Replacement driver for ED A5-350 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-15-2013, 09:27 PM - Thread Starter
steveerat's Avatar
Does anyone have any suggestions or recommendations for a new driver for an Elemental Designs A5-350? I've heard of them being modified to accept a 15" driver, but if there's an option that could just be dropped in, that would be fantastic. I'd also like to maximize sound quality and reliability for $250 or less if possible.
steveerat is offline
post #2 of 5 Old 03-15-2013, 10:27 PM
ozziedog's Avatar
Liked: 24
Modified didn't the a5-350 come with a 15" in it? I believe it was the 16Ov.2. I was gong to suggest the SI 15 D2 but it looks like it may be just a hair too big. Otherwise it would be in your price range at $170 and probably be a better driver than the ED.
ozziedog is offline
post #3 of 5 Old 03-15-2013, 10:50 PM
ozziedog's Avatar
Liked: 24
You might consider the Dayton Ultimax also, it is $170 also and is real close in size to the 16Ov.2.
ozziedog is offline
post #4 of 5 Old 03-16-2013, 10:20 AM - Thread Starter
steveerat's Avatar
Thanks for the suggestions - I'll check them out.
post #5 of 5 Old 03-17-2013, 12:07 PM
ozziedog's Avatar
Liked: 24
No problem. If you find one you like, I would download Winisd and model it with your box perimeters to see if it will work.
ozziedog is offline
Elemental Designs A5 350
