One more Econowave speaker build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-16-2013, 02:00 PM - Thread Starter
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 82 Post(s)
Liked: 126
i decided to give these shot and with building a home theater they fit the budget.
they where build from MDF
i wanted them to have a nice recessed looked so the i used 3/4 mdf and also 1/2 mdf for the fronts
then all the parts for from parts express
i ordered duratex speaker box paint ... very happy with this product very easy to apply i used a foam roller to get a smoother finish instead of the rough finish you get with a nap roller
and the end result is very nice sounding speaker
snickers1 is offline
post #2 of 15 Old 02-16-2013, 02:20 PM
mtg90's Avatar
Quoted: 478 Post(s)
Liked: 943
I don't know how wide your screen is but I would suggest moving the left and right speakers as far to the sides screen as you could then toe them in some. Benefits include a wider sweet spot and more even coverage across all the seating positions.
This article should provide some useful insight: http://libinst.com/PublicArticles/Setup%20of%20WG%20Speakers.pdf
mtg90 is offline
post #3 of 15 Old 02-16-2013, 02:24 PM
curtisG's Avatar
Great looking home theater! Any plans for some subs in your room?
Also. agree with mtg90, you might get better imaging with a wider speaker layout across the front
curtisG is offline
post #4 of 15 Old 02-16-2013, 05:14 PM - Thread Starter
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 82 Post(s)
Liked: 126
120" screen will be about 2 inches past the speakers .... 120" i think is the max i go with front row of seats being 11.5 feet back
post #5 of 15 Old 02-16-2013, 05:15 PM - Thread Starter
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 82 Post(s)
Liked: 126
it is wired for two subs each will go in the corners cabinets on the stage ..... i will start with one sub first thou
post #6 of 15 Old 02-16-2013, 05:47 PM
xjagox's Avatar
Quoted: 42 Post(s)
Liked: 39
Do you have dimensions for the speaker box that you made?
xjagox is offline
post #7 of 15 Old 02-16-2013, 05:52 PM - Thread Starter
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 82 Post(s)
Liked: 126
sure
h=22.4 x W=14.5 x D=13.0
post #8 of 15 Old 02-16-2013, 07:21 PM
LTD02's Avatar
Quoted: 2525 Post(s)
Liked: 2868
there is something about your theater that just looks...cool.
nice work.
btw, mtg makes a good point.
Listen. It's All Good.
LTD02 is offline
post #9 of 15 Old 02-16-2013, 08:38 PM
NWCgrad's Avatar
Quoted: 1270 Post(s)
Liked: 1310
Have not seen an econowave build for a while, looks really good.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is online now
post #10 of 15 Old 02-16-2013, 08:44 PM
steve71's Avatar
Quoted: 77 Post(s)
Liked: 44
That looks great. Those speakers just look proud to be there.
steve71 is offline
post #11 of 15 Old 02-17-2013, 08:25 AM - Thread Starter
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 82 Post(s)
Liked: 126
nice work.
thanks .. still got long list of work to do ...... the screen will be 120" which is about 2 inch's past the speakers
post #12 of 15 Old 02-17-2013, 08:26 AM - Thread Starter
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 82 Post(s)
Liked: 126
post #13 of 15 Old 06-16-2013, 02:03 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
What is the foam on the wall ? Is that a professional sound treatment pad or something you found ?
BTW ... really nice theater build !
Mfusick is offline
post #14 of 15 Old 06-16-2013, 02:24 PM - Thread Starter
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 82 Post(s)
Liked: 126
Thank you
i got them from here
http://www.thefoamfactory.com/acousticfoam/wedgefoam.html
they serve the same purpose as putting linaccoustic on wall, i was inspired by sandmans build i really liked the effect when you put lights behind the screen
post #15 of 15 Old 06-19-2013, 05:31 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Mfusick is offline
