Dayton 18HO - Box dimension question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-04-2013, 08:34 AM - Thread Starter
pauleyc's Avatar
Liked: 24
I'm getting ready to dive into a DIY project, the first subwoofer build since my college car stereo days (~20yrs ago). I was going to wait on the SI18's but the timing is bad. Since I'm putting these behind my screen wall, I need the box to be somewhat shallow. I have flexibility in the other directions to make the box as big as it needs to be. Question is .... is there some laws of speaker building that I would be breaking by building a box with one dimension much smaller than the other two? Most people go more square-ish but I think that is b/c its the most efficient use of space.
Right now I'm looking at two 18s in the front (the priority w/ the new screen wall build) and then adding two SI15 or UM15 subs in the rear. Placement will be on the 1/4 points on the front/back walls. I would prefer to avoid the corners b/c of floor to ceiling bass traps (34" face super chunks). My goal is the drive the 18HOs off a EP4k or 3kDSP in a 4.0 box. I'm currently running two HSU ULS15s that will be sold off.
pauleyc is offline
post #2 of 6 Old 03-04-2013, 08:37 AM
Sibuna's Avatar
Quoted: 375 Post(s)
Liked: 429
Sibuna is offline
post #3 of 6 Old 03-04-2013, 08:43 AM - Thread Starter
pauleyc's Avatar
Liked: 24
My bad .. probably 12" interior on the depth .. box would be 14.25" deep (2x front).
pauleyc is offline
post #4 of 6 Old 03-04-2013, 10:36 AM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 441
That would be fine.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #5 of 6 Old 03-04-2013, 10:53 AM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 39
My sub (was) 18.25" deep, and it could have gone much shallower than that. Probably want a couple inches behind the motor vent, after that you are good.
You probably know but I would recommend keeping the sub low to the ground in the box. When is really gets cranking, it can start moving the box a little bit. smile.gif What are your other planned dimensions?
djkest is offline
post #6 of 6 Old 03-04-2013, 12:32 PM - Thread Starter
pauleyc's Avatar
Liked: 24
Roughly 12"D x 19"H x 32"W internal dimensions (rough napkin estimate), so its going going to be wide but fairly low and shallow which should be fairly stable.
pauleyc is offline
