Twin sealed SI HT18's or F20/ lilwrecker for first DIY subwoofer project - AVS Forum | Home Theater Discussions And Reviews
Old 03-06-2013, 10:51 PM - Thread Starter
madmaxz28's Avatar
SO ive been a long time reader of this and other home theater forums. ive decided to take the plunge and dive into the world of DIY HT subs. ive done plenty of car stuff in the past. my HT rooms a basement room about 30x15x8. power will be provided by an inuke3000dsp.
ive decided i want to use the new SI HT subs. i love SI as a company and used to love there subs in my car audio projects and i currently run 2 BM mkIII's in my truck.
ive decided on either 2 sealed HT18's in 4.5-5ft3 each
or a single F20/lil wrecker with a SI HT15. im leaning toward the lil wrecker since i have the room and i like the low end capability over the or f20.
with the good price of the SI subs and the high prices of building materials i think im looking at around the same cost to do either. $500 + amp
Just wanted to get some opinions on SPL/SQ capability's of the 2 setups 60% movies / 40% music
madmaxz28 is offline
Old 03-06-2013, 11:01 PM - Thread Starter
madmaxz28's Avatar
btw with the F20 id use a dayton hf 15 or ultimax since there a better suit for the f20
Old 03-07-2013, 05:49 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
It has been my understanding that with the F-20, you will get gobs of output from like 50hz and up, but it doesn't extend very low, probably 20hz or so with some lower dbs at that point. I would go with the duel sealed SI 18's. You might not get as much output but they will extend lower. I am not sure about that lilwrecker or what ever it's called, and I may be wrong about all of this, so I am interested in hearing some other opinions on this. I would imagine that if you did go with the F-20 variant, using a high quality Stereo Integrity 15" driver would be better than the Dayton DVC15, right?
Martycool007 is offline
Old 03-07-2013, 08:56 AM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
You've got it backwards, the f20 hits plenty hard in the 20-50 range.
I don't think the SI15 works in the f20 enclosure. And while it models well in the lilwrecker, it has yet to be tried.
stormwind13 is offline
Old 03-07-2013, 10:56 AM - Thread Starter
madmaxz28's Avatar
yes i would most likely use a dayton sub in the f20. but think if i go big might as well go BIG . lil wrecker
madmaxz28's Avatar
