lt.1300 and lms 5400 ultra - AVS Forum | Home Theater Discussions And Reviews
Old 02-25-2013, 10:02 PM - Thread Starter
ozziedog's Avatar
Liked: 24
So I've been waiting for the you UXL-18 to come back into stock and I was going to build a small sealed box and power it with the lt.1300. But I have a chance to pick up a used lms 5400 Ultra locally for a good price. My question is, would the lt.1300 be powerful enough for the LMS 5400 ultra?
ozziedog is offline
Old 02-25-2013, 10:06 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
winisd
cookieattk is offline
Old 02-25-2013, 10:09 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Real world power on that amp was around 1,000 watts. Will it work, yes. Will it work well, not really.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
Old 02-26-2013, 01:08 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1555
You will not be happy with the output of the 1300.
I had one, and I sold it. FP14k clone is a much better value for the money.
BassThatHz is offline
Old 02-26-2013, 03:18 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
You won't know if 1000w is enough unless you try it.
However, unless you can buy one for under $150 it would not be worth it.
You can get some real world power from an affordable pro amp like the EP4000 for less than $300.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
Old 02-26-2013, 04:38 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I already have the lt.1300 and won't be able to purchase any more amps for at least a few months
ozziedog is offline
Old 02-26-2013, 04:54 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You would be better off with a driver that would make full use of 1k watts. If that amp has a HPF a ultimax 15 would be s good choice, and its only $200.
Jay1 is offline
Old 02-26-2013, 07:34 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
If you already have, try it!
I used a 1000w amp with my first 5400 and it did pretty well.
You could always go with a larger cab to increase the efficiency, say 5 cubes.
Joe = LFE Addict
jpmst3 is offline
Tc Sounds Lms Ultra 5400
