impressions of the NU6000 - AVS Forum | Home Theater Discussions And Reviews
Old 02-13-2013, 08:49 AM - Thread Starter
mikeciccarelli's Avatar
Does anyone have an experience directly with the NU6000 inuke AMP? Looks like it would put out around 1400-1500 RMS? Looking to upgrade the EP4000 as I wanted a bit more headroom. Anyone compared NU4000 to the EP4000 first hand? I know it would only be around 400 watts per channel upgrade (which is good at 4 ohms) but I would reuse my EP4000.
Also I only have normal "bare wire" type connectors on my DIY subs. What's the easiest way to use the outputs on the NU6000 and connect them to standard speaker type inputs?
I was thinking of going non-DSP as I have a XT-32 receiver..
thanks,
Mike
mikeciccarelli is offline
Old 02-13-2013, 09:20 AM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 39
I have experience with the iNuke 3000 DSP. You need to buy some speakon connectors for the amp side, at least.
These are the cheap ones:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=092-058
These are $1 more, but higher quality:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=092-190
djkest is offline
Old 02-13-2013, 10:38 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 690
I went with the "cheaper" ones, and found out they can't handle 14ga/4c wire, which is 11ga when twisted together since only 2 connectors.
The $1 more ones can handle them, placed order just now.
(thx djkest for posting)
mtbdudex is online now
Old 02-13-2013, 10:44 AM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 39
I have a pair of the cheap ones that came with a cable I bought. I can't figure out how to fully dissasemble them to remove the wire. I can see that it may work to use a crecent wrench on one end, but I can't figure out how it comes apart. This is after I've removed the blue collar and the cheap plastic strain relief. I checked Neutrik's website and their directions were most unhelpful.
djkest is offline
Old 02-13-2013, 11:31 AM - Thread Starter
So with the more expensive ones I can just use normal speaker wire and wire up 2 of them? I just want to hook up 1 sub per channel...
thanks,
Mike
Old 02-13-2013, 11:39 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
thanks,
Mike
Yes. It is really easy to do. Just Google: "how to build speakon connectors" and you will see lots of YouTube videos. I found a good video and learned how to do it in about 5 minutes with my iNuke3000DSP. I am a big fan of Speakon now. And I agree spend a little more on the better connectors.
ack_bk is offline
Old 02-13-2013, 12:02 PM - Thread Starter
I'm about to pull the trigger on a NU6000.. Anyone have any other input? I was thinking if it wasn't really much of an upgrade I'd just wait. Again, the EP4000 I have now would be reused on a different set of subs.. Hoping to get a bit more of a kick on the 2 15" LMS-R's..
thanks,
Mike
Old 02-13-2013, 01:18 PM
Stephen Hopkins's Avatar
Do you need Speakon connectors for both the high-level outputs as well as the low-level inputs? Or does the input accept RCA? It's hard to tell from the pictures...
Stephen Hopkins is offline
Old 02-13-2013, 01:50 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Looks like it accepts XLR and TRS for the inputs.
Mrkazador is offline
Old 02-13-2013, 01:56 PM
So a basic Female RCA to 1/4" Mono adapter like this would work for the input?
http://www.parts-express.com/pe/showdetl.cfm?partnumber=090-285
Old 02-13-2013, 02:00 PM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 39
I use this cable and it seems to work fine!
http://www.amazon.com/Hosa-Cable-CPR202-Dual-Inch/dp/B000068O17/ref=sr_1_2?ie=UTF8&qid=1360789189&sr=8-2&keywords=1%2F4%22+to+RCA+cable
Recommended to me by Archea
djkest is offline
Old 02-13-2013, 02:29 PM - Thread Starter
I've used these too for RCA to XLR conversion: http://www.parts-express.com/pe/showdetl.cfm?partnumber=240-438
and they work great..
So I went ahead and bought the NU6000.. I hope to provide some info regarding the switch.. Hoping to have it by Saturday.
thanks,
Mike
Old 02-13-2013, 02:52 PM
noah katz's Avatar
Quoted: 882 Post(s)
Liked: 304
yep, those work fine
Noah
noah katz is online now
Old 02-13-2013, 03:52 PM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
I would get the dsp, it really worth it's price for simplify.
datranz is offline
