Dual Dayton RSS460HO-4 Build and questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 37 Old 03-06-2013, 09:32 PM - Thread Starter
ozziedog's Avatar
Liked: 24
Alright my drivers came in today, so I am ready to start building the boxes. I am using 3/4" MDF and am planning on building the boxes to be 20x20x23. To start with I will be powering 1 sub with a LT.1300 but we are fixing to order an EP4000 to power both subs. I do have a few MORE questions though.
1.)What do you think about this box size?
2.)Do I need poly fill?
3.)What are the advantages of Duratex over regular paint?
Thank you everyone for your help.
Especially thank you to those of you that have helped me get to this point!!!!!!!
ozziedog is offline
post #2 of 37 Old 03-06-2013, 09:50 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
That's about spot on for the right size. A lot depends on how much power you plan to apply. If you think you will want to push a little more down the road, I'd decrease the size to around 3.5cf; if sticking with 500 watts or so that's perfect.
No. Should you use it, probably. Up to 1lb per cubic ft will trick the driver into performing like it's in a larger enclosure, which is a good thing. It will also help with resonance to a small degree.
Nothing really. A lot like the wrinkle finish and it's tough as nails. There are many finishes to choose from so pick your poison.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 37 Old 03-07-2013, 10:41 AM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
Using dual drivers that big (18")... I would use minimum one inch MDF, probably thicker... And with a lot of bracing. My guess the 0.75" MDF will not be stiff enough to eliminate resonances, expecially since 18" drivers can really pressurize a cabinet. I am currently building a single 12" RSS315HF-4 in a 18" cube. The speaker baffle will be 1.5" and the rest will be 1" thick. Unfortunately, no one sells 1" MDF here in Hawaii so I have to laminate 0.25" and 0.75" MDF together to make the 1" panels. Not fun.
I am finishing my sub in cherry veneer. Staining it with a blend of dark cherry and cabernet. Then spraying it with either a gloss poly or lacquer. Saw someone do it on a speaker on the Polk forum and it really, really looked nice.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #4 of 37 Old 03-07-2013, 02:48 PM
Quoted: 360 Post(s)
Liked: 437
1" is certainly not required. You will be fine with .75" thick MDF, or 11 layer ply, for all but the front. Bracing is recommended no matter how thick the material so you really aren't gaining anything with 1". In fact, intelligently placed bracing will do more for stiffening than the material itself. For the front I would definitely go with a double baffle of two .75" pieces.
post #5 of 37 Old 03-07-2013, 02:51 PM - Thread Starter
ozziedog's Avatar
Liked: 24
Originally Posted by bass addict View Post
That's about spot on for the right size. A lot depends on how much power you plan to apply. If you think you will want to push a little more down the road, I'd decrease the size to around 3.5cf; if sticking with 500 watts or so that's perfect. .
Since I will be adding more power down the road, what do you think about each box being 20x20x21. That puts the volume around 3.8cf before the driver and bracing.
ozziedog is offline
post #6 of 37 Old 03-07-2013, 02:53 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I thought the .75 would be fine as long as I brace it good and I am planning on the double baffle up front.
ozziedog is offline
post #7 of 37 Old 03-07-2013, 02:54 PM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
+1 on the construction, 3/4 well braced with double baffle is perfect.
On size, I am runing two of these right now in my temp room, each one in it's own 21x21x21 enclosure with 1250w per driver. It's percect! Nary a bad sound or struggle from anything...they just pound cleanly along. FWIW, my cabs are 11 ply birch, double baffle and good bracing...tested and approved.
ChopShop1 is offline
post #8 of 37 Old 03-07-2013, 02:58 PM
Quoted: 360 Post(s)
Liked: 437
There you have it. You can't get a better recommendation than that. biggrin.gif
post #9 of 37 Old 03-07-2013, 03:04 PM - Thread Starter
ozziedog's Avatar
Liked: 24
Alright a 21"cube it is. Thanks for the help guys. I will start cutting wood in about an hour.
ozziedog is offline
post #10 of 37 Old 03-07-2013, 06:37 PM - Thread Starter
ozziedog's Avatar
Liked: 24
All wood is cut.
ozziedog is offline
post #11 of 37 Old 03-07-2013, 07:53 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I only have 3 clamps so this is going to take a while.
ozziedog is offline
post #12 of 37 Old 03-07-2013, 08:45 PM
Quoted: 360 Post(s)
Liked: 437
No nail gun?
post #13 of 37 Old 03-07-2013, 09:00 PM - Thread Starter
ozziedog's Avatar
Liked: 24
No, I don't have a nail gun. My brother in-law has one that he usually lets me borrow but he is in the process of moving and we can't find it. So, I have to go the slow route.
ozziedog is offline
post #14 of 37 Old 03-07-2013, 09:18 PM
Quoted: 360 Post(s)
Liked: 437
post #15 of 37 Old 03-07-2013, 10:26 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I now, but I am tired of the suspense!!!
ozziedog is offline
post #16 of 37 Old 03-07-2013, 11:00 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2572
can't you rent a brad nailer from home depot for $5? i mean if you really want to get done quickly. :-)
Listen. It's All Good.
LTD02 is offline
post #17 of 37 Old 03-08-2013, 01:14 AM - Thread Starter
ozziedog's Avatar
Liked: 24
I don't know? I didn't know you could do that. Either way, I will probably whine about how long it is taking but just keep glueing away. I will have to remember that for next time though.
ozziedog is offline
post #18 of 37 Old 03-08-2013, 02:47 AM - Thread Starter
ozziedog's Avatar
Liked: 24
Does this bracing look alright?
ozziedog is offline
post #19 of 37 Old 03-08-2013, 05:25 AM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Should be fine...the main thing is that you don't want a span of more than 8" or so without bracing if you can help it. I tend to lean toward overkill and go with 6" or so where I can. obviously with drivers this size, there are some places you just can't do that. I would personally move the ones that are furthest apart in the pic to the inside of the four braces that are all really close together if you can and still have clearence for the magnet, etc. They look to have a 15" span or so between them in that side to side bracing. Instead of ripping those out and starting fresh, you could also try to jimmy a single brace going from sided to side, right across the middle of the enclosure like a center point to the four wide spread braces. Just me, it will probably work fine, but the overkill helps you sleep at night biggrin.gif
post #20 of 37 Old 03-08-2013, 06:30 AM
Gomdaf's Avatar
I would think you're getting mighty close to your baffle cut out with those inside 4 braces just by eyeballing it. Still have driver clearance?
Gomdaf is offline
post #21 of 37 Old 03-08-2013, 06:58 AM
mastermaybe's Avatar
Quoted: 362 Post(s)
Liked: 305
^ Yep...and little is a bigger time and material waster than over-the-top bracing. But I suppose if you're into trying to kill things that are already dead and have nothing better to do with your time, money, and materials, go for it.
I've now built 3 different pairs of cabinets- with one cabinet "adequately" and one doubly braced within each pair- and have yet (nor 3-4 others) to hear (never mind measure) a difference in any of them...cabinet resonances included.
Decent materials, craftsmanship, and titebond go a long way.
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #22 of 37 Old 03-08-2013, 07:58 AM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Hadn't even thought about the cab being small and that being an issue, great point...I was just looking at brace spacing:p Flipping all those braces on there sides would help that too.
James,
I hear ya, even if you were a bit blunt biggrin.gif I would say though, making sure you don't have more than an 8" span unbraced isn't overkill, it's ideal. Going beyond that, like I do is overkill, but a few 2" strips is hardly wasted material and takes about two minutes to cut and place, so not really much wasted. If anything, we are using material that would be wasted and giving it a function ( or at least a placebo effect of function:D )
post #23 of 37 Old 03-18-2013, 10:04 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I did have to move a couple of the braces, but I finally had time to work on these again today. Almost ready to start painting.[IMG]
ozziedog is offline
post #24 of 37 Old 03-19-2013, 12:23 AM - Thread Starter
ozziedog's Avatar
Liked: 24
Well I got to test drive 1 tonight and it walks all over my old A7-350. I can't wait to get the other one done and get an amp for it. Considering the Dayton is a budget driver, it is pretty impressive. This is my first attempt at DIY and considering the performance for the dollars I will never buy another pre made speaker again. This has made my night. Thank you everyone for your help.
ozziedog is offline
post #25 of 37 Old 03-19-2013, 10:45 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Wait - you are using your sub boxes before finishing them........for some that means 1 day becomes 1 week becomes 1 month....and on...
I'm resisting using my in process boxes till all finished....
I see a little girl in the foreground, how does she like them?
My 3 kids think I've gone overboard at times with this hobby...
mtbdudex is offline
post #26 of 37 Old 03-19-2013, 11:42 AM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Great to hear you are enjoying it....wait until you get two up and running with full power smile.gif
post #27 of 37 Old 03-19-2013, 12:22 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I had to force myself to take the driver back out and work on the finish today.
Both my kids love it. My daughter loves dancing and singing to the music and my son thinks it cool when the house shakes.
ozziedog is offline
post #28 of 37 Old 03-19-2013, 12:26 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I should have the other one done in the next couple of days. I am on vacation so I actually have plenty of time to work on them right now. I just got to find an amp for a decent price. I was thinking an ep2000 bridged should be good for the other one.
ozziedog is offline
post #29 of 37 Old 03-19-2013, 08:25 PM - Thread Starter
ozziedog's Avatar
Liked: 24
Done painting one, just have to make the grill.
ozziedog is offline
post #30 of 37 Old 04-22-2013, 10:35 PM - Thread Starter
ozziedog's Avatar
Liked: 24
Ok, I am finally finishing up my second sub. I have purchased an inuke6000 and a balanced mini dsp but I am still confused as on how to hook up the mini dsp. I think I understand it all except how to wire from my avr (RX-a2000) to the mini dsp. Can anyone please help make this clearer for me?
ozziedog is offline
