally Posted by NWCgrad View Post
From my experience, and those of others, 45 degrees is the preferred position. I admit it looks a bit funky but the imaging is great with a huge sweetspot.
Generally I'd agree, but I am setup according to Audyssey DSX standards. 30 deg mains, 45 deg height channels, and 60 deg wide channels.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #32 of 36 Old 02-12-2013, 07:18 PM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
With this new AE group buy, jump on it and take advantage. Should be a nice discount for all of us who want the drivers.
bhazard is offline
post #33 of 36 Old 02-12-2013, 07:35 PM - Thread Starter
Quoted: 360 Post(s)
Liked: 441
I just noticed it was finalized. I'm all over it as long as the wait period is not insane.
post #34 of 36 Old 02-12-2013, 07:42 PM
cheezit73's Avatar
Liked: 24
Bass Addict,
Since you are running Audyessy with wides and heights now, what are you going do do with SEOS? Are you going to build a LCR SEOS and use your Axiom's or are you going to build SEOS's for heights and wides too? Just curious as I just placed an order for three Fusion Tempests to redo my front stage and cant wait, however prior to pulling the trigger on that I just bought a 4311 and have been running matching wides to my Energys and I have been liking it. Now I just don't know if it will make sense to keep my Energys as wides with the SEOS and may just go back to 7.1 until I can fund building something like the Alchemys as heights and wides. Any how just curious how you are going about it. Do you have any pictures of your setup, I would love to see it.
cheezit73 is offline
post #35 of 36 Old 02-12-2013, 07:49 PM - Thread Starter
Quoted: 360 Post(s)
Liked: 441
Originally Posted by cheezit73 View Post
Bass Addict,
I am going to keep using the Axioms for height and wide. I would think the wides would work even better with the Seos as they are more directional than domes. I would like to build a wide speaker using the Seos, but they are just too big. frown.gif The M2 I am using blends in fairly well sitting right below my sofit. I'd love to get you some pics but I have everything pulled down at the moment redoing my columns and front screen area (upgrading to 2.35 with a new scope setup).
Here's all I have ATM showing the heights with front stage. The wides are mounted on side wall below sofit at 60deg angle from MLP.
post #36 of 36 Old 02-12-2013, 08:22 PM
cheezit73's Avatar
Liked: 24
Very cool, thanks for the picture. I am redoing my front wall too as part of my SEOS upgrade I am switching to an AT screen. I am just going to wire everything for the wides and heights and just try it out. I will move my current Energy towers to duty as the wides. Good luck with your choice on which speakers to go with, I will be posting a build log for my Tempests once I receive them.
