Replacement insulation in JBL speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-13-2013, 10:48 PM - Thread Starter
drewman21's Avatar
Not sure if this is the best place for this question but I am trying to find out what I should do about replacement or extra insulation in a JBL Control 25T speaker. I bought a few Control 25T speakers a few years back when I found out you could by-pass the transformer inside and use them as 8ohm speakers. I just got around finally to working on prep and painting them and I realized I could remove the transformer that I by-passed and make the speakers a lot lighter. Looking at the speaker case with it removed it seems like it might be a good idea (or not) to add more insulation or to fill up the empty space left behind. A friend of mine suggested some shredded denim jean material wadded up. Any one have any ideas?
IMG_0561 by drewmantrivia, on Flickr
IMG_0564 by drewmantrivia, on Flickr
IMG_0568 by drewmantrivia, on Flickr
drewman21 is offline
post #2 of 4 Old 03-14-2013, 03:26 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
fiberglass works just fine.
denim may or may not be a fire hazard depending on how it is used and if it is treated or not.
Listen. It's All Good.
LTD02 is offline
post #3 of 4 Old 03-14-2013, 05:52 PM - Thread Starter
drewman21's Avatar
I would like to keep this low cost as possible so would any fiberglass be ok or not? I see small bags of quick fill fiberglass for window frame cracks for a few dollars or buying a single acoustical fiberglass ceiling tile and cutting it down into chunks to use in a few speakers? Do you think either would work or should i look for something different?
post #4 of 4 Old 03-14-2013, 06:05 PM
LTD02's Avatar
Liked: 2576
acoustical tile is a completely different thing.
your home store may have something like this:
http://www.amazon.com/Owens-Corning-111781-Multi-Purpose-Insulation-Projects/dp/B002JL0030/ref=pd_sim_sbs_hi_24
LTD02 is offline
