Want to use Dayton RSS390HF-4 15 for outdoor Sub. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-23-2013, 04:31 PM - Thread Starter
deathinc's Avatar
I want to use 1 of my 2 Daytons RSS390HF-4 15 for outdoor use w a pair of B&W WM6. Subwoofer will be 100% music. I need to know if they are weatherproof,specially sun resistant. I also need a recommendation for some type of weatherproof paint for the cabinet. Please help me make this possible!
BTW I will be going sealed because I will be powering it by a oaudio 500w amp that has no HPF for ported :S
Av123 Onix Rockets RS1000 , AV123 RSC200 BIGFOOT, B&W WM6 White, Denon AVR-4311CI 9.2
DIY Stereo Integrity SI 18" Subwoofer X2, HTPC Running XBMC 14TB , Roku HD Player
Sony VPL-VW70 Pojector, Xbox 360 250GB, Yamaha RX-V573
deathinc is offline
post #2 of 5 Old 02-23-2013, 04:34 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Any kind of truck bedliner would do the trick for the cabinet.
I am not sure about the driver.
I have an outdoor sub as well, but I use a horn where the driver is not exposed to the elements.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #3 of 5 Old 02-23-2013, 04:37 PM - Thread Starter
deathinc's Avatar
I will probably have a speaker grill in place. I could always use some kind of outdoor furniture cover to preserve it.
deathinc is offline
post #4 of 5 Old 02-23-2013, 04:46 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Anodized aluminum cone, rubber surround. It should be fine outside, but the only way to know for sure is to wait a few years.
Jay1 is offline
post #5 of 5 Old 02-23-2013, 07:44 PM
Ricci's Avatar
Quoted: 190 Post(s)
Liked: 489
I would suggest that the cone should be placed to avoid direct sunlight. Down firing would be good. A gray-black metal cone and surround will get very hot in direct sun in the summer months. Hot enough that the cone will burn your hand if left for more than a few moments and the adhesive for the surround attachment could very well fail if used while that hot. I have had this happen while outdoor testing metal cone drivers.
Ricci is offline
Dayton Audio Rss390hf 4 15 Reference Hf Subwoofer 4 Ohm
