Amp for a JL Audio 8" W7?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-05-2013, 04:57 PM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
The sub is 3 ohm single voice coil, cause JL has to be different. 500 watts RMS.
So I need an amp 3 ohm stable around 500 watts. Would prefer consumer or plate.
Dayton makes a 500 watt plate amp stable down to 4 ohm, you think it would run the 3 ohm without problems?
Thanks for any help guys!
TenTonBass is offline
post #2 of 6 Old 03-05-2013, 08:58 PM
LTD02's Avatar
Quoted: 2345 Post(s)
Liked: 2584
do you know off hand what the resistance (re) is?
Listen. It's All Good.
LTD02 is offline
post #3 of 6 Old 03-05-2013, 09:04 PM
LTD02's Avatar
Liked: 2584
if this is your driver:
http://mediacdn.jlaudio.com/media/mfg/9013/media_document/live_1/8_13W7_MAN.pdf?1317790345
the manual reports dc resistance (re) is 2.78 ohms minimum. that is well within a reasonable spec for a nominal 4 ohm amplifier and is what many nominal 4 ohm drivers would measure.
jbl has the same goofy spec for their w15gti sub, so maybe it is some sort of car subwoofer marketing thing.
LTD02 is offline
post #4 of 6 Old 03-06-2013, 01:21 AM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
Yeah I think it persuades people to buy the JL amps for car audio purposes. Thanks for the help!
post #5 of 6 Old 03-06-2013, 10:53 AM
Audiophile1178's Avatar
Yesterday, I bridged my Crown XLS2500 to see how the crown would hold up to the 3 ohm load of the 10W7, as well as, the 10W7 getting 2400 watts of potential power. I slowly turned up the pots on the Crown amp until I felt safe and they both held up well. I played some clips from one of the Transformers movies and all was well except for a spot where it clipped really bad but luckily for me it was only a sec and appears to have not done any harm. I did this test as I noticed in WinISD impedance graph showed the sub to be above 4 ohms from 12Hz to 70Hz and sure enough there was no problem. smile.gif You can model the 8W7 in WinISD to see if the results are similar.
Audiophile1178 is offline
post #6 of 6 Old 03-06-2013, 01:20 PM
Manic1!'s Avatar
Quoted: 180 Post(s)
Liked: 76
Any amp that will run 4 ohms will be able to run 3 ohms.
Manic1! is offline
