TC Sounds LMS5400 18" VS Dayton Audio RSS460HO-4 18" Reference - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 184 Old 11-11-2013, 04:08 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5278 Post(s)
Liked: 4163
Originally Posted by laeriq View Post
Not to rain on the parade, but I'm pretty sure that TC Sounds doesn't recommend upfiring or downfiring configurations for the LMS. Not saying it won't work, but that's a lot of magnet on top of the cone.
Hmm. I've never heard that before. The LMS-Ultra is certainly capable of either up or downfiring applications with no issues.
Maybe what you are thinking of is TC's VMP passive radiators? You are definitely not supposed to use those up or down firing.
Scott Simonian is offline
post #182 of 184 Old 11-11-2013, 04:52 PM
laeriq's Avatar
Quoted: 62 Post(s)
Liked: 90
From the manual, bolding my own-
Not Covered By Warranty:
• Misuse or over excursion
• Thermal abuse to the voice coil or glues around the voice coil
• Thermal abuse to the lead wires on the spiders
• Mechanical damage due to over excursion or excessive acceleration
• Dents in the cone from bottoming out the driver or inadvertent force
Spider sag due to gravity in a down or up firing position for long periods of time
• Damage due to moisture
• Shipping damages
• Cosmetic damage
• Consequential damage on other components
Not saying what dgage is doing is right or wrong, just pointing out that TC Sounds won't cover issues with that application under warranty. Still should be a great project, just making sure he was aware of that info. Not everyone reads the manuals tongue.gif
laeriq is offline
post #183 of 184 Old 11-11-2013, 04:59 PM
Bass Enabler
Liked: 4163
Ah. I see. They are just covering their butts.
post #184 of 184 Old 11-11-2013, 08:21 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1557 Post(s)
Liked: 1346
Thanks Laeriq. Based on the Parts Express calculator, I think I'll take my chance as long as the LMS 5400 works from the beginning. But it's good information for others to know so they can choose whether to do a down or up firing subwoofer.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
Tc Sounds Lms Ultra 5400 , Dayton Audio Rss460ho 4 18 Reference Ho Subwoofer 4 Ohm
