La SEOS - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 128 Old 03-21-2013, 01:14 PM - Thread Starter
Carl_Huff's Avatar
Quoted: 83 Post(s)
Liked: 104
Mike,
Thank you for your thoughtful contribution! I will certainly be looking deeper into this per your direction. If it is convenient for you, could you please point me to the comments made by DJK? I have the utmost respect for him and would like to read what he had to say on the topic. And I will see what I can do to generate some impedance plots.
_____________
Best Regards,
Carl Huff
Carl_Huff is offline
post #122 of 128 Old 03-22-2013, 12:38 PM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
Here's a link to a bunch of different threads from the Klipsch forum:
http://forums.klipsch.com/forums/p/76770/757339.aspx#757339
It turns out the comments I remembered were in fact from someone named Pete:
My buddy Thermio and I both scratch built a set of LS bass cabs and he did the djk mod to them. He took measurements on one cabinet as the mods progressed. Here is the data:
200 160 125 100 80 63 50 40 31 25 20 HZ
77 80 79 73 72 78 68 60 61 52 51 dB Stock, mouth braced
76 78 78 73 69 75 65 60 66 56 52 4.5 cuft, no ports
76 78 77 75 74 80 70 60 68 54 54 Two 4"dia 10" ports
76 79 78 76 75 80 71 60 68 54 53 Ports cut to 7"
The interesting thing with 10" ports is the boxes went deep, but the snappy, fast horn
sound was lost! Cutting the port length to 7" brought the snap and speed back to same
as stock, plus the lows remained, esp. at the 31Hz box tuning point. This data is with
K33E driver and light stuffing. We think a K43E in this box would be superb, but haven't tried it yet.
I'm going to try the mods using two 4" ports with both ends flaired (Thermio used 4" PVC). Flaring
is supposed to reduce distortion and possibly increase the gain. Parts Express sells the kits.
Neither of us is going back to stock.
Pete
That was from this thread:
http://forums.klipsch.com/forums/p/65188/638314.aspx#638314
Lots more discussion in all the links mentioned in those threads.
-Mike Bentz
~It's all about compromise~
MBentz is offline
post #123 of 128 Old 03-22-2013, 12:56 PM - Thread Starter
Carl_Huff's Avatar
Quoted: 83 Post(s)
Liked: 104
Thanks Mike,
In my efforts to track down DJK I found a new thread where he is adapting a La Scala cabinet to accept four 8 inch drivers on a PPSL manifold (Push Pull Slot Loaded).
http://community.klipsch.com/forums/t/172362.aspx
It looks interesting! I also sent him an email inviting him to join in here.
____________
Best Regards,
Carl Huff
post #124 of 128 Old 03-22-2013, 04:42 PM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
I do like that Push-Pull cancels mechanical inertia, but the distortion cancellation is only for the even harmonics. I would argue that the relative spectra of distortion is just as important (if not more important) than the total energy of the distortion....and cancelling out even harmonics shifts the timbre in the direction of cold/harsh sounding - but maybe some would perceive that as more clean? In all actuality, the distortion reduction really isn't fixing the non-linear motion of the drivers - so all of your IMD products should be very similar. There is also the issue of the basket ringing having one less attenuating surface.
All that to say, I prefer the simplicity of just firing the mouths at each other and taking advantage of the mechanical inertia cancellation.
I'd love to hear DJK's take on that though - I believe he was the one talking about it knocking out only the evens (which is related to the forward motion of the driver being different from the rearward motion).
-Mike Bentz
MBentz is offline
post #125 of 128 Old 03-26-2013, 12:12 PM - Thread Starter
Carl_Huff's Avatar
Quoted: 83 Post(s)
Liked: 104
Just a Quick Update ...
I had the privilege of chatting with Dennis Kleitsch (alias DJK) on the phone this last weekend. What an interesting fellow he is! We chatted at length about his La Scala porting exploits. He didn't find fault with any of my findings but agreed that the 'groundplane measurement technique' as recommended by Mike Bentz was a good idea. I will do that as soon as I have a free day when there isn't a breeze blowing. This is the only time of the year when Bakersfield, California is a windy place!
_____________
Best Regards,
Carl Huff
post #126 of 128 Old 03-27-2013, 07:09 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
_____________
Best Regards,
Carl Huff
Hey Carl, I am just curious, (and too lazy to go back and look at the first post, lol), what woofer are you using in the La Scala bass bin? The Klipsch K-33, perhaps? Did you think about using that CW1526cw from Bob Crites? I was under the understanding that the CW1526 is better than the original K-33, and I would imagine that it would work great in this build. Can you elaborate a little bit on the woofer that you choose to use, and also, why you choose to use it over the CW1526 and/or K-33?
Martycool007 is offline
post #127 of 128 Old 03-27-2013, 08:22 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
It's in the very first post.........
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #128 of 128 Old 02-04-2016, 08:30 AM
BruceGA's Avatar
Liked: 0
I've already started the build and will be uploading PICs soon. I do not know the origin of the attached drawings. If anyone here does know please PM me so that I might give them credit for their contribution.
_____________
Best Regards,
Carl Huff
Carl, The 3D image is one I made with TrueSpace, a now defunct company. My only regret is that I left off the piece that goes across the back under the top of the cabinet. I believe it is 3 inches by whatever the width between the side happen to be. With OS upgrades an stuff, I haven't been able to add the final piece. If I had the 3D models of the horns and drivers, I would have added them to the drawings as well, but alas, not so.
I have other images, different woods and views...
I'm currently refurbing an old pair of LS, and am porting them. We'll see how it goes. Too busy and terrible at managing my time. Thanks for the work you put in.
I usually hang out on the Klipsch forums as Marvel.
Bruce Brown
BruceGA is offline
