Porting and box size? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-08-2013, 11:56 AM - Thread Starter
Shady195's Avatar
Liked: 34
Sorry to make another thread but this is a learning experiance and maybe im just not typing the right context into google to get my answer..
When you look at drivers, when they give a sealed vs ported enclosure they all seem to have a small sealed enclosure, and a vented enclosure twice the size.. For example the 15" Ultimax im sticking in one of EricH's flat packs calls for a 3.1 cubic ft sealed enclosure and a 6.1 cubic foot vented enclosure..
I was playing around with some web program on google, types in EricH's flat pack diemesnions and stuck a 3" diameter 13" long port for a port size and It said it was tuned down to like 20HZ IIRC
but what is the reasoning behind having a bigger enclosure? if the enclosure is to small and ported does it harm the driver? or can you really just stick a 3" port in a box like that and get the output you want...
Excuse my ignorance, especially if this is something thats been answered or talked about countless times, just not finding the answer, or maybe its not in simple enough terms that I am realizing the answer is in front of me.
EMP E55ti | EMP E56ci | Polk T15's for surround duty | Ultimax 15" Sub | Integra 40.2 | Rotel 976 | Panasonic 60ST60
Shady195 is offline
post #2 of 6 Old 03-08-2013, 12:15 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
A single 3" port is not enough, you will get chuffing. The ultimax really wants a very large enclosure to be vented (14cu ft would be best). Once you start lowering the enclosure volume you lose a lot of the low end response.
Here is a graph showing different enclosure volumes, all with 500w and a highpass.
Mrkazador is offline
post #3 of 6 Old 03-08-2013, 12:24 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Smaller volumes (under 8ft3) look better when you tune very low, like 16hz or lower. That leads to crazy port lengths ofcourse.
Jay1 is offline
post #4 of 6 Old 03-08-2013, 12:39 PM - Thread Starter
Shady195's Avatar
Liked: 34
Thanks guys, pretty much what I was looking for, maxes sense with the chuffing, dident really think of that, thats a lot of air trying to move through a tiny ass port
Curious to know how this in a sealed enclosure in my room audyssyed will compare to the RW-12D I currently have.
Shady195 is offline
post #5 of 6 Old 03-08-2013, 12:42 PM
Bill Fitzmaurice's Avatar
Liked: 4668
How well it works. Modeling programs default to the flattest possible response with the specs of the driver, which often will result in a smaller sealed cab than vented. It also usually results in less low frequency extension and output with sealed. You don't have to use a larger box with vented, you may change the box size and tuning to get the result you're looking for if it's other than maximally flat.
Bill Fitzmaurice is offline
post #6 of 6 Old 03-09-2013, 01:22 AM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
jay really hit on the key point. as the enclosure gets smaller, the port must become exponentially longer in order to provide the same tuning.
this is why you will never see a very small enclosure, with a big driver, and a very low tuning using a port.
for that purpose, passive radiators can be used.
Listen. It's All Good.
LTD02 is offline
