Help to fill or not to fill sub enclosure - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 03-07-2013, 04:35 PM - Thread Starter
DIESEL758's Avatar
Hey guys I built the boxes and they came out to 4.434 ft3 per enclosure.These are for two Dayton RSS460HO 18's. Iam getting a little high pitch crackle from the voice coils on certian notes, especially the beginning scene on the movie IMMORTALS. I really don't notice it any other time. I have a behringer FBQ3102 going to my crown xls1000, the amp is bridged running Dayton RSS460HO 18's. really not knowing how much power each sub is getting should I add fill to the enclosures. Will this help eliminate the crackle or is there something else going on I don't know about.
DIESEL758 is offline
post #2 of 18 Old 03-07-2013, 05:05 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Well based on that amp it's not from overpowering them. You could be clipping the signal.
Achievement Unlocked
Psychotic Episode Averted
bass addict is online now
post #3 of 18 Old 03-07-2013, 05:07 PM
A9X-308's Avatar
Quoted: 1307 Post(s)
Liked: 971
Without hearing it 'crackle' sounds to me that the amp is possibly clipping on that scene.
A9X-308 is offline
post #4 of 18 Old 03-07-2013, 05:15 PM - Thread Starter
DIESEL758's Avatar
That is also what I was figuring I have since played around with the gains and it has pretty much stopped. Do I or should I put fill in the enclosures??? Right now I have the boxes lined with .75 inch fill it is glued all the way around, it is the kind that comes in a roll. Since I don't have any kind of equipment to set gain structure on the cleanboxpro,FBQ3102,and XLS1000 is there a way I can get it in the ball park to keep everything safe???
post #5 of 18 Old 03-07-2013, 05:43 PM
A9X-308's Avatar
Liked: 971
That confirms it then.
It's unlikely to make very much difference
That stuff is barely useful in a full range enclosure, and does absolutely nothing in a sub.
It's not going to damage anything, so when you hear it distorting, turn the volume control down a bit, or get a bigger amp so it doesn't happen in the first place, providing of course you're not going to exceed Xmax.
Do you have any measuring gear at all?
A9X-308 is offline
post #6 of 18 Old 03-07-2013, 05:52 PM - Thread Starter
DIESEL758's Avatar
Would running another xls1000 to the other sub help??? That would put each sub at 1100 watts bridged into 4 ohms from the xls1000's.
post #7 of 18 Old 03-07-2013, 06:00 PM
A9X-308's Avatar
Liked: 971
It would work, but personally I'm not a fan of bridging amps into low impedances. Or you could sell it and buy something bigger.
A9X-308 is offline
post #8 of 18 Old 03-07-2013, 06:08 PM - Thread Starter
DIESEL758's Avatar
Is being bridged in 4 ohm load considered low impedance??? The subs are 4 ohm
post #9 of 18 Old 03-07-2013, 06:38 PM
A9X-308's Avatar
Liked: 971
Bridged, each channel is effectively driving half the impedance or 2R.
A9X-308 is offline
post #10 of 18 Old 03-07-2013, 06:53 PM - Thread Starter
DIESEL758's Avatar
So right and left channel are at 2 ohms and combined or bridged that puts them at 4 ohms??? Is running the amp or amps if I get two going to ruin them or cause problems??? The amps only see action when we watch a movie other than that they are off the rest of the time I do not have them on while watching regular tv programming.
post #11 of 18 Old 03-07-2013, 08:53 PM
Quoted: 360 Post(s)
Liked: 437
4ohms bridged = 2 ohms stereo. I personally have never had an issue with 4 ohm bridged loads or 2 ohm stereo. Now 2 ohm bridged is another story. smile.gif
It certainly won't ruin the amp running in 4 ohm bridged. Heat is the enemy, so give them plenty of circulation and they'll be fine. Don't sweat it.
post #12 of 18 Old 03-07-2013, 09:04 PM - Thread Starter
DIESEL758's Avatar
Thanks, I really didn't think it would hurt anything and the amp is well ventilated, I will add another one and see how that works out. Hopefully 1100 watts each will be just right. Right know it is pretty darn loud and they are stacked and put in the corner. I might try separating the box (it's one enclosure) and see how it reacts. My room layout sucks, my room is 15ft wide and 20ft long with solid wall to my left and rear and front with wall to my right is solid but has stair entry to rear of LP and front of LP to the right leads to hallway.
post #13 of 18 Old 03-07-2013, 09:36 PM
Quoted: 360 Post(s)
Liked: 437
Is the 4.4cf enclosure net? If so, be careful throwing 1,100 watts as you might risk bottoming the driver.
post #14 of 18 Old 03-07-2013, 09:40 PM - Thread Starter
DIESEL758's Avatar
Yes that is net. What would be a better size for the wattage?? Is there a simple way to make the enclosure smaller???
post #15 of 18 Old 03-07-2013, 09:47 PM
antisuck's Avatar
Quoted: 98 Post(s)
Liked: 141
Pull driver, insert bricks (chunks of 2x4, etc), reinstall driver.
antisuck is offline
post #16 of 18 Old 03-07-2013, 09:50 PM
Quoted: 360 Post(s)
Liked: 437
No need to worry about changing the enclosure, just don't throw a ton of watts at it. Win Isd shows xmax at around 15 hz with 700 watts with that amount of airspace.
The SPL difference is minimal between 4.4 with 700 watts and say 3.25 with 1000.
post #17 of 18 Old 03-07-2013, 10:01 PM - Thread Starter
DIESEL758's Avatar
Sounds good thank you!!!! I really don't now the real world watts the xls1000 puts out bridged but I bet it's somewhere in the 800 to 900 watts. Also is there really a big gain by adding the second amp?? Iam guessing that being bridged at 1100 watts and both subs running off that channel they are probably seeing around 450 watts each.
post #18 of 18 Old 03-07-2013, 10:12 PM
Quoted: 360 Post(s)
Liked: 437
You can't run both subs off of a bridged channel. 2 SVC 4 ohm coils can either be wired for 2 or 8 ohms. 2 will frag the amp, and 8 won't put any power out. Either run it like it is, or get a second amp.
