Tapped Horn little project - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-13-2013, 04:21 PM - Thread Starter
miniac007's Avatar
Quoted: 70 Post(s)
Liked: 32
Hello,
I am starting a new project with a little tapped horn based on this one: http://www.hififorum.at/forum/showthread.php?t=3433
The driver is now unavailable, so I planed to use this one: http://monacor.co.uk/products/speakerbuilding-pa10-12/vnr/105270/
I played a little with hornresp and i get this:
Any advice or suggestion are welcome !
miniac007 is offline
post #2 of 5 Old 02-13-2013, 04:34 PM
LTD02's Avatar
Quoted: 2462 Post(s)
Liked: 2783
if that is what you are shooting for, it looks like it is a pretty exact match.
Listen. It's All Good.
LTD02 is offline
post #3 of 5 Old 02-13-2013, 07:42 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
That curve is mighty fine!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #4 of 5 Old 02-14-2013, 12:21 AM - Thread Starter
miniac007's Avatar
Quoted: 70 Post(s)
Liked: 32
I have a question about excursion and power:
The limit seems to be 16W for 112 db SPL.
So is it a problem for a TH for HT in a 25m2 = 280sqft room (listening distance at 2.8m = 9.5 ft ? Do I need much ? Or what should I do to improve that ?
Is a class T amp of 20W will be a good solution to drive it thru a miniDSP for pass band filter ? Or better using a Gainclone LM3886 based one ?
post #5 of 5 Old 02-17-2013, 01:30 AM - Thread Starter
miniac007's Avatar
Quoted: 70 Post(s)
Liked: 32
Hi all,
I have an other question about the horn building: I want to have a side opened mouth like DTS-10, but I don't understand in this case how to measure L34 and S4:
- Is S4 always the end of the section (S4-2) or is it the area of the aperture (S4-1) ?
- How to measure L34:
* Begining of the aperture L34-1 ?
* Axis of the aperture L34-2 ?
* End of the aperture L34-3 ?
* Always the end of the section L34-4 ?
Thanks !
