***SEOS 12 / DNA-360 / Eminence Delta 12LFA Curved Build*** - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 218 Old 08-19-2013, 07:58 AM
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 256
Originally Posted by cuzed2 View Post
Thanks Tux!
I will try swapping the tweeter polarity this week and will report back.
As for for near-field measurements; most of today's sweeps were taken in-room with the MIC 36" from the baffle face. Does near-field mean I should move the MIC even closer?
OK Gang - did some more testing this weekend. The polarity swap for the tweeter (360 CD) was indeed necessary, see below.
The graph below is after I swapped the polarity on the RF (GOLD), as compared to the LF (Blue) that had not yet been changed:
The following is an even better comparison of the LF before (BLUE), and after (RED) swapping the polarity
And then some more investigation of the LF roll-off for the mains, and why Audyssey is crossing my mains over at 150Hz.
As per Tux's recommendation; I did a close MIC measurement of the deltalight II woofer, here is the result, 1" from the dustcap for both the LF and RF.
So with the my front SEOS mains behaving well; I have to assume that my roll-off is related to my room, mains placement, and/or room treatment related...?
Probably time to take this to the "acoustical treatment thread" or the "simplified Audyssey thread"
LTD02 likes this.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #212 of 218 Old 10-05-2013, 01:25 PM
Java's Avatar
Hey, Cuzed
I hate to hijack Nick's thread, but his polarity issue continues to keep my curiosity. Your mains are 2512s using this crossover design, right?
Any updated impression on the polarity swap?
It's a bit of pain for me to open my boxes back up, so I wanted to check with you.
Java
Java is offline
post #213 of 218 Old 10-05-2013, 01:32 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
"As per Tux's recommendation; I did a close MIC measurement of the deltalight II woofer, here is the result, 1" from the dustcap for both the LF and RF."
p-f-s!
Listen. It's All Good.
LTD02 is offline
post #214 of 218 Old 10-06-2013, 09:59 AM
Java's Avatar
p-f-s!
Java is offline
post #215 of 218 Old 10-06-2013, 10:27 AM
LTD02's Avatar
Liked: 2888
Acronym: Pretty F_cking Sweet
1. Used as a way to describe something that is just way to cool for school.
2. Also used when saying 'Sweet' just doesn't cut it.
Example 1:
"I checked out that DJ from SA that you told me about. PFS!"
Example 2:
"I got digets from two girls at that show, now thats PFS."
LTD02 is offline
post #216 of 218 Old 10-06-2013, 10:36 AM
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 256
Originally Posted by Java View Post
Hey, Cuzed
Java
Java,
I just checked; and yes that is the same XO design. However; the polarity to the CD has now been reversed from what is shown on that schematic. As for listening impressions; the vocals in stereo mode seem to be more "forward" (don't think it is placebo effect).
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #217 of 218 Old 10-06-2013, 10:38 AM
Java's Avatar
Example 1:
Example 2:
Java is offline
post #218 of 218 Old 10-26-2013, 07:29 AM
Java's Avatar
Hey Cuzed,
Missed your reply. Thanks.
I'll give it a try. I always cringe when I have to open up the boxes...
Looking at your and Nick's response curves pre/post, it looks like this is a needed tweak.
Thanks, again
java
Java is offline
