Questions about "suggested box size" according to Bass Box Pro and the Driver Manufacturer... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-13-2013, 11:01 AM - Thread Starter
Jon S's Avatar
Quoted: 915 Post(s)
Liked: 295
I am seriously considering building a subwoofer using a JL Audio sub (or two). I see that JL has suggested box size for their subs in their website.... But when I punch in the speaker paramters in Bass Box Pro, the suggested cabinet sizes are way different. For example, the JL12W3v3-4 parameters from JL suggest a box that is 1.75 cu. ft. but bass box pro suggests a volume of 3.09 cubic ft from the TS parameters for a vented enclosure. On the other hand, for a sealed enclosure, JL suggest 1.125 cu. ft and Bass Box suggest a close 1.17 cu. ft. box which is close enough to be negligible.
Which parameters should I follow and why the differences?
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #2 of 3 Old 02-13-2013, 11:12 AM
Bill Fitzmaurice's Avatar
Liked: 5684
Manufacturers typically default to the smallest box that will work at all. mad.gif
Bill Fitzmaurice is offline
post #3 of 3 Old 02-13-2013, 03:10 PM
LTD02's Avatar
Quoted: 2526 Post(s)
Liked: 2869
"Manufacturers typically default to the smallest box that will work at all."
yeah, that's pretty much it...but in their defense, many of them are going in cars which is different from subs designed for theaters.
Listen. It's All Good.
LTD02 is offline
