Need a little DIY help on Driver Replacement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-08-2013, 03:19 PM - Thread Starter
tbraden32's Avatar
I had to replace a blown woofer in my Triad Platinum sub. I have already received my replacement driver and took out my old blown one too. However, when I was putting in the new driver, some of the screws did not tighten, they went in, but just would continue to spin if I tried to tighten them. Assuming the holes are stripped or something.
So my question is, do I make ALL new holes for the screws or do I add some adhesive to make them tight, or do nothing?
tbraden32 is offline
post #2 of 7 Old 03-08-2013, 04:19 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Fill the old holes with wood putty, rotate the driver, drill new holes.
Bill Fitzmaurice is offline
post #3 of 7 Old 03-08-2013, 04:45 PM - Thread Starter
tbraden32's Avatar
Thanks. Final question the previous driver wires were soldiered to the box wires, is that recommended?
post #4 of 7 Old 03-11-2013, 09:24 AM - Thread Starter
tbraden32's Avatar
Any suggestions on above^^
post #5 of 7 Old 03-20-2013, 05:35 AM - Thread Starter
tbraden32's Avatar
Got 4 of the eight screws out. The other four screws will not come out. There are inserts that the screws screw into. Assuming the inserts are just spinning when I'm trying to take the screws out.
I'm stumped on how to get then out. Can not get any leverage as they are recessed into the woofer. Any suggestions on how to get these out?
post #6 of 7 Old 03-20-2013, 06:57 AM
realtight's Avatar
Quoted: 31 Post(s)
Liked: 77
If you take a magnet to the loose screws do they come out a bit? If they do you can dremel the screw heads off... I've had to do that numerous times with t-nuts.
realtight is offline
post #7 of 7 Old 03-27-2013, 05:53 PM - Thread Starter
tbraden32's Avatar
They will come up some, but there will not be enough room to get a dremel in there. The rim of the woofer will be in the way.
Guess I'm gonna try to drill the head off with a metal bit.
