Stupid noobie error... How do I fix? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-11-2013, 04:08 PM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
After constructing a sub cabinet over the weekend, I realized I forgot to insert the t-nuts behind the baffle board for the bolts to hold the driver in. Any ideas how I can insert them after the fact without damaging the baffle? I understand it is rather tuff to insert them into MDF.
I was thinking of using a vise with a board running across the speaker cutout to support the top of tvise without damaging the face. Will that work?
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #2 of 9 Old 03-11-2013, 05:20 PM
Bill Fitzmaurice's Avatar
Liked: 4639
TNuts should always be installed by pulling them into place with a bolt. Use a washer to keep the bolt head from damaging the baffle.
Bill Fitzmaurice is online now
post #3 of 9 Old 03-11-2013, 06:26 PM
mynym's Avatar
Quoted: 22 Post(s)
Why not just use drywall screws and skip the Tnuts?
mynym is offline
post #4 of 9 Old 03-11-2013, 06:43 PM
MattB101's Avatar
Second the motion on pulling them into their predrilled holes with a bolt. I also recommend using a small block of wood to protect the face of the baffle. You could also press them into place with a large C-clamp.
Sent from my recliner. Retired Navy E-8
MattB101 is offline
post #5 of 9 Old 03-11-2013, 06:49 PM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
That's what I meant... C-clamp... not vise... doh...
Thanks all.
Jon S is offline
post #6 of 9 Old 03-11-2013, 07:47 PM
gregzoll's Avatar
Liked: 33
Get some tube stock a larger than the bolt, cut short to allow the bolt that you will use, which needs to be long enough to allow some to stick into the box, so that it will grab the T-nut, place washer between it and the wood, then hold the nut until it starts drawing up, stop when pulled into the wood.
gregzoll is offline
post #7 of 9 Old 03-12-2013, 04:13 PM - Thread Starter
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
I just realized I also ordered Hurricane nuts along with my T-Nuts... Which would you recommend?
Jon S is offline
post #8 of 9 Old 03-12-2013, 04:57 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
Neither, use good wood screws. There may be a few that like H and T nuts but the majority will recommend good wood screws.
N8DOGG is online now
post #9 of 9 Old 03-12-2013, 05:04 PM
Liked: 4639
+1. The only reason to use blind nuts is when the baffle is too thin to hold screws.
