Tritrix - done!! Choosing next build - Econowave old speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-16-2013, 06:31 AM - Thread Starter
khel's Avatar
As my first full scale DIY project I've built myself a set of Tritrixes (TL left and right, ported center and surrounds).
The good part - I love the sound and I am glad that I've decided to go with "easier" design for my first project - I"ve learned so much in that time!
.. and the questionable part is - from one time "build and forget" deal it turned into hobby and now I cannot stop thinking about building next project - haha!!
I'v been reading about Econowave (waveguide) designs on this and other forums for quite some time now - and it looks really interesting and promising. I have a set of old Technics SB2660 speakers that I was thinking about "econowaving" smile.gif (I really like the looks of 12" white woofers}
Here's the part I'm not quite sure about.....
It'll cost me around $200 to upgrade this pair (<95db crossover, D220Ti-8 drivers and Pyle PH-612 waveguide)
If they'll sound as good or better that Tritrix - it'll go for it. (the low end should be better for sure).
... or maybe I just should save a bit more and go with Econowave Deluxe or Pi or Seos or something like that??
Oh yeah, and it's mostly for HT use. The room is 18x24 with vaulted ceiling and 2 big openings to the dining room and second floor. (not sure if it's considered a "big" room or not)
And here's some pictures of my Tritrix build
khel is offline
post #2 of 6 Old 03-16-2013, 07:55 AM
pgwalsh's Avatar
Quoted: 481 Post(s)
Liked: 339
Very nice looking, especially the finish. What was the process on the finish?
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5. Home Theater
On-deck: Finalists, The AviaTrix (soundbar), Statement II's, UM18x4
pgwalsh is offline
post #3 of 6 Old 03-16-2013, 10:21 AM
BeerParty's Avatar
If this is for a home theater setup, what are you using for a sub-woofer? If you have the itch to build something else and you are happy with the 5 Tritrix you have now, a new DIY subwoofer may be your best investment.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #4 of 6 Old 03-16-2013, 05:49 PM - Thread Starter
khel's Avatar
Thanks! On L/C/R I've tried Kilz Orderless primer, Satin Latex and regular roller. It turned out so-so. Cannot say that I liked that primer. Though the big plus of going this way - I could do it inside without any problems.
With surrounds, I used Zinsser BIN - liked it much more. ... then after some sanding - oil based enamel with small foam roller.
That's about it.
Oh, I had some old really thick plastic veneer - so I"ve used it on top and bottom of center channel.
khel is offline
post #5 of 6 Old 03-16-2013, 05:54 PM - Thread Starter
khel's Avatar
Yes, it is mostly for HT. As for sub - well, I'm almost done with it - just need to prime and paint the box smile.gif I'll make another "build" thread when I'm completely done with it.
.. and yes, I am happy with Tritrixes.. but I do want to be happier.. plus.. I have another tv that can use speakers in bedroom - lol.
khel is offline
post #6 of 6 Old 03-17-2013, 01:26 AM
maxcooper's Avatar
Quoted: 13 Post(s)
Your tritrix builds look really good. Nice work.
A SEOS build would be good. I built some econowave Sr speakers to use as pa speakers and I liked them so much that they've been in my living room ever since. Now I am slowly building some seos / dna-360 / AE TD woofer speakers that look nicer to replace them. I built the center, and I really like the way it sounds, I think partly because the dna-360 CD is smoother-sounding than the d220ti.
-Max
maxcooper is offline
