Where to start? - AVS Forum | Home Theater Discussions And Reviews
Old 03-18-2013, 01:52 PM - Thread Starter
ScottFrankl's Avatar
Hey all, I'm wanting to try my hand at a DIY sub. My budget is around $500. The room is roughly 12 feet by 16 feet, 8 foot ceilings.
I've not build a speaker or a sub before, so where should I start?
ScottFrankl is offline
Old 03-18-2013, 02:46 PM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
You should start here, as this is where the (subwoofer) crazys live.
The easy starting point is:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-514
http://www.parts-express.com/pe/showdetl.cfm?partnumber=301-512
http://www.diysoundgroup.com/subwoofer-flatpacks-2/3-sub-flat-pack.html
$170 + $200 + $90 + glue paint, wire, terminals, fill ~=$500
This is as simple as it gets. Knock-down box that you assemble. Driver's a drop-in but you will have to cut a hole for the plate amp. A drill, jigsaw and screwdriver are all the tools you'd need, plus glue and paint/sandpaper. I've made diysoundgroup's boxes before; excellent quality - duct tape is all you need to clamp them while the glue dries. This driver is new but very capable, and at a good price. Chose the amp by price too, on sale this month and well suited to this driver.
With a 3 cu ft box, F3 is 32Hz and F10 ~20Hz. In your size room, the lowest supported mode is 35Hz (16 ft. half wavelength), so you're well into room gain by the time the sub starts rolling off. Should be a good match without using any active boost.
Just be aware that there are a dozen "good matches" to your request... this is only one.
Have fun,
Frank
fbov is offline
Old 03-18-2013, 03:54 PM
mobeer4don's Avatar
Quoted: 123 Post(s)
Liked: 117
The only problem with this ^^^^ is that you will likely soon decide that you need to upgrade the rest of your speakers to keep up with what the sub can do. I'm not saying that is a bad thing....but you have been warned wink.gif
mobeer4don is offline
Old 03-19-2013, 11:31 AM - Thread Starter
Thanks guys, this is perfect. Appreciate the replies!
Old 03-19-2013, 01:35 PM
LTD02's Avatar
Quoted: 2344 Post(s)
Liked: 2581
depending on the size of the room, you may need some low end eq that the yung amp does not have.
Listen. It's All Good.
LTD02 is offline
