Does A beyma woofer and a Tang band tweeter make an excellent 2 way system? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 47 Old 02-18-2013, 12:50 AM - Thread Starter
LINEARX's Avatar
Does anybody have an opinion or experience with either or both of the following drivers for use in a 2 way speaker system:
1) Woofer, beyma 10" model number 10BR60V2
2) Tweeter, Tang Band TW series 28-537SH
In reading the data sheets and analyzing the frequency response curves and distortion figures, they seem to be a good combination.
LINEARX is offline
post #2 of 47 Old 02-18-2013, 07:01 AM
Bill Fitzmaurice's Avatar
Liked: 4628
Where is the woofer down -6dB at 30 degrees off-axis compared to axial? That's the highest frequency where you'd want to cross over to a tweeter.
Bill Fitzmaurice is online now
post #3 of 47 Old 02-18-2013, 09:16 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
This tweeter's been successfully used with low (under 1.5 khz) crossovers many times. How well it would keep up with the Beyma is another question.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=275-140
Jay1 is offline
post #4 of 47 Old 03-29-2013, 10:57 PM - Thread Starter
LINEARX's Avatar
Thanks for the reply s.
The manufacturers data sheet shows a fair response to about 2200Hz. They don't have any off-axis charts.
I've successfully mated these two drivers with 2nd order x-over at 2300Hz.
Both drivers match well at around 90db sensitivity 1w1m.
The Beyma woofer requires about 3 cu ft box. If executed right that'll put the tweeter at ear height as a 34" high floor stander.
LINEARX is offline
post #5 of 47 Old 03-30-2013, 06:09 PM
R Swerdlow's Avatar
Quoted: 66 Post(s)
Liked: 137
I'm confused. If you already built this, why are you asking?
I believe a 2nd order crossover at 2300 Hz used with these two drivers will result in sound with a big hole in the mid range performance.
That 10" woofer might be going into breakup at that frequency. With a 2nd order crossover, you are asking it to produce smooth sound at least one octave higher or as high as 4600 Hz.
This calls for a much smaller diameter woofer, or a 3-way design.
You can't realistically expect any 10" to have wide off-axis performance at that high a frequency. Bill Fitzmaurice is right. The frequency at which that driver starts producing sound in a narrow pattern heard best only directly in front of it (beaming) is likely to be well below 1000 Hz. That will be well below that Tang Band tweeter's ability to make undistorted sound. Tang Band has been known to be rather optimistic in its driver spec. sheets, but you shouldn't buy their info without testing it yourself.
How wide is your cabinet? Did you measure that tweeter's response while mounted in that cabinet. The resulting frequency response curve will look significantly different than the manufacturer's curve because of cancellations caused by diffracted sound coming from the cabinet edges.
R Swerdlow is offline
post #6 of 47 Old 03-30-2013, 07:07 PM - Thread Starter
LINEARX's Avatar
R Swerdlow
My first post was back in February. At that time I asked other DIYers if they had any opinions or experience with the drivers. I hadn't started the building process then.
No one with experience with either driver has responded as of yet.
So, I'm left to experiment on my own with some general audio info from you, Jay and Bill so far.
When using the 10" driver, If I use a 2nd order x-over @2300Hz why will there be a big hole in the mid range performance?
Have you seen the manufacturers frequency plot?
When you use the term "beaming" do you mean the driver has a polar pattern lobe facing front and 25 degrees or less?
Are there NO 10" drivers capable of useful response to 2500Hz or higher?
The Tang Band Tweeter has a Fs of 900Hz. How low can IT be crossed over . . . . safely?
I have the tweeter mounted in a rectangular cab with a trapezoid shape at the top 17" . There is 3/4 inch of baffle to each side and top of the tweeter with the 10" driver below it in a 12" wide baffle.
Speaker box is a floor stander 34" inches high essentially my ear level when seated.
I have tested the tweeter in the box. I'm considering trying it outside the box also.
LINEARX is offline
post #7 of 47 Old 03-30-2013, 08:07 PM
R Swerdlow's Avatar
Quoted: 66 Post(s)
Liked: 137
R Swerdlow
I didn't pay attention to the date of your original post. My fault.
I see your enthusiasm for DIY speaker building, and I want to encourage it, not pour cold water on it. Please understand my comments with that in mind.
When using the 10" driver, If I use a 2nd order x-over @2300Hz why will there be a big hole in the mid range performance? Have you seen the manufacturers frequency plot?
Yes, I looked a the Beyma spec sheet. It only showed an on-axis frequency response curve. I suspect (but don't know for certain) that this driver was made for PA or guitar amplifier purposes. It looks fairly smooth for a 10" driver at high frequencies, but only on-axis.
For PA or instrument amp uses, beaming sound in the mid range is not such a problem as it is for hifi audio, where it will be crossed over to smaller high frequency drivers. The problem comes in the disconnect you'll hear in sound as it goes from a beaming woofer to widely dispersed sound from a smaller diameter driver. You may hear the mid range sound directly on-axis, but off-axis the sound will drop significantly. That will significantly impact the detail of the critical mid range sound, and the lack of dispersion will reduce the ability of speakers in creating a realistic stereo image.
I doubt it. Here are 3 very good quality 10" drivers made by Seas. I use these as examples because I know that Seas publishes reliable frequency response curves measured at 0°, 30°, and 60° off-axis.
http://www.madisoundspeakerstore.com/approx-10-woofers/seas-prestige-ca26rfx-h1305-10-coated-paper-cone-woofer/
http://www.madisoundspeakerstore.com/approx-10-woofers/seas-prestige-ca26re4x-h1316-10-paper-cone-woofer/
http://www.madisoundspeakerstore.com/approx-10-woofers/seas-prestige-l26rfx/p-h1209-10-aluminum-cone-woofer/
With those curves, you can estimate by eyeball what Bill Fitzmaurice described when he said look for the frequency where the sound is (no lower than) 6 dB compared to the on-axis curve. Above that frequency range, these 10" drivers are beaming too much. It's a simple matter of physics, no 10" diameter driver can do much different.
You can also clearly see the frequency where these hifi 10" drivers are going into break-up mode. That kind of noise is ugly and should be suppressed by the crossover. You can also see how the cone material effects how big the break-up peaks are, and at what frequency they begin.
A rough rule of thumb says that you can safely crossover a tweeter at double the Fs if the crossover slope is 4th order, and roughly triple at 2nd order. But that is a general rule of thumb only. You really need to know how the tweeter's frequency response curve looks when mounted in the cabinet.
This short article is an example of what I mean http://www.salksound.com/wp/?p=135#more-135. (I hope you read the whole article smile.gif).
Look at the raw frequency response of the tweeter in the 2nd graph in the article. See the peak at roughly 1700 Hz, followed by the dip at roughly 2700 Hz. This is caused by the interaction of the tweeter and the edges of an 8" wide rectangular cabinet. All tweeters will have a similar profile in that cabinet. But none of this shows up in the manufacturers spec sheet, because it is usually measured with the tweeter mounted on a very wide baffle.
If I understand what you said, where your tweeter is, your cabinet is about 1.5" wider than the tweeter plate? I couldn't predict how your cabinet edges will impact the tweeter, but I hope that article makes it clear why you should know that as you design a crossover.
post #8 of 47 Old 03-30-2013, 11:20 PM - Thread Starter
LINEARX's Avatar
`The Beyma 10" is definitely designed with PRO Audio in mind. I knew that going in.
The data sheet had most info I needed except for off axis plots.
With my limited test equipment a, WT2 Woofer tester, a Behringer DEQ 2496 and an ECM 8000 mike, I can test
the drivers and some rough testing in the listening room.
`The Beyma manufacturers data sheet was somewhat accurate. The response did extend to 4000Hz.
I'm crossing the tweeter at 2300Hz and have found the Beyma easily extends to that Hz on axis.
The combination of zobel, notch filter, and 2nd order crossover have me fidgeting to get a smoother
frequency response. All the components are acting parasitic ie: each time I make a component change
in the crossover, the notch filter changes.
I have read that article on crossovers by Dennis Murphy and also read Philharmonic Audio site which
has a Dennis Murphy. Another Murphy site I read was Murphy Blaster Productions but I don't know if
that's Dennis. Another good crossover work site is here, http://www.mh-audio.nl/index.asp
and a driver tests and comparisons here, John Krutke's ZaphAudio.com.
I've found a diverse opinion on crossover philosophy, some like minimalist with 1st order and nothing else,
others like 4th order crossovers, a zobel, notch filters, and L-pads. Some like to use BSC some not.
A lot depends on other details especially which drivers are in play and what's the design meant to accomplish.
My attempt was to gain a larger more powerful 2 way using a 10" driver. Most 10" drivers in the Home theater arena
are pure woofers in that they have no response past about 1000-maybe 1500Hz. They work well in a 3way.
Looking at Pro Audio 10s I found many drivers with response past 2000Hz, IF you can believe the manufacturing hype.
`I have DIY 2 ways using the "standard" 6.5 woofer and tweeter but felt I needed more bass to match my
subwoofer. @ 80Hz crossover and more power/ loudness.
I'm also trying to gauge the level of importance of a drivers harmonic distortion and IM distortion on actual audible products.
How important are the distortion levels of any driver? How bad can distortion be before it becomes obvious?
I've read much about audio perception but I haven't found anybody that has put everything together for us DIYers yet.
http://www.uaudio.com/blog/how-the-ear-works/
There's much to learn in this hobby.
LINEARX is offline
post #9 of 47 Old 03-31-2013, 11:09 AM
R Swerdlow's Avatar
Quoted: 66 Post(s)
Liked: 137
If you've already built this 2-way, I wonder if you'll really want to change things, but we can always discuss ideas.
The biggest problem I see is trying to get both more bass output and extended high frequency range from a 10" driver. You can't have it both ways without something suffering. You may have measured a frequency response (FR) as high as 4000 Hz, but a FR curve only tells you how loud the sound is at a given frequency. It won't tell you if the speaker is in break-up mode making unwanted noise.
In this FR curve, look in the 2,000 to 5,000 Hz range. There is a sudden drop of nearly 10 dB in response just below 2,300 Hz, followed by a rapid climb by nearly 20 dB by 3,300 Hz. Above that frequency, there is a steady drop off in response. This is characteristic of a paper coned driver in break-up mode, and suggests (but does not conclusively demonstrate) that's the Beyma 10" is also doing that. The rapid up and down swings seen the harmonic distortion curves between 800 and 4,000 Hz also suggest something unwanted may be going on.
The sound may be as loud in the 4,000-5,000 Hz range as it is below 1,000 Hz, but it will not be smooth sounding. At lower volumes this may contribute to an apparent increased detail over and above what's in the recording. Do brass trumpets or horns sound more detailed or more forward? Some people may at first like this increased edge in the upper mid range/lower treble. If you increase the volume, do the brass horns or trumpets sound too forward or become fatiguing? This will vary with the type of music or sound. You have to have a signal that produces those frequencies to stimulate that response.
I wonder if a 2nd order low-pass filter at 2,300 Hz will effectively suppress the break up noise. You can try using a lower crossover frequency, using steeper roll-off slopes, or adding an LCR trap filter to suppress the noisy frequencies.
And then there is the problem of beaming, but I already mentioned that.
Dennis Murphy is a self taught crossover designer with over 25 years experience. He has designed most of the Salk speakers, all the DIY designs at Murphy Blaster Productions, and more recently all of the Philharmonic Audio speakers. Over the years, I have become familiar with his speaker designs, and I've learned that I like his design taste and philosophy. In particular, he favors a flat FR curve over as wide a range as possible. He also depends on his own accurate measurements as a necessary step in crossover design. He has successfully used a variety of 2nd, 3rd, and 4th order crossovers, and is not wedded to a single type. He also makes the distinction between a crossover's electrical performance and roll-off curves, and the acoustic roll-off of a driver combined with the crossover. What matters is the acoustic performance. He has very rarely (or never) seen a successful speaker with a simple 1st order (electrical) crossover. There are some good commercial designs such as Vandersteen, that tout 1st order crossovers, but a quick look at them reveals that they are far from simple minimalist crossovers.
Baffle step compensation (BSC) is not so much a matter of preference as it is based on knowledge of how close a speaker cabinet will be placed to the wall behind it. The further away from the wall, the more BSC is needed to maintain a flat FR curve. In your 2-way speaker with a 6½" woofer, did you use BSC or avoid it to keep the sensitivity higher?
Others may have different opinions than mine wink.gif.
Zaph Audio's driver tests are a very good source of info and his measurements are widely considered as reliable.
The other web site you mentioned (http://www.mh-audio.nl/index.asp) has "textbook" calculators for crossovers, but you mentioned how you've already observed how small changes in components have unexpected effects on the the rest of the crossover, such as in the notch filters. The trouble with the crossover calculators based on "textbook" values, is that they assume driver impedance is constant across the bandwidth.
Yes, I agree, there is much to learn in this hobby biggrin.gif.
post #10 of 47 Old 03-31-2013, 02:19 PM - Thread Starter
LINEARX's Avatar
Thanks for the talk back. It helps.
A useful tool was the WT2 woofer tester. It made it easier to flatten the Beyma's impedance rise through the crossover region
using the correct component values of capacitor and resistor in the impedance compensation network (zobel).
You're correct identifying the breakup region above 2300Hz as a major problem.
Left untreated that PEAK @ 3400Hz DID added too much brass sound on trumpets too much emphasis on violins, and too much ear fatigue.
I experimented with 1st order, 2nd order and 3th order cross overs attempting to avoid the distortions and anomalies above 2300Hz.
I used a Notch filter and moved that filter back and forth from 3000Hz to 3800Hz Looking for the sweet spot.
I changed the resistor in the notch filter adjusting the filter damping from 6dB to as much as 20dB. At one point I had thought that possibly I could use the Notch filter
by itself as a cross over component since the driver's natural roll off was so near to the notch filter in frequency. That didn't work.
I combined the notch with 1st order and 2nd order crossovers. All the while I had a zobel installed.
I have settled on a crossover @ 2300 with the Beyma having a zobel and a 4th order crossover. The tweeter gets a 2nd order crossover and an L pad.
Long term listening sessions will validate whether or not the Beyma 10" is a worthy driver.
A second speaker when I get it built, will show whether or not 2 will exhibit stereophonics and soundstage.
I'm guessing after both speakers are built I'll still be making a few adjustments . . . . and then put them aside and start on the next project.
LINEARX is offline
post #11 of 47 Old 03-31-2013, 04:56 PM
R Swerdlow's Avatar
Quoted: 66 Post(s)
Liked: 137
Interesting. So the 10" woofer got a 4th order low-pass at 2300 with a zobel and an additional notch filter to quiet the worst break up. It seems like you tried nearly every reasonable approach. I had thought you used a 2nd order filter – I must have misread something.
In my previous post when I speculated about the woofer's break up, I forgot to point out another sign of something amiss. In the impedance vs. frequency curve, there is a small blip between 800 and 900 Hz. It may look tiny and ignorable, but in this range I'd hope to see a very smooth impedance curve. Because it occurs at the same frequency as the onset of the harmonic distortion swings, its another warning sign that something you don't want to hear, like break-up, is beginning.
The tweeter has gotten little mention. 2nd order high-pass at 2300 Hz shouldn't be a stretch for it. I'll guess it sounds good. Did you have to pad it down to get it at an even loudness level with the woofer, or were they pretty close?
Yes, your long term listening sessions will tell whether or not you like the dispersion and imaging these speakers can create. In my thinking the Beyma 10" would be a very worthy bass driver in a 3-way speaker. If you cross over the bass to mid range at roughly 400 to 600 Hz, you might not need the zobel filter for it. But a 3-way crossover will also introduce other cans of electrical worms for you to wrestle with. That's for you to decide.
At least you did deal with the big problem of filtering out the woofer's break up noise. To my thinking hearing that is much worse than not hearing enough mid range dispersion.
post #12 of 47 Old 03-31-2013, 07:09 PM - Thread Starter
LINEARX's Avatar
You've pretty much got the picture.
The tweeter will have the 2nd order crossover and the Beyma will have a 4th order for the first prolonged listening session.
The 2nd order may be the final choice for the woofer though. I'm always bent towards fewest parts if there is negligible advantage.
The crossover will be at 2300Hz until there's a reason to change it.
I noticed the little blips on the impedance curve too. I see the one you noted between 800 and 900 Hz and a smaller one
at about 140Hz. Both anomalies were not on the WT2 impedance plot after the zobel was installed.
Maybe the Beyma test machine got knocked by someone walking by at the wrong time. But maybe there IS a point of distress at those frequencies.
I've carefully played the tweeter in free air with a 2nd and 4th order cross over listening for distress from content below 1000Hz.
I didn't note any distress up to 90dB at the listening position 12 feet away. I did note a very slight improvement in possible separation detail with the 4th vs the 2nd.
But that high in the sound spectrum may be all my own tinnitus.
There will be a zobel on the Beyma and a Notch filter @ 3400 cut 3-6dB depending on room placements.
Although both drivers were very close in SPL, the tweeter will have an L-pad for a 1-3 dB cut .
I haven't chanced a 3 way yet. I'm challenged enough by 2 ways. On your suggestion though maybe . . . . .
I've got to rely on the ears of others for some final listening sessions. My hearing is about gone above 8000Hz.
It will take time to make a final judgement.
LINEARX is offline
post #13 of 47 Old 04-01-2013, 01:43 PM
coctostan's Avatar
Liked: 135
LinearX, are you taking measurements and simulating this crossover? Would you mind posting your results?
Generally speaking you will rarely see a 10" woofer used higher than about 2khz. Even if you find a 10" woofer that is flat to 10khz it will be a mess off-axis. As a rule of thumb, I try to minimize waistbanding of the horizontal directivity. Waistbanding is where the directivity narrows and then widens as frequency increases. Instead you should shoot for a gradual transition from wider directivity to narrower directivity with minimal fluctuation. I'll explain below why you are likely not achieving this with your present design.
You can generally estimate the directivity of a woofer based on its diameter from surround to surround. Your 10" woofer is likely about 8" across between the surrounds. This corresponds with an ~1700hz wavelength. This is important because around 1 wavelength the woofer's directivity should be in the ballpark of 90deg. Below ~1700hz it will approach omnidirectional and become a function of the baffle and boundary spacing (aka BSC). Above ~1700hz it will narrow in directivity. This is referred to as beaming.
The tweeter, due to its 1" size will be radiating omnidirectionall below about 3khz...well except that the baffle itself is likely acoustically large. Assuming a 12" baffle, the tweeter should have a directivity of about 180deg from about 1200hz up to about 13khz.
(Caveat: These directivity numbers are rough estimates based on driver sizes. It is is better to measure these for your actual drivers and baffles.)
So with a 10" woofer crossed to a 1" dome around 2300hz I would roughly estimate your horizontal beamwidth as follows:
1000hz - 140deg
1300hz - 110deg
1700hz - 90deg
2000hz - 75deg
2300hz - 75deg
3000hz - 130deg
4000hz - 180deg
To compare to a more common standard like a 6" woofer crossed around the same spot:
1000hz - 180deg
1300hz - 180deg
1700hz - 150deg
2000hz - 120deg
2300hz - 110deg
3000hz - 150deg
4000hz - 180deg
Neither is ideal, but you can see how narrow the 10" woofer version gets. If you take the 6" version and cross it around 1800hz the directivity would be great (for a 1" dome 2-way that is). Here is an example of a very nice 2-way dome commercial speaker that exhibits good directivity with minimal waistbanding: http://redspade-audio.blogspot.com/2013/02/sonus-faber-cremona-auditor-stand-mount.html
You could also cross around 1500hz to the Beyma 10 (someone mentioned this tweeter is comfortable that low):
1000hz - 140deg
1300hz - 130deg
1700hz - 140deg
2000hz - 170deg
2300hz - 180deg
3000hz - 180deg
4000hz - 180deg
So you might be wondering, "why do I want to avoid waistbanding? I can sit with my head in a vice". The reason is that you don't only hear direct, on-axis sound...especially in a home environment. There will be an "unevenness" to the sound because in the range that is rather narrow (from 1700hz - 2500hz) the total sound energy will be far less than the total sound radiated into the room above and below that. I'd go further in depth but if you search on constant directivity or uniform directivity there is enough discussion already out there.
Of course, some people completely ignore directivity. IMO, a uniform off-axis response is the second most important metric when designing a speaker (behind on-axis FR).
My suggestion would be to measure for directivity and try a cross in the 1500hz range (maybe even a bit lower). If you want to quickly hear these differences use an active DSP and switch between two settings where it is flat on-axis with a cross around 1500hz vs the same around 2300hz. The key is to do this in room with both speakers running.
coctostan is offline
post #14 of 47 Old 04-01-2013, 10:53 PM - Thread Starter
LINEARX's Avatar
coctostan thanks for commenting,
I have NOT been taking measurements nor simulations. I have made crossover changes in situ and noted changes using pink noise and RTA
Mike is the ECM 8000 and Behringer DEQ 2496. I don't have a way to capture the results.
Thanks for the discussion of driver "beam" and why a 10" has narrower beam than a 6". I now understand that between the Beyma and the tweeter will exist waist banding.
I'm going to have to read more on constant directivity and/or uniform diectivity to fully understand what happens in the listening environment
which negatively impacts aural perception when a driver produces acceptable frequency response but does so in a narrow 75 degree beam/cone.
I see in the commercial 6" 2 way example you posted that even they deal with "beaming" but with the tweeter at 7KHz.
I have not tested for off axis response yet. I was going to process that stage when I had two boxes completed.
My original interrogatory about the two drivers making an excellent system seems to be exposing some negatives.
The two drivers DO make a system, HOW good remains to be seen.
"a uniform off-axis response is the second most important metric when designing a speaker (behind on-axis FR)."
I haven't heard anyone state that case before. We all learn from one another.
My second most important metric might be price$.
The 6 comments which follow the Red Spade article are interesting too. There are suggestions about what additional improvements can be made to the 2 way.
There's always something.
LINEARX is offline
post #15 of 47 Old 04-02-2013, 01:19 PM
R Swerdlow's Avatar
Quoted: 66 Post(s)
Liked: 137
Thanks cocostan for helping to make this important point clear. I thought I had talked enough about it earlier, but I guess it never hurts to repeat this point wink.gif.
Think about a bare light bulb, and the same bulb with a bowl reflector and lens, a spotlight. Light travels from the bare bulb in all directions, up, down and sideways. Nearly all the light from the spotlight is contained in a narrow beam. The narrow beam from the spotlight carries farther away than light from the bare bulb, but light from the bare bulb spreads over a wider area than the spotlight. Which is better? It depends on how far away you are.
The same goes for sound from speakers, but with one important difference. Sound waves are significantly longer than light waves. The wavelengths of sounds in the audio range are:
20 Hz = 56.5 feet
200 Hz = 5.65 feet
2,000 Hz = 0.565 feet = 6.8"
20,000 Hz = 0.0565 feet = 0.68"
Because sound wavelengths can be similar to the diameters of speaker cones, something important happens. Sound with a frequency of about 1360 Hz has a 10" wavelength, the same as the diameter of the 10" woofer we’re talking about. At lower frequencies, the sound waves are much larger than the cone, and the sound radiates widely (or disperses well), similar to light from a bare bulb. As the sound wavelength decreases, approaching 10", the sound disperses less and less widely. At wavelengths shorter than 10", the sound beams instead of disperses, similar to light from a spotlight. This transition is gradual.
If sound from a speaker (in normal sized rooms) is widely dispersed, we hear it as spacious, and if two speakers produce widely dispersed sound in stereo, we hear it as a well-defined stereo image. The wider that speakers disperse their sound, the better we perceive the stereo image.
Speaker beaming, or waistbanding (I like that term biggrin.gif), is an important aspect of speaker design. A 10" woofer can move more air and dig deeper than a 6½" woofer, and it projects acoustic power over a greater distance, like a spotlight. But the 6½" woofer can disperse that acoustic power better (up to about 2,000 Hz), like a bare light bulb. Because rooms in our homes have walls that reflect sound, and because we tend to sit about 10 to 15 feet away from the speakers, this dispersed acoustic power sounds different and better than acoustic power projected from a beaming driver. In a large auditorium, the large woofer might still be beaming, but the listeners might be sitting 100 to 150 feet away. The speaker's beamed sound will be spread wider at that longer distance.
So in speaker designing, it's worthwhile to use a woofer at frequencies where is disperses sound widely, and cross it over to a smaller tweeter at frequencies where it begins to beam. That way, you avoid waistbanded sound.
post #16 of 47 Old 04-02-2013, 11:19 PM - Thread Starter
LINEARX's Avatar
It seems counter intuitive to limit the Beyma to 1500Hz while it sounds good at this point in the experimental stage, playing to 2300Hz.
On the other hand 1500Hz is further down the spectrum separating it from frequency anomalies above 2300Hz.
But I'm only listening for frequency response and harmonic/IM distortion artifacts and not imaging or holographic audio at this point.
I'm still testing one speaker.
I'll try crossing at 1500Hz and 1700Hz and see how well the tweeter behaves in a 2nd order and a 4th order crossover.
I'll have to purchase more caps and coils. Another reason to try to make 2nd order crossovers vs 4th order, work . . . ie smaller value caps = less money.
"The wider that speakers disperse their sound, the better we perceive the stereo image."
Where in the dispersion angle is the sweet spot? What dispersion angle should we be designing for? Is 180 degrees the optimum?
I had been designing the enclosure to limit baffle dimension to only about 1 inch each side beyond the circumference of the 10" Beyma and 3/4" beyond the Tweeter front panel.
The box edges will be routered to reduce diffraction.
Oh, this Tang Band Tweeter TW series 28-537SH, has an open port on the rear of the back chamber. I'm assuming the port gives direct access to the rear of the voice coil and cone.
If I use this tweeter in a sealed box will the compression and rarefaction of the woofer destroy the tweeter cone and suspension? Will the tweeter be acting as a small PR for the woofer?
I haven't pumped up the volume on the speaker yet. I'm trying to get an answer from Tang Band first.
LINEARX is offline
post #17 of 47 Old 04-03-2013, 12:19 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
power response may even be more important than on-axis response because on-axis response can be fixed with equalization, power response cannot.
Listen. It's All Good.
LTD02 is offline
post #18 of 47 Old 04-03-2013, 06:14 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Can you explain what is "power responce" and how is it adjusted in a crossover? Also how does one maximize on-axis performance within the actual crossover?
Martycool007 is offline
post #19 of 47 Old 04-03-2013, 07:19 AM
Liked: 4628
Power response is the average of axial and off-axis response. In the omni-directional lows power and axial frequency response are the same, as when you look at a polar plot there's equal SPL in all directions. As the off-axis sensitivity drops, seen in a polar plot as a shift from a circle to a lobe to a narrowing lobe, power response goes down. Where it enters the crossover equation is that you want to crossover from the lower frequency to the higher frequency element before the lower frequency element has too much directivity, typically no higher than where the 30 degree off-axis response is down 6dB from axial. If you crossover too high there's a tightening of the polar response at the upper end of the lower frequency element, which balloons out to a wide polar response at the low end of the higher frequency element. You won't see the implications of that on an axial chart, where response will appear flat. You wouldn't hear it on-axis in a very dead room. But you'll hear it off-axis, and in a normal room where you hear both the axial output and the off-axis reflecting off the walls you'll hear it on-axis as well, as a response dip in the combined response of the direct and reflected waves.
post #20 of 47 Old 04-03-2013, 07:52 AM
Quoted: 280 Post(s)
Liked: 176
So let me see if I got this straight, Power responce is the sum or average of both the on-axis and off-axis frequency responce?
What makes the off-axis sensitivity drop? Do you mean the same sensitivity as the impedence? Or is this a seperate term all-together?
I understand that its optimal to have the low frequency driver cross to the high frequency driver before the low frequency driver becomes
narrower in its responce or directivity. I am also curious as to how you determine the 30 degree off-axis responce? Is this something that
is measured with something like REW?
Is this still the case when designing a crossover in a 3-way design? (ie low frequency woofer to mid-frequency driver to high frequency driver-tweeter)
Sorry for what may seem like dumb questions to you guys, but I am just starting to learn about crossovers and acoustics. LoL, I am trying
really hard!
post #21 of 47 Old 04-03-2013, 08:26 AM - Thread Starter
LINEARX's Avatar
LTD02,
Where on YOUR list of priorities does a speaker's "power response" lie?
1) on axis response
2) constant directivity
3) power response
4) harmonic distortion
5) intermodulation distortion
6) group delay
7) transient response
8) crossover topology
9) sound stage
10) room integration
11) subwoofer integration
12) all others
I'm coming to realize that building a speaker is more than just assembling a box and putting drivers in it or conversely, buying drivers and building a box for them.
LINEARX is offline
post #22 of 47 Old 04-03-2013, 08:47 AM
R Swerdlow's Avatar
Quoted: 66 Post(s)
Liked: 137
It seems counter intuitive to limit the Beyma to 1500Hz while it sounds good at this point in the experimental stage, playing to 2300Hz. On the other hand 1500Hz is further down the spectrum separating it from frequency anomalies above 2300Hz. But I'm only listening for frequency response and harmonic/IM distortion artifacts and not imaging or holographic audio at this point.
It may seem counter intuitive, but it is important. That's why some of us have written so many words trying to explain it. Remember that the Beyma woofer was designed for pro audio, where the listening distance may be much greater than in home audio.
I'll try crossing at 1500Hz and 1700Hz and see how well the tweeter behaves in a 2nd order and a 4th order crossover. I'll have to purchase more caps and coils. Another reason to try to make 2nd order crossovers vs 4th order, work . . . ie smaller value caps = less money.
If you're going to try using that tweeter at 1500 Hz, it may be safer with steeper 4th order slopes. Remember that with a 2nd order crossover, the tweeter will still be trying to make sound (12 dB quieter) at one octave lower than the crossover point, or at 750 Hz. A few more crossover parts will cost less than replacing the tweeter.
You have to measure it to find out what your woofer does in your cabinet. Measure frequency response with the test microphone 1 meter away on-axis, and again at 30° and at 60° off-axis. You can move the microphone or move the speaker to get those angles. As Bill Fitzmaurice said, make the crossover frequency "no higher than where the 30° off-axis response is down 6dB from axial". At a practical level, it's easier to look at it that way.
Here is an example of a Seas 10" woofer (CA26RFX) where the manufacturer's spec sheet shows 3 frequency response curves in one graph, the dark line is measured on-axis, and the fainter lines beginning at 500 Hz are measured at 30° and 60° off-axis.
Wait to see what Tang Band says. Conventional practice uses a tweeter in a closed chamber separated from that of the woofer. Many tweeters come with a closed back, just for that reason.
Yes, power response, off-axis response, dispersion, lack of beaming, what ever you call it, is important for any crossover between any two drivers.
post #23 of 47 Old 04-03-2013, 10:03 AM
coctostan's Avatar
Liked: 135
No problem. IMO, one of the differences between a decent home speaker and a great home speaker is how off-axis response is handled. You can achieve whatever on-axis response you desire through the crossover. The off-axis response is first dictated by the physical characteristics of the speaker and no crossover can alter this just like a crossover can't make a 10" woofer play nicely at 20khz.
All dome 1" drivers will collapse directivity similar to that Sonus Faber speaker. The ring radiator style alters it some but not in a large way. You will also see that the baffle is not completely flat in an effort to minimize baffle diffraction. This affects both on-axis and off-axis response.
The most well-known designers (at least that I know of) that emphasize off-axis response are Wayne Parham and Earl Geddes. They go to the extent of using horns to control the upper frequency directivity. You can read some of their papers and web posts.
I'm not sure I agree with the comment about widely dispersed sound being more spacious or giving a more well-defined image. I would argue that the opposite is true. A wide-directivity speaker will simply produce more early reflections which worsen the image. Spaciousness is more a function of late reflections and those can be achieved with narrower directivity speakers.
If your only or primary criteria were FR and distortion, then yes you would choose the bandpass of your drivers accordingly. I'm suggesting this is far from optimal. I would also suggest that listening to drivers individually is not useful. How a driver sounds individually (crossover or not) doesn't hold much weight to be honest. In fact it can lead you down the wrong path. For instance a low-passed woofer will typically sound better than a high-passed tweeter when both are played individually and might skew you towards a higher cross.
Ulimately, using your ear to design a speaker is not a good practice. IMO this should be done only with final tweaking and evaluation of different design hypotheses (such as different on-axis and off-axis targets).
There is no directivity sweet spot (at least not one that is widely held). At a higher level I would suggest targeting uniformity where you don't have significant fluctuations in off-axis response. This creates a more even "total sound" which is what the listener hears in a home setting.
With a 1" dome on a flat baffle you will have collapsing directivity. The question is how you handle the difference in directivity between the woofer and tweeter around the crossover region. You will have to work some compromise of off-axis response and how low that tweeter can play cleanly. The good thing is that you chose a tweeter that appears to play fairly low for a 1" dome.
really hard!
http://techtalk.parts-express.com/showthread.php?225005-Uniform-power-response-best-way-to-get-it
First google result for "power response loudspeaker". It is a pretty good discussion.
The best way to determine the off-axis response of a speaker is to measure it. You simply point a mic at it X deg off its axis and take a sweep. You can also get a rough estimate of based on the size of the diaphragm. That is what I did when estimating where a 10" woofer would be -6db at 90deg off axis. This is only a rough estimate though.
This applies to 10-way speakers. smile.gif There is nothing fundamentally different about a 3-way. Retail speaker companies have been making a big deal of it for decades because it is "more". That is not to say there is anything wrong with 3-way's but like with any design exercise, "right tool for the job" rules.
Ultimately, it is no coincidence that most 1" dome tweeters are used with something like a 6" woofer. As seen with that Sonus Faber speaker, you can get a very nice uniform off-axis response with a 1" dome that can handle a 1st order (guessing that is electrical not acoustic) crossover at 1800hz. There is a little waistbanding, but nothing terrible and about as good as it gets with a 2-way dome speaker. This is absolutely not a coincidence. I'd bet that the woofer they use could easily play up to 3khz nicely on-axis. Given that this is a very expensive speaker, they are also not using the simple 1st order high pass for cost savings or a better on-axis response. The reason they do this is for optimal off-axis response.
Now many cheaper 2-way dome speakers would use a tweeter that might play down to 4khz since it is cheaper to find a woofer that plays that high than a 1" dome that plays down to 1.8khz. This speaker could have a ruler flat on-axis response, but it will sound far worse because there will be a suckout in reflected sound from about 1800hz to 4khz.
The Sonus Faber will sound better than this typical but similar cheaper 2-way dome with 6" woofer. The primary reason (assuming on-axis response is flat in the cheaper speaker) is not because the Sonus Faber will show less distortion (we can assume it will). The primary reason is that it will have a far more uniform off-axis response. Certainly, the lower distortion, etc add to its superiority, but my experience, along with the research I've read indicates the off-axis uniformity is what separates the decent from the good and great.
post #24 of 47 Old 04-03-2013, 10:52 AM
coctostan's Avatar
Liked: 135
One other thing:
There are different levels of refinement. Avoiding beaming is akin to making sure it is not a bad design. Full on beaming, where the -6db beamwidth encroaches upon the direct listening area is simply a poor design IMO. That is the classic "head in a vise" requirement where it will sound bad in the next chair over or if you slouch 12" lower.
What I call waistbanding won't become an issue to direct sound for someone sitting a bit off-axis in most rooms. Waistbanding will have a greater effect on how the speaker interacts with the room and the reflected sound which is also heard by the listeners. The speaker that exhibits waistbanding won't be nearly as bad as the prior severely beaming speaker.
The final level of refinements are how the off-axis response tapers, how low the directivity narrows and the actual beamwidth. What is optimal for all this is up for debate and depends on your constraints (budget, speaker size, etc).
post #25 of 47 Old 04-03-2013, 10:41 PM - Thread Starter
LINEARX's Avatar
Tang Band says "no problem using their tweeter in a sealed box.
They suggest lowest frequency for crossover is 1800Hz.
"Here are the answers for your questions:
That tweeter has a port in back of the chamber.
1) Can I use it in a sealed enclosure with a 10' inch woofer
or will the woofer blow out the tweeter cone and suspension when played loud.
è Yes! you can install 28-537SH in a sealed enclosure with a 10’ inch woofer.
28-537SH do not have to give it a separate air chamber, which itself contains.
2) can I cross the tweeter @ 1500-1700 Hz without damage or creating special distortion conditions?
èThe speaker driver 28-537SH F0 = 900Hz, our recommendation for crossover is 1800Hz or above which is best to set your crossover at this driver.
3) what is the maximum power in watts I can play crossed at 1500Hz?
èFor 25-537SH, RMS=12W above 1800HZ
4) The data sheet says, " rated power input 12W" is that watts? That doesn't seem like much.
It also says "Maximum power input 100W". Is that watts? That seems reasonable.
è 12W= 12 watts( in different speaker drivers have own voice coils which have their own power limits)
12W is the most suitable RMS power for the voice coil of 28-537SH
The maximum power input 100W means the instant power input."
I've done some additional reading on constant directivity. The speaker technology began to change back in the 70s-80s. Directivity became an electrical engineers research and development project. Many papers have been written on it over the years as ways to measure and control it were found. I'm still reading.
According to some of the material I've read, it might be more desirable to use a compression driver and a constant directivity waveguide instead of the Tang Band dome tweeter. That appears to be what Geddes does with his "Abbey" and "Nathan". With the proper compression driver and waveguide, I could cross over lower to the Beyma and possibly achieve a more desirable level of constant directivity.
Parham makes a big deal out of corner horns. I've never heard them but believe they may be the real deal for homes that have the corners to go along with it. Those speakers are much more complex than what I'm trying to build.
LINEARX is offline
post #26 of 47 Old 04-04-2013, 09:10 AM
R Swerdlow's Avatar
Quoted: 66 Post(s)
Liked: 137
You are now getting to see that in DIY speaker building, there are few simple yes-or-no decisions, and lots of decisions based on compromises. With compromises, it's always better to understand the choices.
Your tweeter does have a closed chamber behind it. In your cabinet, it sits in its own chamber sealed off from the rest of the speaker. The written description at Parts Express clearly says that, but there was no photo of the back of the tweeter.
Tang Band recommends a crossover frequency no lower than 1,800 Hz, double the Fs of 900 Hz. They didn't say what crossover slopes apply for that minimum frequency, but I'll guess it might be 4th order. At that frequency, the tweeter will produce about half the total SPL (equal to the woofer output), and one octave lower, at 900 Hz, the tweeter will produce sound about 24 dB lower SPL than at 1,800 Hz. With a 2nd order crossover, the tweeter will make sound about 12 dB lower at 900 Hz, possibly producing audible distortion, or worse.
Because you want to use that 10" woofer in a 2-way design, your choices are go with a different dome tweeter, such as the Dayton RS28 silk dome, or a tweeter with a wave guide or horn. The RS28 dome has an Fs under 600 Hz, and has been crossed over between 1200 and 1500 Hz with 4th order slopes. It's an excellent sounding low-distortion tweeter. There are other dome tweeters that are robust enough for such a low crossover point, but they are all much more expensive.
A wave guide mounted tweeter does allow lower crossover points, but like anything else it comes with some accompanying downsides. I have no experience building or designing speakers with these tweeters, so I can't comment intelligently about them. I do remember once reading about an audible resonance associated with the size of the perimeter of a wave guide, but I don't remember any details about that. Maybe someone else can talk about that. There are other arguable advantages and disadvantages with wave guide mounted tweeter designs. So you should remember that speaker building is a series of decisions based on compromises. With DIY, as you are learning, it really is Compromise It Yourself.
post #27 of 47 Old 04-04-2013, 10:31 AM
coctostan's Avatar
Liked: 135
All designs are an exercise in compromise. Whether you are designing a bridge, a plane or a simple speaker.
Some compromises were made simply by the drivers chosen. It can still work to provide a nice speaker but ultimately I think that is just part of the learning experience.
Working with what you have right now, I would suggest experimenting with playing that TB tweeter lower. From the measurements I've seen it looks like it could go a bit lower. With that said, it has been years since I've used a non-compression driver in a design. The old rule of thumb was always 2x the Fs for domes but I've seen that rule broken successfully. The guys over at Parts Express Tech Talk or HTGuide are more familiar with these design types so you could post over there.
I'm personally biased towards compression drivers on horns. The biggest downside is the price. Before Erich and his efforts it was hard to find a good CD for less than $100 and you still needed to find a quality horn. Now you can get good horn/CD combos for under $100 which is still a good amount more than a $30 dome. There just isn't anyway a dome will give the uncompressed dynamics and directivity control of a horn. Of course you want to use a quality horn and CD.
I think you can make a nice speaker if you can get the tweeter down to around 1800hz (and maybe give 1500hz a shot). You could also buy some inexpensive horn/CD combos and try those. The other option would be to find a nice 6 or 8" option and cross in the 1800hz range.
post #28 of 47 Old 04-04-2013, 11:15 AM - Thread Starter
LINEARX's Avatar
I'm always willing to compromise as long as I get my way . . .
None of the info on the Tang Band tweeter at any of the distributors that I checked:
Parts Express
Sears
Amazon.com
HiFi Alternative
Solen
nor the Tang Band Site, mentioned the rear port or had more than a front picture.
Like you said, there's always something to learn.
I've decided to try crossing the tweeter at 1500 to 1800 with a 4th order and analyze the result.
I'm contemplating a tweeter and wave guide.
I'm going to re-review possible cone tweeter alternatives looking for a suitable lower crossover point near 1200 to 1500.
I'll take a close look at the Dayton RS28 first.
If I need to change tweeters I can use the Tang Band in surrounds with a 5-6 inch woof.
Is there no end to this stuff?
LINEARX is offline
post #29 of 47 Old 04-04-2013, 11:41 AM - Thread Starter
LINEARX's Avatar
Originally Posted by coctostan View Post
" it has been years since I've used a non-compression driver in a design. "
I've looked at many compression drivers anticipating a possible 2 way project sometime in the future.
Many of the compression drivers have poor performance data compared to domes but a few show excellent stats but were the more expensive ones.
If I remember right they were in the $100 dollar range and up.
Which particular compression drivers have you had experience with?
LINEARX is offline
post #30 of 47 Old 04-04-2013, 11:41 AM
coctostan's Avatar
Liked: 135
I don't remember if you mentioned, but do you have something like a Dayton USB mic and REW or HolmImpulse or the OmniMic setup? You really need to be able to take good measurements. From there you can model just about anything.
