Will this fan fit my EP4000??? BUYING TODAY!!!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 03-18-2013, 08:17 AM - Thread Starter
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
http://www.digikey.com/scripts/DKSearch/dksus.dll?Detail&itemSeq=127817424&uq=634991986025569466
IF for some reason the link doesnt work, its part number 1053-1263-ND
ratm is offline
post #2 of 24 Old 03-18-2013, 08:41 AM
bhazard's Avatar
Quoted: 89 Post(s)
Liked: 57
You just reminded me that I need to buy one for a fan mod as well. It looks like a 24v that would fit, but I'd want to hear from those who have done it for which one they liked best.
bhazard is offline
post #3 of 24 Old 03-18-2013, 08:50 AM
Scott C.'s Avatar
I forget which thread it was, but it seems like someone used this fan: http://www.digikey.com/scripts/dksearch/dksus.dll?vendor=0&keywords=3110sb-05w-b20-e00
It's got the same CFM, and slightly less noise than the one you posted.
Sounds Good to Me... keeping track of my audio projects.
Scott C. is offline
post #4 of 24 Old 03-18-2013, 09:27 AM
bhazard's Avatar
Quoted: 89 Post(s)
Liked: 57
Ship date of 5/14
bhazard is offline
post #5 of 24 Old 03-18-2013, 09:40 AM - Thread Starter
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
Originally Posted by bhazard View Post
Ship date of 5/14
yeah, thats why I posted the one I did. Ships this wednesday
ratm is offline
post #6 of 24 Old 03-18-2013, 09:59 AM - Thread Starter
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
1053-1263-ND This is the part I ordered. We shall see how it goes...
ratm is offline
post #7 of 24 Old 03-18-2013, 10:02 AM
Scott C.'s Avatar
Ship date of 5/14
Ah, didn't notice that.
Scott C. is offline
post #8 of 24 Old 03-18-2013, 10:34 AM
bhazard's Avatar
Quoted: 89 Post(s)
Liked: 57
Luckily Digikey isn't the only place that stocks 80x80x25mm ball bearing 24v fans. Even amazon has a ton.
Going to see if I can find a similar one.
bhazard is offline
post #9 of 24 Old 03-18-2013, 11:20 AM
bhazard's Avatar
Quoted: 89 Post(s)
Liked: 57
Bought this one. Seems like a decent 26dba for the airflow.
http://www.digikey.com/product-detail/en/3110SB-05W-B40-E00/P14752-ND/2615565
bhazard is offline
post #10 of 24 Old 03-18-2013, 11:34 AM - Thread Starter
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
I looked at that one and was just about to buy it, but I saw the one that I bought which was 23db and it ships in 2 days. So will see.
ratm is offline
post #11 of 24 Old 03-18-2013, 11:38 AM
bhazard's Avatar
Quoted: 89 Post(s)
Liked: 57
There are 1,200+ on hand and ships immediately on this one if you want to switch. Cheaper too.
26db - 36cfm
vs
23db - 26cfm
bhazard is offline
post #12 of 24 Old 03-18-2013, 01:05 PM - Thread Starter
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
I already placed the order for the 23db one. Are you going to just splice the wires and use electrical tape? Or some sort of caps?
ratm is offline
post #13 of 24 Old 03-18-2013, 01:25 PM
bhazard's Avatar
Quoted: 89 Post(s)
Liked: 57
Never use just electrical tape, it won't be secure. You're better off using wire nuts if you're not going to solder it.
bhazard is offline
post #14 of 24 Old 03-18-2013, 01:36 PM - Thread Starter
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
Small simple ones from Home Depot?
ratm is offline
post #15 of 24 Old 03-18-2013, 01:40 PM
bhazard's Avatar
Quoted: 89 Post(s)
Liked: 57
Yep
bhazard is offline
post #16 of 24 Old 03-18-2013, 02:10 PM - Thread Starter
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
Sweet thanks!
ratm is offline
post #17 of 24 Old 03-26-2013, 10:05 AM - Thread Starter
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
Done! So much better. Cant even notice that its on 1/2 the time. Much easier than I thought as the hardest part was getting the screws out.
Will push my Cap a little bit when the wife and kids leave.
ratm is offline
post #18 of 24 Old 03-26-2013, 11:48 AM
bass addict's Avatar
Quoted: 370 Post(s)
Liked: 446
I might have to do this mod. My amps aren't even the theater room, but they are still noisy enough when hanging out in the other room that they drive me nuts.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #19 of 24 Old 03-26-2013, 11:49 AM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 433
i have a fan for mine just have not done it yet
the xbox 360 is actually louder, i shoudl fan mod that as well
Sibuna is offline
post #20 of 24 Old 03-26-2013, 11:54 AM
Quoted: 370 Post(s)
Liked: 446
Do you have the latest Xbox? While mine is noticeable, it's definitely not anywhere near the level as the EP4000's.
I wouldn't screw with modding the Xbox fan. Too many RROD's.
post #21 of 24 Old 03-26-2013, 12:08 PM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 433
no i have an older one, i got it in 2007
Sibuna is offline
post #22 of 24 Old 03-26-2013, 01:38 PM - Thread Starter
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
DEF. a noticeable difference.
ratm is offline
post #23 of 24 Old 03-26-2013, 06:33 PM
carp's Avatar
Quoted: 2784 Post(s)
Liked: 2097
Nice man, I did a fan mod back when I had my Caps and ep4000 and it went from crazy loud to I can' hear it from across the room. So worth it. I punished that amp too, clip lights like crazy during demo's and never a problem. It is also nice to know you can't hurt the Cap even with no HPF, I didn't use one.
carp is offline
post #24 of 24 Old 03-26-2013, 07:55 PM - Thread Starter
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
Yup. Couldn't believe the difference. No on to convincing the wife that I need another Cap.
ratm is offline
