Coaxial Center Channel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 02-16-2013, 07:13 PM - Thread Starter
todd.brust's Avatar
Hello all. New to this forum and it seems to have more traffic than my usual forums, but just want to get some feedback and see what people think about this idea. I currently have a set of Tannoy i8 speakers for my main left/right speakers. They are coaxial drivers and I thought it would be a cool idea to carry that over to my center channel. Plus it would combat the problems associated with off axis response with a horizontal MTM design. Eminence has some 8" drivers than can be coupled with a 1 3/8" compression driver. The raw drivers can be had for a little more than $100. All I'd need to do is model an enclosure and design a crossover. What is everyones thoughts on this idea. Any experience with this idea. Any feedback is appreciated. Thanks.
todd.brust is offline
post #2 of 24 Old 02-16-2013, 07:16 PM - Thread Starter
todd.brust's Avatar
post #3 of 24 Old 02-16-2013, 07:19 PM
tuxedocivic's Avatar
Quoted: 1906 Post(s)
Liked: 1725
I think mtg90 measured this coax and it was terrible. Double check, but if I'm right the tannoys are likely a better choice.
Ryan
tuxedocivic is online now
post #4 of 24 Old 02-16-2013, 07:24 PM - Thread Starter
todd.brust's Avatar
I have the Tannoys already and am using them for my main left and right speakers. I'll have to do some searching around this forum. There's seems to be TONS of good information here.
post #5 of 24 Old 02-16-2013, 07:26 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Pick up a third Tannoy for timbre matching.
Face2 is offline
post #6 of 24 Old 02-16-2013, 07:43 PM - Thread Starter
todd.brust's Avatar
Yeah now that I have been doing some research on here, It looks like buying a raw Tannoy Driver would be a good option. The Tannoy 2046 speaker could be a good option. I just have to keep my eyes open online. Or possibly get one direct from Tannoy. I have a buddy who works at a Tannoy dealer.
post #7 of 24 Old 02-16-2013, 08:04 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
looks like the tannoy i8 is +/- 3db from about 90hz up.
http://efxireland.com/pdf/tannoy/ACF113.pdf
the 1.7khz cross seems about right for good directivity matching.
why not just get a third one?
Listen. It's All Good.
LTD02 is offline
post #8 of 24 Old 02-16-2013, 08:15 PM - Thread Starter
todd.brust's Avatar
I don't know if I can get the i8 anymore. My pair was pulled out of an old church that was a 10+ year old install. I think it is a discontinued speaker. Tannoys DI8 and VX8 both look very similar. The VX8 looks a little more similar as far as specs go.
post #9 of 24 Old 02-16-2013, 08:25 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
I did a surround build using the 10cx and I am still using them! I think they sound great and they measure pretty darn well for the money I spent. Moving up to the D220ti was a good move and even though they measure a little differently, I think the same response could be had just popping an L-pad into the stock emminence XO's to level everything out. I have the apt-50's and XO's layin around so PM me if you want to try them out smile.gif Read through the thread too:
http://www.avsforum.com/t/1353658/budget-eminence-coaxial-surround-build
beastaudio is offline
post #10 of 24 Old 02-16-2013, 08:55 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Ebay is your friend.
Face2 is offline
post #11 of 24 Old 02-16-2013, 10:05 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
The coaxial I tested was this one: http://www.parts-express.com/pe/showdetl.cfm?partnumber=290-890 which now looks to be discontinued.
I used a DNA-150 CD in there and the results were not good at all, the only other screw on CD I have is the Selenium DH200E-E which would not screw in completely.
I was unsure if the other Eminence coaxials had a different horn flare or not and whether any other CD's might do better but I can't find FR graphs of any CD's tested in the Eminence coaxials so I am a little worried they might be just as bad. Only graph that does turn up is the one on US Speaker of the 10CX which does not look too bad actually.
Anyway if you can find a third matching Tannoy that would be the way to go.
mtg90 is offline
post #12 of 24 Old 02-17-2013, 12:46 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Email Tannoy and ask them if they still have spares or if they think any of their distributors might have one. They probably wouldn't sell you two, but one is easier; tell them an amp blew and damaged it and you need a replacement.
A9X-308 is offline
post #13 of 24 Old 02-17-2013, 07:34 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
You could always do a clone of the Tannoy, assuming that you could find the matching driver and figure out the enclosure specs. Do these types of speakers have crossovers? I would guess not since they just use one driver, right? Or is that a coax driver that is comprised of a tweeter mounted inside a mid driver?
Martycool007 is offline
post #14 of 24 Old 02-17-2013, 09:30 AM - Thread Starter
todd.brust's Avatar
Thanks a bunch for all the answers so far. I could pull the drivers out of my current Tannoy speakers and take measurements of internal dimensions. Clone The crossovers and get the speaker model number. I have already talked to by old boss and he's going to call Tannoy on Monday or Tuesday. Hopefully come up with some good results.
On a side note, MTG20, what do you use for measuring? I was thinking of getting a measuring system, but don't know what to get. I have used SysTune before but that is way out of my price range. I just want something to toy around with.
post #15 of 24 Old 02-17-2013, 09:37 AM - Thread Starter
todd.brust's Avatar
It is two separate drivers. The compression driver is mounted behind the woofer.
post #16 of 24 Old 02-17-2013, 09:37 AM
Aaron Smith's Avatar
Quoted: 139 Post(s)
Liked: 58
I'm down to my last 17 Tannoys that use the 2046 driver... smile.gif Don't have any I8 cabs, but do have a few single S8 complete cabs that would match perfectly.
Todd, PM me if you would like to discuss further.
Aaron Smith is offline
post #17 of 24 Old 02-17-2013, 10:56 AM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
Right now a Dayton UMM-6 and REW, <$100 and very easy to setup and use being a USB mic.
mtg90 is offline
post #18 of 24 Old 02-17-2013, 11:06 AM
Liked: 1725
You can get the UMM-6 from cross spectrum labs with a third party cal file as well. I use an ecm8000 from cross spectrum with their premium plus calibration. And I use HolmImpulse most of the time. Also check out Arta. A lot of people are using Omnimic as its plug and play and quite powerful, although I've never used it.
Ryan
post #19 of 24 Old 02-17-2013, 02:25 PM - Thread Starter
todd.brust's Avatar
I was looking at the Dayton OmniMic. The UMM-6 sure seems like a suitable idea too.
Is it as simple as plugging the UMM-6 into my computer and then install REW? For under $100 bucks, I think I can deal with that.
post #20 of 24 Old 02-17-2013, 03:08 PM
Bill Fitzmaurice's Avatar
Liked: 4629
Is it as simple as plugging the UMM-6 into my computer and then install REW? .
It is. I use it with HolmImpulse.
Bill Fitzmaurice is online now
post #21 of 24 Old 02-18-2013, 08:44 PM
Quoted: 911 Post(s)
Liked: 489
There are a pair of i8's on eBay right now. (No connection to seller, etc.)
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #22 of 24 Old 02-18-2013, 09:54 PM - Thread Starter
todd.brust's Avatar
Damn, I am going to have a ton of Tannoys by the end of the Month. Haha
post #23 of 24 Old 02-18-2013, 11:06 PM
Quoted: 139 Post(s)
Liked: 58
post #24 of 24 Old 02-19-2013, 12:19 AM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
I still have 8-10 Tannoys in storage...
Face2 is offline
