$500 amp and EQ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-25-2013, 10:13 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I have built 2 subs and currently have 1 powered with a lt.1300 and the other is just waiting on an amp. I just got some extra money and need an amp for the other one and a EQ for the both subs. I would prefer to get rid off the lt.1300 and just have 1 amp and 1 EQ, but am having a hard time finding a combo that would beat the inuke6000 dsp for under $500. I want to avoid the inuke since it doesn't EQ below 20 hz and the amp rolls off below 20 hz also, so if for $500 I need to keep the lt. 1300 for 1 and just find a different amp for the other sub then that will be alright. Any suggestions will be appreciated.
ozziedog is offline
post #2 of 7 Old 03-25-2013, 10:35 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
It would be a little over your budget but the non DSP NU6000 is $400, and a miniDSP is $125....
Jay1 is offline
post #3 of 7 Old 03-25-2013, 10:46 PM
Scott C.'s Avatar
It was mentioned in another thread that the iNuke goes down to about 10Hz before rolling off
http://www.avsforum.com/t/1330665/behringer-inuke-dsp/60#post_22460912
Sounds Good to Me... keeping track of my audio projects.
Scott C. is offline
post #4 of 7 Old 03-25-2013, 11:05 PM - Thread Starter
ozziedog's Avatar
Liked: 24
10 hz isn't bad, I thought I had heard it was 20 hz which would be disappointing, but 10 hz should be plenty for my Dayton's.
ozziedog is offline
post #5 of 7 Old 03-25-2013, 11:10 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I am fine with the extra $25 but with the mini DSP wouldn't I still need to buy a mic?
ozziedog is offline
post #6 of 7 Old 03-25-2013, 11:26 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Well if you plan on EQing your system you're going to need some kind of way to measure the response, but you dont have to have a mic to use the minidsp.
Jay1 is offline
post #7 of 7 Old 03-26-2013, 12:23 AM - Thread Starter
ozziedog's Avatar
Liked: 24
What about the UMIK-1 mic they sale? It is only $75 and I might be able to squeeze that in. Not a $300 omnimic though.
ozziedog is offline
