question of statements front baffle thickness - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-18-2013, 12:40 AM - Thread Starter
Thomas 1966's Avatar
I am using 3/4 inch red oak plywood for my statements center build
the front baffle lists using 3/4 and 1/2 glued together
can i use only one sheet of 3/4 or 2 sheets of 3/4 as I have no 1/2 inch
I am going to stain no paint or veneer so I do not want to use another material
If I have to use half inch I will hide it inside the the box having only I sheet showing
why is the baffle to be 1 1/4 inch what effect does this have would 1 1/2 inch be ok or better?
Thomas 1966 is offline
post #2 of 3 Old 02-18-2013, 01:53 AM
Mrkazador's Avatar
Quoted: 259 Post(s)
Liked: 388
Might interfere with the drivers so route out a recess or create a larger bevel/chamfer.
Mrkazador is offline
post #3 of 3 Old 02-18-2013, 04:09 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 177
Can't hurt to go with 2 layers of 3/4" birch, just be sure to route out the holes for the drivers in a way that lets the drivers have some breathing room.
Thomas 1966 likes this.
Martycool007 is offline
